About the priority of multiple interrupts
SDK: 15.3.0
Device: EYSHJNZWZ (nRF52832)
I am using multiple interrupts.
For example, BLE communication interrupt and SOC interrupt.
I set the priority of each interrupt as follows.
#define		C_APP_SOC_OBSERVER_PRIO			1
#define		C_BLE_APP_BLE_OBSERVER_PRIO		3
NRF_SDH_SOC_OBSERVER(
						m_soc_observer,
						C_APP_SOC_OBSERVER_PRIO,
						e_soc_evt_handler,
						NULL
NRF_SDH_BLE_OBSERVER(
						m_ble_observer,
						C_BLE_APP_BLE_OBSERVER_PRIO,
						e_ble_evt_handler,
						NULL
Since the priority of the interrupt is different, I think that it will be a multiple interrupt.
When a high-priority interrupt occurs during a low-priority interrupt, the high-priority interrupt runs with priority.
Is my opinion correct?
Is it possible to disable or enable multiple interrupts?
     The _OBSERVER macro will inherit the interrupt priority of the interrupt vector that is set pending by the SoftDevice (SWI2 by default) in nrf_sdh.c::SD_EVT_IRQHandler.
    Each registered observer has a priority level in the case that several observers are registered to the same type, and one shall execute first (ie: a software implemented priority).
     As mentioned, these observers will inherit the interrupt level as the SD_EVT_IRQ runs in.
    You can disable interrupts if you'd like, but as you should not disable softdevice interrupts, you should use these macros instead which only disables application interrupts:
    CRITICAL_REGION_ENTER();
    critical_code();
    CRITICAL_REGION_EXIT();
    Håkon
  • Thank you for answering.
    I understood interrupt priority and how to disable interrupts.
    What about the above?
    Please tell me.
