Hi, team
I am using nRF5_SDK_15.3.0_59ac345/examples/ble_peripheral/ble_app_ancs_c sample application. and i wnated to add extra notification attribute.
added BLE_ANCS_KEY1 in this Enum ble_ancs_c_notif_attr_id_val_t.
/**@brief IDs for iOS notification attributes. */
typedef enum
BLE_ANCS_NOTIF_ATTR_ID_APP_IDENTIFIER = 0, /**< Identifies that the attribute data is of an "App Identifier" type. */
BLE_ANCS_NOTIF_ATTR_ID_TITLE, /**< Identifies that the attribute data is a "Title". */
BLE_ANCS_NOTIF_ATTR_ID_SUBTITLE, /**< Identifies that the attribute data is a "Subtitle". */
BLE_ANCS_NOTIF_ATTR_ID_MESSAGE, /**< Identifies that the attribute data is a "Message". */
BLE_ANCS_NOTIF_ATTR_ID_MESSAGE_SIZE, /**< Identifies that the attribute data is a "Message Size". */
BLE_ANCS_NOTIF_ATTR_ID_DATE, /**< Identifies that the attribute data is a "Date". */
BLE_ANCS_NOTIF_ATTR_ID_POSITIVE_ACTION_LABEL, /**< The notification has a "Positive action" that can be executed associated with it. */
BLE_ANCS_NOTIF_ATTR_ID_NEGATIVE_ACTION_LABEL, /**< The notification has a "Negative action" that can be executed associated with it. */
BLE_ANCS_KEY1,
} ble_ancs_c_notif_attr_id_val_t;
and also added "KEY1" to lit_attrid
/**@brief String literals for the iOS notification attribute types. Used when printing to UART. */
static char const * lit_attrid[BLE_ANCS_NB_OF_NOTIF_ATTR] =
"App Identifier",
"Title",
"Subtitle",
"Message",
"Message Size",
"Date",
"Positive Action Label",
"Negative Action Label"
"KEY1"
and added in service_init function
ret = nrf_ble_ancs_c_attr_add(&m_ancs_c,
BLE_ANCS_KEY1,
m_attr_negaction,
ATTR_DATA_SIZE);
APP_ERROR_CHECK(ret);
And I am sending push pay load
"title":"title",
"subtitle":"New Subtitle",
"key1":"Value1"
from the following site https://pushtry.com
and following printed in the serial monitor
<info> app: App Identifier: com.xcubelabs.demo
<info> app: Title: title
<info> app: Subtitle: New Subtitle
<info> app: Message: Body
<info> app: Message Size: 4
<info> app: Date: 20200113T
<info> app: Positive Action Label: (N/A)
<info> app: Negative Action LabelKEY1: Clear
<info> app: : (N/A)
But i didnt get that key value.
please help me out this problem. if any Example code snippets are availble please send to me .
The main file and header file is attached below
* Copyright (c) 2012 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_apple_notification_main main.c
* @ingroup ble_sdk_app_apple_notification
* @brief Apple Notification Client Sample Application main file. Disclaimer:
* This client implementation of the Apple Notification Center Service can and
* will be changed at any time by Nordic Semiconductor ASA.
* Server implementations such as the ones found in iOS can be changed at any
* time by Apple and may cause this client implementation to stop working.
