python device_page_generator.py -d nrf52832_xxAA -sd "s132_7.0.1" failed
use nrf5_SDK_for_Mesh_v4.0.0_src fail
nrf5_SDK_for_Mesh_v4.0.0_src\tools\dfu>python device_page_generator.py -d nrf52832_xxAA -sd "s132_7.0.1"
  File "device_page_generator.py", line 244, in <module>
    main()
  File "device_page_generator.py", line 238, in main
    write_specific_page(platforms, softdevices, args)
  File "device_page_generator.py", line 177, in write_specific_page
    bootloader_config = json.load(f)["bootloader_config"]
  File "C:\Python35\lib\json\__init__.py", line 268, in load
    parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
  File "C:\Python35\lib\json\__init__.py", line 319, in loads
    return _default_decoder.decode(s)
  File "C:\Python35\lib\json\decoder.py", line 339, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "C:\Python35\lib\json\decoder.py", line 355, in raw_decode
    obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Expecting ',' delimiter: line 8 column 3 (char 180)
But nrf5_SDK_for_Mesh_v3.2.0_src succeed
nrf5_SDK_for_Mesh_v3.2.0_src\tools\dfu>python device_page_generator.py -d nrf52832_xxAA -sd "s132_6.1.1"
Wrote device page for nrf52832_xxAA with the s132_6.1.1 SoftDevice to bin/device_page_nrf52832_xxAA_s132_6.1.1.hex.
pip install intelhex
You are using pip version 6.1.0, however version 19.3.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Requirement already satisfied (use --upgrade to upgrade): intelhex in c:\python27\lib\site-packages
  • Hi John,
    Could you try to update python to at least v3.5.1  ? I'm using Python v3.7 and it works fine for me.
    Also please make sure you installed pip3 install -r requirements.txt
    Also, please use the correct .json file. I attached here for reference.
        "bootloader_config": {
            "bootloader_id": 1,
            "bootloader_version": 1,
            "company_id": 89,
            "application_id": 1,
            "application_version": 1
  • Hi Hung,
     Thanks for your support.
    nrf5_SDK_for_Mesh_v4.0.0_src\tools\dfu>python35 -V
    Python 3.5.4
    nrf5_SDK_for_Mesh_v4.0.0_src\tools\dfu>pip3 install -r requirements.txt
    Requirement already satisfied: pyserial in c:\python35\lib\site-packages (from -r requirements.txt (line 2)) (3.4)
    Requirement already satisfied: intelhex in c:\python35\lib\site-packages (from -r requirements.txt (line 3)) (2.2.1)
    bootloader_config_default.json
            "bootloader_id": 1,
            "company_id": 89,
      "public_key":
      "558cdba44e90f9354a6eae8436ff8a8161556b4bea6980baa9890a6536fe248e5f6a333c1dffa27fc529c67609a1345888176a77a969a700e442271ea792d847"
    nrf5_SDK_for_Mesh_v4.0.0_src\tools\dfu>python35 device_page_generator.py -d nrf52832_xxAA -sd "s132_7.0.1"
        main()
  • Hi John,
    A "," is missing after application_version":1 . Your .json file should look like:
            "bootloader_id": 1,
            "company_id": 89,
            "application_version": 1,
    		 "public_key": "558cdba44e90f9354a6eae8436ff8a8161556b4bea6980baa9890a6536fe248e5f6a333c1dffa27fc529c67609a1345888176a77a969a700e442271ea792d847"
