nRF sniffer 3 can't capture BLE packet
I try to use the nRF sniffer but it can't capture any packets.
System used :
Windows 10 Pro x64
Wireshark 3.2.0
Python 3.8
nRF Connect v3.3.0 - Programmer v1.3.1
Hardware used: PCA10040 V0.9.0 (HEX is downloaded by above Programmer)
nRF sniffer used: 3.0.0_129d2b3
Log of command nrf_sniffer.bat
> nrf_sniffer_ble.bat --extcap-interfaces
extcap {version=3.0.0}{display=nRF Sniffer for Bluetooth LE}{help=www.nordicsemi.com/.../nRF-Sniffer-for-Bluetooth-LE}
interface {value=COM3}{display=nRF Sniffer for Bluetooth LE COM3}
control {number=0}{type=selector}{display=Device}{tooltip=Device list}
control {number=1}{type=string}{display=Passkey / OOB key}{tooltip=6 digit temporary key or 16 byte Out-of-band (OOB) key in hexadecimal starting with '0x', big endian format. If the entered key is shorter than 16 bytes, it will be zero-padded in front'}{validation=\b^(([0-9]{6})|(0x[0-9a-fA-F]{1,32}))$\b}
control {number=2}{type=string}{display=Adv Hop}{default=37,38,39}{tooltip=Advertising channel hop sequence. Change the order in which the siffer switches advertising channels. Valid channels are 37, 38 and 39 separated by comma.}{validation=^\s*((37|38|39)\s*,\s*){0,2}(37|38|39){1}\s*$}{required=true}
control {number=3}{type=button}{role=help}{display=Help}{tooltip=Access user guide (launches browser)}
control {number=4}{type=button}{role=restore}{display=Defaults}{tooltip=Resets the user interface and clears the log file}
control {number=5}{type=button}{role=logger}{display=Log}{tooltip=Log per interface}
value {control=0}{value= }{display=All advertising devices}{default=true}
Wireshark message while start capture nRF Sniffer for Bluetooth LE COM3
No packets captured.
As no data was captured, closing the temporary capture file.
Help about capturing can be found at
wiki.wireshark.org/CaptureSetup
Wireless (Wi-Fi/WLAN):
Try to switch off promiscuous mode in the Capture Options.
Please advise, thank you.
Regards.