* This file contains the source code for a sample application using the Apple
* Notification Center Service Client.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble_hci.h"
#include "ble_gap.h"
#include "ble_err.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "nrf_delay.h"
#include "app_scheduler.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "ble_db_discovery.h"
#include "nrf_ble_gatts_c.h"
#include "nrf_ble_ancs_c.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define ATTR_DATA_SIZE BLE_ANCS_ATTR_DATA_MAX /**< Allocated size for attribute data. */
#define DISPLAY_MESSAGE_BUTTON_ID 1 /**< Button used to request notification attributes. */
#define DEVICE_NAME "ANCS" /**< Name of the device. Will be included in the advertising data. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_FAST_INTERVAL 40 /**< The advertising interval (in units of 0.625 ms). The default value corresponds to 25 ms. */
#define APP_ADV_SLOW_INTERVAL 3200 /**< Slow advertising interval (in units of 0.625 ms). The default value corresponds to 2 seconds. */
#define APP_ADV_FAST_DURATION 3000 /**< The advertising duration of fast advertising in units of 10 milliseconds. */
#define APP_ADV_SLOW_DURATION 18000 /**< The advertising duration of slow advertising in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(500, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(1000, UNIT_1_25_MS) /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating an event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define MESSAGE_BUFFER_SIZE 18 /**< Size of buffer holding optional messages in notifications. */
#define SECURITY_REQUEST_DELAY APP_TIMER_TICKS(1500) /**< Delay after connection until security request is sent, if necessary (ticks). */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump. Can be used to identify stack location on stack unwind. */
#define SCHED_MAX_EVENT_DATA_SIZE APP_TIMER_SCHED_EVENT_DATA_SIZE /**< Maximum size of scheduler events. */
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SCHED_QUEUE_SIZE 20 /**< Maximum number of events in the scheduler queue. More is needed in case of Serialization. */
#else
#define SCHED_QUEUE_SIZE 10 /**< Maximum number of events in the scheduler queue. */
NRF_BLE_GATTS_C_DEF(m_gatts_c); /**< GATT Service client instance. Handles Service Changed indications from the peer. */
BLE_ANCS_C_DEF(m_ancs_c); /**< Apple Notification Service Client instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB Discovery module instance. */
static pm_peer_id_t m_whitelist_peers[BLE_GAP_WHITELIST_ADDR_MAX_COUNT]; /**< List of peers currently in the whitelist. */
static uint32_t m_whitelist_peer_cnt; /**< Number of peers currently in the whitelist. */
static uint16_t m_cur_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static ble_gatt_db_srv_t m_peer_srv_buf[2] = {0}; /**< Array of services with room to store both GATT Service and ANCS. */
static bool m_ancs_discovered = false; /**< Bool to keep track of when both ancs and gatts have been disovered. Only then do we want to save the peer data. */
static bool m_gatts_discovered = false; /**< Bool to keep track of when both ancs and gatts have been disovered. Only then do we want to save the peer data. */
static ble_ancs_c_evt_notif_t m_notification_latest; /**< Local copy to keep track of the newest arriving notifications. */
static ble_ancs_c_attr_t m_notif_attr_latest; /**< Local copy of the newest notification attribute. */
static ble_ancs_c_attr_t m_notif_attr_app_id_latest; /**< Local copy of the newest app attribute. */
static uint8_t m_attr_appid[ATTR_DATA_SIZE]; /**< Buffer to store attribute data. */
static uint8_t m_attr_title[ATTR_DATA_SIZE]; /**< Buffer to store attribute data. */
static uint8_t m_attr_subtitle[ATTR_DATA_SIZE]; /**< Buffer to store attribute data. */
static uint8_t m_attr_message[ATTR_DATA_SIZE]; /**< Buffer to store attribute data. */
static uint8_t m_attr_message_size[ATTR_DATA_SIZE]; /**< Buffer to store attribute data. */
static uint8_t m_attr_date[ATTR_DATA_SIZE]; /**< Buffer to store attribute data. */
static uint8_t m_attr_posaction[ATTR_DATA_SIZE]; /**< Buffer to store attribute data. */
static uint8_t m_attr_negaction[ATTR_DATA_SIZE]; /**< Buffer to store attribute data. */
static uint8_t m_attr_disp_name[ATTR_DATA_SIZE]; /**< Buffer to store attribute data. */
/**@brief String literals for the iOS notification categories. used then printing to UART. */
static char const * lit_catid[BLE_ANCS_NB_OF_CATEGORY_ID] =
"Other",
"Incoming Call",
"Missed Call",
"Voice Mail",
"Social",
"Schedule",
"Email",
"News",
"Health And Fitness",
"Business And Finance",
"Location",
"Entertainment"
/**@brief String literals for the iOS notification event types. Used then printing to UART. */
static char const * lit_eventid[BLE_ANCS_NB_OF_EVT_ID] =
"Added",
"Modified",
"Removed"
"App Identifier",
"Title",
"Subtitle",
"Message",
"Message Size",
"Date",
"KEY1"
/**@brief String literals for the iOS notification attribute types. Used When printing to UART. */
static char const * lit_appid[BLE_ANCS_NB_OF_APP_ATTR] =
"Display Name"
static void delete_bonds(void);
/**@brief Callback function for handling asserts in the SoftDevice.
