nRF52840 how to goto DFU when the softdevice has been disabled?
I have a system based on nRF52840 (SDK 15.0.0) where while running the application I can call the below code, and it will then restart in DFU secure mode to do a firmware upate. This all works great.
However I have a use-case where once running the app, the system will switch to Enhanced Shockburst mode so the softdevice is disabled. The code below no longer works probably because those 'sd_' functions won't work with the softdevice disabled.
Is there a way to modify the GPREGRET register and then call a system reset?
Basically I would like to goto the bootloader, but my normal do_dfu function below won't work because the softdevice is disabled. I tried starting ble / sd, but it crashes the device at that point.
Thanks
void do_dfu(void)
    uint32_t err_code;
    //NRF_LOG_DEBUG("In ble_dfu_buttonless_bootloader_start_finalize\r\n");
    err_code = sd_power_gpregret_clr(0, 0xffffffff);
    VERIFY_SUCCESS(err_code);
    err_code = sd_power_gpregret_set(0, BOOTLOADER_DFU_START);
    // Signal that DFU mode is to be enter to the power management module
    nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU);
    //return NRF_SUCCESS;
