APP_BUTTON library Can be used with external GPIO interrupt?
Good day!
Problem statement:
TSM12 Capacitive touch sensor IC (I2C com supported) is used in our application. It has got 12 output channels and Channel 1 is a parallel output port (It can be read over I2C or it can be connected directly to the GPIO pin).  We used this Channel 1 as a Touch button input and other channels as a wheel sensor. We tried building this with GPIOTE events but this one is a power-hungry method (Also this requires fine-tuning of the debounce effect). Now, I read that the app_button library uses less power and also deals with the button debounce effect.
Query:
Can we use this Capacitive touch sensor Interrupt PIN on nRF52832(on any of the GPIO pins) with the app_button library and be able to disable other Buttons interrupts?  FYI, The soft device is used in our application.
Thank you,
AimHigh