* @details This function is called in case of an assert in the SoftDevice.
* @warning This handler is an example only and does not fit a final product.
* You must analyze how your product should react to asserts.
* @warning On assert from the SoftDevice, the system can recover only on reset.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Fetch the list of peer manager peer IDs.
* @param[inout] p_peers The buffer where to store the list of peer IDs.
* @param[inout] p_size In: The size of the @p p_peers buffer.
* Out: The number of peers copied in the buffer.
static void peer_list_get(pm_peer_id_t * p_peers, uint32_t * p_size)
pm_peer_id_t peer_id;
uint32_t peers_to_copy;
peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ?
*p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
*p_size = 0;
while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--))
p_peers[(*p_size)++] = peer_id;
peer_id = pm_next_peer_id_get(peer_id);
/**@brief Function for starting advertising. */
static void advertising_start(bool erase_bonds)
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
ret_code_t ret;
memset(m_whitelist_peers, PM_PEER_ID_INVALID, sizeof(m_whitelist_peers));
m_whitelist_peer_cnt = (sizeof(m_whitelist_peers) / sizeof(pm_peer_id_t));
peer_list_get(m_whitelist_peers, &m_whitelist_peer_cnt);
ret = pm_whitelist_set(m_whitelist_peers, m_whitelist_peer_cnt);
// Setup the device identies list.
// Some SoftDevices do not support this feature.
ret = pm_device_identities_list_set(m_whitelist_peers, m_whitelist_peer_cnt);
if (ret != NRF_ERROR_NOT_SUPPORTED)
ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
ret_code_t ret;
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
case PM_EVT_BONDED_PEER_CONNECTED:
if (p_evt->peer_id != PM_PEER_ID_INVALID)
uint16_t data_len = sizeof(m_peer_srv_buf);
ret = pm_peer_data_remote_db_load(p_evt->peer_id, m_peer_srv_buf, &data_len);
if (ret == NRF_ERROR_NOT_FOUND)
NRF_LOG_DEBUG("Could not find the remote database in flash.");
ret = nrf_ble_gatts_c_handles_assign(&m_gatts_c, p_evt->conn_handle, NULL);
// Discover peer's services.
memset(&m_db_disc, 0x00, sizeof(m_db_disc));
ret = ble_db_discovery_start(&m_db_disc, p_evt->conn_handle);
// Check if the load was successful.
ASSERT(data_len == sizeof(m_peer_srv_buf));
NRF_LOG_INFO("Remote Database loaded from flash.");
// Assign the loaded handles to the GATT Service client module.
ble_gatt_db_char_t srv_changed_handles = m_peer_srv_buf[0].charateristics[0];
p_evt->conn_handle,
&srv_changed_handles);
// Enable indications.
ret = nrf_ble_gatts_c_enable_indication(&m_gatts_c, true);
//Load the relevant handles into a ble_ancs_c_service_t struct that can be
// assigned to the ANCS module.
ble_ancs_c_service_t ancs_handles;
ble_gatt_db_char_t * p_char = m_peer_srv_buf[1].charateristics;
ancs_handles.control_point_char = p_char[0].characteristic;
ancs_handles.notif_source_char = p_char[1].characteristic;
ancs_handles.notif_source_cccd.handle = p_char[1].cccd_handle;
ancs_handles.data_source_char = p_char[2].characteristic;
ancs_handles.data_source_cccd.handle = p_char[2].cccd_handle;
ret = nrf_ble_ancs_c_handles_assign(&m_ancs_c, p_evt->conn_handle,
&ancs_handles);
} break;
case PM_EVT_CONN_SEC_SUCCEEDED:
// Check it the Service Changed characteristic handle exists in our client instance.
// If it is invalid, we know service discovery is needed.
