Configure PWM driver to have similar behaviour as an Arduino analogWrite()
I'm interested in passing a PWM wave form to drive a motor using an Allegro A4963.
There exists an Arduino library that does just that and in order to set speed they perform an "analogWrite()" on a certain speed.
How do I use the PWM driver to implement the same behavior ?
PS: I'm using an nRF52840-DK
  • Following code seems to be doing the job:
    nrf_drv_pwm_config_t config =
            // These are the common configuration options we use for all PWM
            // instances.
            .irq_priority = APP_IRQ_PRIORITY_LOWEST,
            .count_mode   = NRF_PWM_MODE_UP,
            .step_mode    = NRF_PWM_STEP_AUTO,
    config.output_pins[0] = BSP_LED_0 | NRF_DRV_PWM_PIN_INVERTED;
    config.output_pins[1] = NRF_DRV_PWM_PIN_NOT_USED;
    config.output_pins[2] = NRF_DRV_PWM_PIN_NOT_USED;
    config.output_pins[3] = NRF_DRV_PWM_PIN_NOT_USED;
    config.base_clock     = NRF_PWM_CLK_125kHz;
    config.top_value      = 255;
    config.load_mode      = NRF_PWM_LOAD_COMMON;
    RETURN_ON_ERROR(nrf_drv_pwm_init(&m_pwm0, &config, NULL));
    // This array cannot be allocated on stack (hence "static") and it must
    // be in RAM (hence no "const", though its content is not changed).
    static nrf_pwm_values_common_t /*const*/ pwm0_seq_values[1];
    pwm0_seq_values[0] = value; // ** this is the value passed to "analogWrite()" **
    nrf_pwm_sequence_t const pwm0_seq =
    	.values.p_common  = pwm0_seq_values,
    	.length           = NRF_PWM_VALUES_LENGTH(pwm0_seq_values),
    	.repeats          = 1,
    	.end_delay        = 0
    nrf_drv_pwm_simple_playback(&m_pwm0, &pwm0_seq, 1, NRF_DRV_PWM_FLAG_LOOP);
  • Yes, it seems you got it about right.
    If you are looking for a simpler PWM, I would recommend that you peek into the "pwm_library" example as well. There you will basically have a function called app_pwm_channel_duty_set(), which takes a number from 0 to 100% where 0 would be GND and 100 would be VDD. This function is also easy to modify to use 1/1000 instead of 1/100 if you need higher accuracy.
    Edvin
