UART, custom and AT commands
I have been trying to get UART working properly on my custom board but also on nRF9160 DK. I'm using only UART_0.
With CONFIG_USE_AT_HOST and without any uart code inside my own code, AT commands are working but if I wrote something else like "hi" to terminal, the device is giving a HARD FAULT.
hi
[0[00:01:23.622,528] [1B][1;31m<err> os: ***** HARD FAULT *****[1B][0m
[00:01:23.628,143] [1B][1;31m<err> os:   Fault escalation (see below)[1B][0m
[00:01:23.634,399] [1B][1;31m<err> os: ***** USAGE FAULT *****[1B][0m
[00:01:23.640,045] [1B][1;31m<err> os:   Stack overflow (context area not valid)[1B][0m
[00:01:23.647,216] [1B][1;31m<err> os: r0/a1:  0x2002c600  r1/a2:  0x00000001  r2/a3:  0x20027506[1B][0m
[00:01:23.655,883] [1B][1;31m<err> os: r3/a4:  0x2002c600 r12/ip:  0x000253a9 r14/lr:  0x000252f3[1B][0m
[00:01:23.664,550] [1B][1;31m<err> os:  xpsr:  0x00028e00[1B][0m
[00:01:23.669,769] [1B][1;31m<err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000[1B][0m
[00:01:23.680,175] [1B][1;31m<err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000[1B][0m
[00:01:23.690,612] [1B][1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000[1B][0m
[00:01:23.701,019] [1B][1;31m<err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000[1B][0m
[00:01:23.711,456] [1B][1;31m<err> os: fpscr:  0x000109b1[1B][0m
[00:01:23.716,674] [1B][1;31m<err> os: Faulting instruction address (r15/pc): 0x2002c600[1B][0m
[00:01:23.724,548] [1B][1;31m<err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0[1B][0m
[00:01:23.732,421] [1B][1;31m<err> os: Current thread: 0x200229b0 (unknown)[1B][0m
Running main.c error handlerError of type ERROR_SYSTEM_FAULT: 2
With uart code from https://github.com/Rallare/fw-nrfconnect-nrf/blob/nrf9160_samples/samples/nrf9160/uart/ inside my own code, I'm able to write whatever I want to terminal and it echoes that back from uart_cb(). But AT commands are NOT working, the code is understanding them as just similar text like "hi" and is echoing them back and not doing anything with the modem.
So, do you have any idea how should I make them work together? My goal is to give my own commands but also AT commands to the device with only one UART peripheral.
Tero
  • I am not able to recreate your error, could you share your code?
    Simon
  • I cleaned my code a little bit so there is not anything useless.
    Here is the prints of execution when uart_init() has been done in main.c:
    Flash region		Domain		Permissions
    00 0x00000 0x08000 	Secure		rwxl
    01 0x08000 0x10000 	Non-Secure	rwxl
    02 0x10000 0x18000 	Non-Secure	rwxl
    03 0x18000 0x20000 	Non-Secure	rwxl
    04 0x20000 0x28000 	Non-Secure	rwxl
    05 0x28000 0x30000 	Non-Secure	rwxl
    06 0x30000 0x38000 	Non-Secure	rwxl
    07 0x38000 0x40000 	Non-Secure	rwxl
    08 0x40000 0x48000 	Non-Secure	rwxl
    09 0x48000 0x50000 	Non-Secure	rwxl
    10 0x50000 0x58000 	Non-Secure	rwxl
    11 0x58000 0x60000 	Non-Secure	rwxl
    12 0x60000 0x68000 	Non-Secure	rwxl
    13 0x68000 0x70000 	Non-Secure	rwxl
    14 0x70000 0x78000 	Non-Secure	rwxl
    15 0x78000 0x80000 	Non-Secure	rwxl
    16 0x80000 0x88000 	Non-Secure	rwxl
    17 0x88000 0x90000 	Non-Secure	rwxl
    18 0x90000 0x98000 	Non-Secure	rwxl
    19 0x98000 0xa0000 	Non-Secure	rwxl
    20 0xa0000 0xa8000 	Non-Secure	rwxl
    21 0xa8000 0xb0000 	Non-Secure	rwxl
    22 0xb0000 0xb8000 	Non-Secure	rwxl
    23 0xb8000 0xc0000 	Non-Secure	rwxl
    24 0xc0000 0xc8000 	Non-Secure	rwxl
    25 0xc8000 0xd0000 	Non-Secure	rwxl
    26 0xd0000 0xd8000 	Non-Secure	rwxl
    27 0xd8000 0xe0000 	Non-Secure	rwxl
    28 0xe0000 0xe8000 	Non-Secure	rwxl
    29 0xe8000 0xf0000 	Non-Secure	rwxl
    30 0xf0000 0xf8000 	Non-Secure	rwxl
    31 0xf8000 0x100000 	Non-Secure	rwxl
    Non-secure callable region 0 placed in flash region 0 with size 32.