// (No database was loaded during @ref PM_EVT_BONDED_PEER_CONNECTED)
if (m_gatts_c.srv_changed_char.characteristic.handle_value == BLE_GATT_HANDLE_INVALID)
} break;
advertising_start(false);
} break;
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
// Note: You should check on what kind of white list policy your application should use.
if ( p_evt->params.peer_data_update_succeeded.flash_changed
&& (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
NRF_LOG_DEBUG("New Bond, add the peer to the whitelist if possible");
NRF_LOG_DEBUG("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
m_whitelist_peer_cnt + 1,
BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
if (m_whitelist_peer_cnt < BLE_GAP_WHITELIST_ADDR_MAX_COUNT)
// Bonded to a new peer, add it to the whitelist.
m_whitelist_peers[m_whitelist_peer_cnt++] = p_evt->peer_id;
// The whitelist has been modified, update it in the Peer Manager.
} break;
/**@brief Function for setting up GATTC notifications from the Notification Provider.
* @details This function is called when a successful connection has been established.
static void apple_notification_setup(void)
ret_code_t ret;
nrf_delay_ms(100); // Delay because we cannot add a CCCD to close to starting encryption. iOS specific.
ret = ble_ancs_c_notif_source_notif_enable(&m_ancs_c);
ret = ble_ancs_c_data_source_notif_enable(&m_ancs_c);
NRF_LOG_DEBUG("Notifications Enabled.");
/**@brief Function for printing an iOS notification.
* @param[in] p_notif Pointer to the iOS notification.
static void notif_print(ble_ancs_c_evt_notif_t * p_notif)
NRF_LOG_INFO("\r\nNotification");
NRF_LOG_INFO("Event: %s", (uint32_t)lit_eventid[p_notif->evt_id]);
NRF_LOG_INFO("Category ID: %s", (uint32_t)lit_catid[p_notif->category_id]);
NRF_LOG_INFO("Category Cnt:%u", (unsigned int) p_notif->category_count);
NRF_LOG_INFO("UID: %u", (unsigned int) p_notif->notif_uid);
NRF_LOG_INFO("Flags:");
if (p_notif->evt_flags.silent == 1)
NRF_LOG_INFO(" Silent");
if (p_notif->evt_flags.important == 1)
NRF_LOG_INFO(" Important");
if (p_notif->evt_flags.pre_existing == 1)
NRF_LOG_INFO(" Pre-existing");
if (p_notif->evt_flags.positive_action == 1)
NRF_LOG_INFO(" Positive Action");
if (p_notif->evt_flags.negative_action == 1)
NRF_LOG_INFO(" Negative Action");
/**@brief Function for printing iOS notification attribute data.
* @param[in] p_attr Pointer to an iOS notification attribute.
static void notif_attr_print(ble_ancs_c_attr_t * p_attr)
if (p_attr->attr_len != 0)
NRF_LOG_INFO("%s: %s", (uint32_t)lit_attrid[p_attr->attr_id],
nrf_log_push((char *)p_attr->p_attr_data));
else if (p_attr->attr_len == 0)
NRF_LOG_INFO("%s: (N/A)", (uint32_t)lit_attrid[p_attr->attr_id]);
* @param[in] p_attr Pointer to an iOS App attribute.
static void app_attr_print(ble_ancs_c_attr_t * p_attr)
NRF_LOG_INFO("%s: %s", (uint32_t)lit_appid[p_attr->attr_id], (uint32_t)p_attr->p_attr_data);
NRF_LOG_INFO("%s: (N/A)", (uint32_t) lit_appid[p_attr->attr_id]);
/**@brief Function for printing out errors that originated from the Notification Provider (iOS).
* @param[in] err_code_np Error code received from NP.
static void err_code_print(uint16_t err_code_np)
switch (err_code_np)
case BLE_ANCS_NP_UNKNOWN_COMMAND:
NRF_LOG_INFO("Error: Command ID was not recognized by the Notification Provider. ");
case BLE_ANCS_NP_INVALID_COMMAND:
NRF_LOG_INFO("Error: Command failed to be parsed on the Notification Provider. ");
case BLE_ANCS_NP_INVALID_PARAMETER:
NRF_LOG_INFO("Error: Parameter does not refer to an existing object on the Notification Provider. ");
case BLE_ANCS_NP_ACTION_FAILED:
NRF_LOG_INFO("Error: Perform Notification Action Failed on the Notification Provider. ");
/**@brief Function for initializing the timer module.
static void timers_init(void)
ret_code_t ret;
ret = app_timer_init();
/**@brief Function for handling events from the GATT Servive client module.
