I am using nRF52832 DK.
I am trying to print Battery service value in log file ( Client side ).
So where i get this information and how can i print this information in my log.
Hi
I suggest you take a look at the ble_app_hrs example in our SDK, which implements the heart rate and battery measurement service. The central application uses the bas_c_evt_handler function to print and read the battery level.
Simon
please let me know how to add log message into a function for ble_app_hrs_c that can be printed on debug terminal.
Hi
The function below is the one reading the battery level. If you flash the ble_app_hrs_c application to one board and the peripheral to another. You should then be able to follow the setup and testing instructions here to test it and print the battery level to a UART terminal.
/**@brief Battery level Collector Handler.
static void bas_c_evt_handler(ble_bas_c_t * p_bas_c, ble_bas_c_evt_t * p_bas_c_evt)
ret_code_t err_code;
switch (p_bas_c_evt->evt_type)
case BLE_BAS_C_EVT_DISCOVERY_COMPLETE:
err_code = ble_bas_c_handles_assign(p_bas_c,
p_bas_c_evt->conn_handle,
&p_bas_c_evt->params.bas_db);
// Battery service discovered. Enable notification of Battery Level.
NRF_LOG_DEBUG("Battery Service discovered. Reading battery level.");
err_code = ble_bas_c_bl_read(p_bas_c);
NRF_LOG_DEBUG("Enabling Battery Level Notification.");
err_code = ble_bas_c_bl_notif_enable(p_bas_c);
} break;
case BLE_BAS_C_EVT_BATT_NOTIFICATION:
NRF_LOG_INFO("Battery Level received %d %%.", p_bas_c_evt->params.battery_level);
case BLE_BAS_C_EVT_BATT_READ_RESP:
NRF_LOG_INFO("Battery Level Read as %d %%.", p_bas_c_evt->params.battery_level);
Simon
Thank you for your reply, it is really helpful for me