    SRAM region		Domain		Permissions
    00 0x00000 0x02000	Secure		rwxl
    01 0x02000 0x04000	Secure		rwxl
    02 0x04000 0x06000	Secure		rwxl
    03 0x06000 0x08000	Secure		rwxl
    04 0x08000 0x0a000	Secure		rwxl
    05 0x0a000 0x0c000	Secure		rwxl
    06 0x0c000 0x0e000	Secure		rwxl
    07 0x0e000 0x10000	Secure		rwxl
    08 0x10000 0x12000	Non-Secure	rwxl
    09 0x12000 0x14000	Non-Secure	rwxl
    10 0x14000 0x16000	Non-Secure	rwxl
    11 0x16000 0x18000	Non-Secure	rwxl
    12 0x18000 0x1a000	Non-Secure	rwxl
    13 0x1a000 0x1c000	Non-Secure	rwxl
    14 0x1c000 0x1e000	Non-Secure	rwxl
    15 0x1e000 0x20000	Non-Secure	rwxl
    16 0x20000 0x22000	Non-Secure	rwxl
    17 0x22000 0x24000	Non-Secure	rwxl
    18 0x24000 0x26000	Non-Secure	rwxl
    19 0x26000 0x28000	Non-Secure	rwxl
    20 0x28000 0x2a000	Non-Secure	rwxl
    21 0x2a000 0x2c000	Non-Secure	rwxl
    22 0x2c000 0x2e000	Non-Secure	rwxl
    23 0x2e000 0x30000	Non-Secure	rwxl
    24 0x30000 0x32000	Non-Secure	rwxl
    25 0x32000 0x34000	Non-Secure	rwxl
    26 0x34000 0x36000	Non-Secure	rwxl
    27 0x36000 0x38000	Non-Secure	rwxl
    28 0x38000 0x3a000	Non-Secure	rwxl
    29 0x3a000 0x3c000	Non-Secure	rwxl
    30 0x3c000 0x3e000	Non-Secure	rwxl
    31 0x3e000 0x40000	Non-Secure	rwxl
    Peripheral		Domain		Status
    00 NRF_P0               Non-Secure	OK
    01 NRF_CLOCK            Non-Secure	OK
    02 NRF_RTC1             Non-Secure	OK
    03 NRF_NVMC             Non-Secure	OK
    04 NRF_UARTE1           Non-Secure	OK
    05 NRF_UARTE2           Secure		SKIP
    06 NRF_TWIM2            Non-Secure	OK
    07 NRF_SPIM3            Non-Secure	OK
    08 NRF_TIMER0           Non-Secure	OK
    09 NRF_TIMER1           Non-Secure	OK
    10 NRF_TIMER2           Non-Secure	OK
    11 NRF_SAADC            Non-Secure	OK
    12 NRF_PWM0             Non-Secure	OK
    13 NRF_PWM1             Non-Secure	OK
    14 NRF_PWM2             Non-Secure	OK
    15 NRF_PWM3             Non-Secure	OK
    16 NRF_WDT              Secure		SKIP
    17 NRF_IPC              Non-Secure	OK
    18 NRF_VMC              Non-Secure	OK
    19 NRF_FPU              Non-Secure	OK
    20 NRF_EGU1             Non-Secure	OK
    21 NRF_EGU2             Non-Secure	OK
    22 NRF_DPPIC            Non-Secure	OK
    23 NRF_GPIOTE1          Non-Secure	OK
    24 NRF_REGULATORS       Non-Secure	OK
    SPM: NS image at 0xc000
    SPM: NS MSP at 0x200290a0
    SPM: NS reset vector at 0xf975
    SPM: prepare to jump to Non-Secure image.
    *** Booting Zephyr OS version 2.1.0  ***
    [00:00:00.191,253] [1B][0m<dbg> board_nonsecure.open_at_socket: AT socket opened[1B][0m
    [00:00:00.198,455] [1B][0m<dbg> board_nonsecure.deactivate_modemtrace: AT CMD: AT%XMODEMTRACE=0[1B][0m
    [00:00:00.214,019] [1B][0m<dbg> board_nonsecure.deactivate_modemtrace: AT RESP: OK
    [1B][0m
    [00:00:00.221,588] [1B][0m<dbg> board_nonsecure.check_modem_firmware: AT CMD: AT+CGMR[1B][0m
    [00:00:00.235,717] [1B][0m<dbg> board_nonsecure.check_modem_firmware: AT RESP: mfw_nrf9160_1.1.0
    OK
    [1B][0m
    [00:00:00.244,842] [1B][0m<dbg> board_nonsecure.check_modem_firmware: LATEST MODEM FW: mfw_nrf9160_1.1.0
    [1B][0m
    [00:00:00.254,241] [1B][0m<dbg> board_nonsecure.check_modem_firmware: CURRENT MODEM FW: mfw_nrf9160_1.1.0ù
    [1B][0m
    [00:00:00.263,793] [1B][0m<dbg> board_nonsecure.check_modem_firmware: You have the latest modem firmware.[1B][0m
    [00:00:00.273,162] [1B][0m<dbg> board_nonsecure.coex_configure: AT CMD: AT%XCOEX0=1,1,1574,1577[1B][0m
    [00:00:00.288,269] [1B][0m<dbg> board_nonsecure.coex_configure: AT RESP: OK
    [1B][0m
    [00:00:00.295,227] [1B][0m<dbg> board_nonsecure.coex_configure: COEX0 successfully configured[1B][0m
    UART application started!