@param[in] p_evt GATT Service event.
static void gatts_c_evt_handler(nrf_ble_gatts_c_evt_t * p_evt)
ret_code_t ret = NRF_SUCCESS;
switch (p_evt->evt_type)
case NRF_BLE_GATTS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_DEBUG("GATT Service and Service Changed characteristic found on server.");
p_evt->conn_handle,
&p_evt->params.srv_changed_char);
ret = pm_peer_id_get(p_evt->conn_handle, &peer_id);
memset(&m_peer_srv_buf[0], 0, sizeof(m_peer_srv_buf[0]));
m_peer_srv_buf[0].charateristics[0] = p_evt->params.srv_changed_char;
m_gatts_discovered = true;
if(m_gatts_discovered && m_ancs_discovered)
ret = pm_peer_data_remote_db_store(peer_id,
(ble_gatt_db_srv_t *)m_peer_srv_buf,
sizeof(m_peer_srv_buf),
NULL);
if (ret == NRF_ERROR_STORAGE_FULL)
ret = fds_gc();
} break;
case NRF_BLE_GATTS_C_EVT_DISCOVERY_FAILED:
NRF_LOG_DEBUG("GATT Service or Service Changed characteristic not found on server.");
case NRF_BLE_GATTS_C_EVT_DISCONN_COMPLETE:
NRF_LOG_DEBUG("GATTS Service client disconnected connection handle %i.",
case NRF_BLE_GATTS_C_EVT_SRV_CHANGED:
NRF_LOG_DEBUG("Service Changed indication received.");
/**@brief Function for handling the Apple Notification Service client.
* @details This function is called for all events in the Apple Notification client that
* are passed to the application.
* @param[in] p_evt Event received from the Apple Notification Service client.
static void ancs_c_evt_handler(ble_ancs_c_evt_t * p_evt)
case BLE_ANCS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_DEBUG("Apple Notification Center Service discovered on the server.");
ret = nrf_ble_ancs_c_handles_assign(&m_ancs_c, p_evt->conn_handle, &p_evt->service);
// Copy the needed ANCS handles into a ble_gatt_db_srv_t struct that will be stored in
// flash.
memset(&m_peer_srv_buf[1], 0, sizeof(m_peer_srv_buf[1]));
p_char[0].characteristic = p_evt->service.control_point_char;
p_char[1].characteristic = p_evt->service.notif_source_char;
p_char[1].cccd_handle = p_evt->service.notif_source_cccd.handle;
p_char[2].characteristic = p_evt->service.data_source_char;
p_char[2].cccd_handle = p_evt->service.data_source_cccd.handle;
m_ancs_discovered = true;
if (m_gatts_discovered && m_ancs_discovered)
NULL);
ret = fds_gc();
apple_notification_setup();
} break;
case BLE_ANCS_C_EVT_NOTIF:
m_notification_latest = p_evt->notif;
notif_print(&m_notification_latest);
case BLE_ANCS_C_EVT_NOTIF_ATTRIBUTE:
m_notif_attr_latest = p_evt->attr;
notif_attr_print(&m_notif_attr_latest);
if (p_evt->attr.attr_id == BLE_ANCS_NOTIF_ATTR_ID_APP_IDENTIFIER)
m_notif_attr_app_id_latest = p_evt->attr;
case BLE_ANCS_C_EVT_DISCOVERY_FAILED:
NRF_LOG_DEBUG("Apple Notification Center Service not discovered on the server.");
case BLE_ANCS_C_EVT_APP_ATTRIBUTE:
app_attr_print(&p_evt->attr);
case BLE_ANCS_C_EVT_NP_ERROR:
err_code_print(p_evt->err_code_np);
// No implementation needed.
/**@brief Function for initializing GAP connection parameters.
