I'm trying to integrate the light switch server example in nRF5 SDK for Mesh v4 with ble app beacon from the nRF5 SDK v16. I added the advertising_init and the advertising_start functions from the beacon example to the light switch server example. The firmware is correct and Segger can build successfully the project.
I saw that if the macro MESH_FEATURE_GATT_ENABLED is set, the RTT Viewer gave "app_error_weak.c, 119, Mesh error 4 at 0x000268F1" because there is a problem with sd_ble_gap_adv_set_configure.
#if MESH_FEATURE_GATT_ENABLED
gap_params_init();
conn_params_init();
If the macro MESH_FEATURE_GATT_ENABLED is zero, the firmware works well without any errors but the nRF Mesh mobile app can't find the board. I evaluate the firmware with two other boards, in one of them is flashed the light switch provisioner example and in the other one is flashed the client example. The three board work well and they successfully rum mesh and the server can also send beacon.
How can I make this work with nRF Mesh mobile app? I think there is a proxy problem but I don't know how to fix it.
Thanks.
