We are using regular RIGADO/U-BLOX modules (BMD300 and BMD350).
Do we need to pass PTS tests when we use Bluetooth layers (Softdevice S132_nrf52_5.1.0) with customs services and characteristics UUID128 ?
Hi Maxime, just to make sure I understand what you are asking: Are you asking if you need to run PTS tests for a proprietary service that you have implemented on top of the Nordic Softdevice?
Yes, it is.
Hi Maxime, there is no need to run PTS tests for you then. PTS testing would only be required if you were using a Bluetooth defined profile/service on top or the SoftDevice.
Thanks a lot for your support :-)
no problem and good luck with your projects