* @details Use this function to set up all necessary GAP (Generic Access Profile)
* parameters of the device. It also sets the permissions and appearance.
ret_code_t ret;
ble_gap_conn_params_t gap_conn_params;
ret = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
ret = sd_ble_gap_ppcp_set(&gap_conn_params);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t ret = nrf_ble_gatt_init(&m_gatt, NULL);
/**@brief Function for handling the Apple Notification Service client errors.
* @param[in] nrf_error Error code containing information about what went wrong.
static void apple_notification_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling a Connection Parameters error.
ret_code_t ret;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = true;
cp_init.evt_handler = NULL;
cp_init.error_handler = conn_params_error_handler;
ret = ble_conn_params_init(&cp_init);
/**@brief Function for handling Database Discovery events.
* @details This function is a callback function to handle events from the database discovery
* module. Depending on the UUIDs that are discovered, this function should forward the
* events to their respective service instances.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_ancs_c_on_db_disc_evt(&m_ancs_c, p_evt);
nrf_ble_gatts_c_on_db_disc_evt(&m_gatts_c, p_evt);
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
ret_code_t ret;
ret = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
ret = pm_sec_params_set(&sec_param);
ret = pm_register(pm_evt_handler);
* @brief Delete all data stored for all peers.
ret_code_t err_code;
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
uint32_t ret = bsp_indication_set(BSP_INDICATE_IDLE);
// Prepare wakeup buttons.
ret = bsp_btn_ble_sleep_mode_prepare();
ret = sd_power_system_off();
* @details This function is called for advertising events that are passed to the application.
* @param[in] ble_adv_evt Advertising event.
ret_code_t ret;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising");
ret = bsp_indication_set(BSP_INDICATE_ADVERTISING);
case BLE_ADV_EVT_SLOW:
NRF_LOG_INFO("Slow advertising");
ret = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
case BLE_ADV_EVT_FAST_WHITELIST:
NRF_LOG_INFO("Fast advertising with Whitelist");
ret = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
case BLE_ADV_EVT_WHITELIST_REQUEST:
ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
ble_gap_irk_t whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
uint32_t addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
uint32_t irk_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
ret = pm_whitelist_get(whitelist_addrs, &addr_cnt, whitelist_irks, &irk_cnt);
NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
addr_cnt,
irk_cnt);
// Apply the whitelist.
ret = ble_advertising_whitelist_reply(&m_advertising,
whitelist_addrs,
addr_cnt,
whitelist_irks,
irk_cnt);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
pm_handler_secure_on_connection(p_ble_evt);
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
ret = bsp_indication_set(BSP_INDICATE_CONNECTED);
m_cur_conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
ret = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_cur_conn_handle);
NRF_LOG_INFO("Disconnected.");
if (p_ble_evt->evt.gap_evt.conn_handle == m_ancs_c.conn_handle)
m_ancs_c.conn_handle = BLE_CONN_HANDLE_INVALID;
break; // BLE_GAP_EVT_DISCONNECTED
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
ret = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys);
} break;
case BLE_GATTC_EVT_TIMEOUT:
ret = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle,
case BLE_GATTS_EVT_TIMEOUT:
ret = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle,
* @param[in] event Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
ret_code_t ret;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
ret = sd_ble_gap_disconnect(m_cur_conn_handle,
if (ret != NRF_ERROR_INVALID_STATE)
case BSP_EVENT_WHITELIST_OFF:
if (m_ancs_c.conn_handle == BLE_CONN_HANDLE_INVALID)
ret = ble_advertising_restart_without_whitelist(&m_advertising);
case BSP_EVENT_KEY_0:
ret = nrf_ble_ancs_c_request_attrs(&m_ancs_c, &m_notification_latest);
case BSP_EVENT_KEY_1:
if (m_notif_attr_app_id_latest.attr_id == BLE_ANCS_NOTIF_ATTR_ID_APP_IDENTIFIER
&& m_notif_attr_app_id_latest.attr_len != 0)
NRF_LOG_INFO("Request for %s: ", (uint32_t)m_notif_attr_app_id_latest.p_attr_data);
ret = nrf_ble_ancs_c_app_attr_request(&m_ancs_c,
m_notif_attr_app_id_latest.p_attr_data,
m_notif_attr_app_id_latest.attr_len);
case BSP_EVENT_KEY_2:
if (m_notification_latest.evt_flags.positive_action == true)
NRF_LOG_INFO("Performing Positive Action.");
ret = nrf_ancs_perform_notif_action(&m_ancs_c,
m_notification_latest.notif_uid,
ACTION_ID_POSITIVE);
case BSP_EVENT_KEY_3:
if (m_notification_latest.evt_flags.negative_action == true)
NRF_LOG_INFO("Performing Negative Action.");
ACTION_ID_NEGATIVE);
uint32_t ram_start = 0;
// Enable BLE stack.