    Initializing LTE network.
    LTE network initialized.
    AT%XTEMP?       //sent from terminal
    AT%XTEMP?       //response to terminal
    AT+CFUN?        //sent from terminal
    AT+CFUN?        //response to terminal
    hi              //sent from terminal
    hi              //response to terminal
    HEY             //sent from terminal
    HEY             //response to terminal
    Here is the prints of execution when uart_init() has been commented in main.c:
    SPM: NS MSP at 0x20028ca0
    SPM: NS reset vector at 0xf8f1
    [00:00:00.214,050] [1B][0m<dbg> board_nonsecure.deactivate_modemtrace: AT RESP: OK
    [1B][0m
    [00:00:00.235,748] [1B][0m<dbg> board_nonsecure.check_modem_firmware: AT RESP: mfw_nrf9160_1.1.0
    OK
    [1B][0m
    [00:00:00.244,873] [1B][0m<dbg> board_nonsecure.check_modem_firmware: LATEST MODEM FW: mfw_nrf9160_1.1.0
    [1B][0m
    [00:00:00.254,241] [1B][0m<dbg> board_nonsecure.check_modem_firmware: CURRENT MODEM FW: mfw_nrf9160_1.1.0ø
    [1B][0m
    [1B][0m
    +CFUN: 0        //response to terminal
    OK              //response to terminal
    %XTEMP: 23      //response to terminal
    [0[00:00:17.359,405] [1B][1;31m<err> os: ***** HARD FAULT *****[1B][0m
    [00:00:17.365,081] [1B][1;31m<err> os:   Fault escalation (see below)[1B][0m
    [00:00:17.371,337] [1B][1;31m<err> os: ***** USAGE FAULT *****[1B][0m
    [00:00:17.377,014] [1B][1;31m<err> os:   Stack overflow (context area not valid)[1B][0m
    [00:00:17.384,246] [1B][1;31m<err> os: r0/a1:  0x2002b5bc  r1/a2:  0x00000001  r2/a3:  0x20026564[1B][0m
    [00:00:17.392,944] [1B][1;31m<err> os: r3/a4:  0x2002b5bc r12/ip:  0x000213cf r14/lr:  0x00021319[1B][0m
    [00:00:17.401,672] [1B][1;31m<err> os:  xpsr:  0x00024400[1B][0m
    [00:00:17.406,921] [1B][1;31m<err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000[1B][0m
    [00:00:17.417,388] [1B][1;31m<err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000[1B][0m
    [00:00:17.427,886] [1B][1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000[1B][0m
    [00:00:17.438,354] [1B][1;31m<err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000[1B][0m
    [00:00:17.448,852] [1B][1;31m<err> os: fpscr:  0x0000ebb1[1B][0m
    [00:00:17.454,071] [1B][1;31m<err> os: Faulting instruction address (r15/pc): 0x2002b5bc[1B][0m
    [00:00:17.462,005] [1B][1;31m<err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0[1B][0m
    [00:00:17.469,909] [1B][1;31m<err> os: Current thread: 0x20021af0 (unknown)[1B][0m
    Here is the code of the UART project:
    0576.uart.rar
    Tero
  • In my case, the ETIMDEOUT comes from calling modem_connect() from main() as well as from debug_console.c→handle_custom_command()→modem_connect().
    Could you check again and see if the same is happening to you, just to make sure we are on the same page.
    Simon
  • Hi Simon,
    I checked it and it works when calling it from main(). Please notice that I'm using NB-IoT and no fallback.
    CONFIG_LTE_NETWORK_MODE_NBIOT=y
    CONFIG_LTE_NETWORK_USE_FALLBACK=n
    Tero
  • It seems like connecting to the modem from a work queue thread does not work. I haven't had time to get to the bottom of it, unfortunately. Have you made any progress yourself?
  • In this case I haven't. I don't know how to make the LTE LC work with UART commands so for now I have send AT+CFUN=1 to modem and then have sent data to server etc.
