I have been working with the thingy91 source code from ncs, I can compile and load the sample app successfully. However I did notice that when I compile the code it does not report the Air Quality from the BME680 sensor, while the out-of-the-box binary does.
After looking into the sample app, I notice that there is a function in env_sensors.c that is supposed to get the air quality measurement but it just return -1.
How am I supposed to configure the sample app in order to make it behave as the out of the box sample app?
Is the following configuration related to this?
project->configure nrf connect sdk project ->menu config-> asset tracker-> environment sensors->use bosh BME680 BSEC lib
I have enabled it... but it makes the project invalid...
I also have seen several posts that says that the driver library is: ncs\zephyr\drivers\sensor\bme680
however, adding those files to the asset tracker project cause an error of multiple definitions being found as it seems like the project already have a library added
Any help on how this sample apps are meant to be used as starting point to development is appreciated.