* application about an error.
ret_code_t ret;
ble_ancs_c_init_t ancs_c_init;
nrf_ble_gatts_c_init_t gatts_c_init;
ret = nrf_ble_qwr_init(&m_qwr, &qwr_init);
// Init the GATTS client module.
memset(&gatts_c_init, 0, sizeof(gatts_c_init));
gatts_c_init.evt_handler = gatts_c_evt_handler;
ret = nrf_ble_gatts_c_init(&m_gatts_c, &gatts_c_init);
// Init the Apple Notification Center Service client module.
memset(&ancs_c_init, 0, sizeof(ancs_c_init));
BLE_ANCS_NOTIF_ATTR_ID_APP_IDENTIFIER,
m_attr_appid,
ATTR_DATA_SIZE);
ret = nrf_ble_ancs_c_app_attr_add(&m_ancs_c,
BLE_ANCS_APP_ATTR_ID_DISPLAY_NAME,
m_attr_disp_name,
sizeof(m_attr_disp_name));
m_attr_title,
ATTR_DATA_SIZE);
m_attr_message,
ATTR_DATA_SIZE);
m_attr_subtitle,
ATTR_DATA_SIZE);
m_attr_message_size,
ATTR_DATA_SIZE);
m_attr_date,
ATTR_DATA_SIZE);
m_attr_posaction,
ATTR_DATA_SIZE);
m_attr_negaction,
ATTR_DATA_SIZE);
BLE_ANCS_KEY1,
m_attr_negaction,
ATTR_DATA_SIZE);
ancs_c_init.evt_handler = ancs_c_evt_handler;
ancs_c_init.error_handler = apple_notification_error_handler;
ret = ble_ancs_c_init(&m_ancs_c, &ancs_c_init);
/**@brief Function for initializing the advertising functionality.
ret_code_t ret;
ble_advertising_init_t init;
static ble_uuid_t m_adv_uuids[1]; /**< Universally unique service identifiers. */
m_adv_uuids[0].uuid = ANCS_UUID_SERVICE;
m_adv_uuids[0].type = m_ancs_c.service.service.uuid.type;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = 0;
init.advdata.uuids_complete.p_uuids = NULL;
init.advdata.uuids_solicited.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_solicited.p_uuids = m_adv_uuids;
init.config.ble_adv_whitelist_enabled = true;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_interval = APP_ADV_FAST_INTERVAL;
init.config.ble_adv_fast_timeout = APP_ADV_FAST_DURATION;
init.config.ble_adv_slow_enabled = true;
init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
init.config.ble_adv_slow_timeout = APP_ADV_SLOW_DURATION;
ret = ble_advertising_init(&m_advertising, &init);
/**@brief Function for initializing buttons and LEDs.
* @param[out] p_erase_bonds True if the clear bonds button was pressed to wake the application up.
uint32_t ret;
bsp_event_t startup_event;
ret = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
ret = bsp_btn_ble_init(NULL, &startup_event);
/**@brief Function for initializing the Event Scheduler.
static void scheduler_init(void)
APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
/**@brief Function for initializing the database discovery module.
static void db_discovery_init(void)
ret_code_t ret = ble_db_discovery_init(db_disc_handler);
static void log_init(void)
ret_code_t ret = NRF_LOG_INIT(NULL);
app_sched_execute();
nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize.
log_init();
timers_init();
scheduler_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
db_discovery_init();
services_init();
advertising_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Apple Notification Center Service client example started.");
advertising_start(erase_bonds);
// Enter main loop.
for (;;)
idle_state_handle();
We look forward to your inputs.
We appreciate your quick response on this.
Thank you.
