Using own application repo
Hi!
I am trying to use my own repo like described in the tutorial https://devzone.nordicsemi.com/nordic/cellular-iot-guides/b/getting-started-cellular/posts/nrf-connect-sdk-tutorial
Everything works fine if I compile stuff that is in the "samples" folder inside the ncs/nrf
I tried to copy one of the sample applications (for example the mqtt_simple" to ncs/applications_test/mqtt_simple and tried to compile with west
west build -b nrf9160_pca10090ns
The build process stops with an error (without any hint what went wrong):
CMake Warning at C:/nrf91/ncs/zephyr/CMakeLists.txt:28 (message):
ZEPHYR_BASE doesn't match CMAKE_CURRENT_SOURCE_DIR
ZEPHYR_BASE = c:/nrf91/ncs/zephyr
PWD = c:/nrf91/ncs/applications_test/mqtt_simple
CMAKE_CURRENT_SOURCE_DIR = C:/nrf91/ncs/zephyr
You may be using a mix of symbolic links and real paths which causes subtle
and hard to debug CMake issues.
See also "C:/nrf91/ncs/applications_test/mqtt_simple/build/CMakeFiles/CMakeOutput.log".
See also "C:/nrf91/ncs/applications_test/mqtt_simple/build/CMakeFiles/CMakeError.log".
ERROR: command exited with status 1: 'c:\Program Files\CMake\bin\cmake.EXE' '-Bc:\nrf91\ncs\applications_test\mqtt_simple\build' '-Sc:\nrf91\ncs\applications_test\mqtt_simple' -GNinja -DBOARD=nrf9160_pca10090
Can you give me a hint what I need to do or configure to have applications outside the ncs repo?
  • Hi.
    The "C" in your ZEPHYR_BASE is lower case, while the one in the CMAKE_CURRENT_SOURCE_DIR is upper case. This confuses the build script.
    If it is set by you running the zephyr-env.cmd script, either do it from inside the zephyr/scripts folder or by having an upper case "C" in the path to the script.
    Didrik
  • Hi!
    Thanks for your help.
    I tried the hello_world example. This works fine.
    When building the mqtt_simple it says the following:
    -- west build: build configuration:
           source directory: C:\nrf91\ncs\applications_test\mqtt_simple
           build directory: C:\nrf91\ncs\applications_test\mqtt_simple\build (created)
           BOARD: nrf9160_pca10090ns (origin: command line)
    CMake Error at CMakeLists.txt:9 (include):
      include could not find load file:
        ../../../cmake/boilerplate.cmake
    -- Using application from 'C:/nrf91/ncs/applications_test/mqtt_simple'
    Zephyr version: 2.0.99
    -- Found PythonInterp: C:/Python37/python.exe (found suitable version "3.7.2", minimum required is "3.4")
    -- Selected BOARD nrf9160_pca10090ns
    -- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.6.3", minimum required is "0.6.0")
    -- Cache files will be written to: C:\Users\UJDF716\AppData\Local/.cache/zephyr
    -- Loading C:/nrf91/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
    -- Overlaying C:/nrf91/ncs/zephyr/dts/common/common.dts
    Devicetree configuration written to C:/nrf91/ncs/applications_test/mqtt_simple/build/zephyr/include/generated/generated_dts_board.conf
    warning: TEST_RANDOM_GENERATOR (defined at subsys/random/Kconfig:8) was assigned the value 'y' but
    got the value 'n'. You can check symbol information (including dependencies) in the 'menuconfig'
    interface (see the Application Development Primer section of the manual), or in the Kconfig
    reference at
    http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_TEST_RANDOM_GENERATOR.html (which is
    updated regularly from the master branch). See the 'Setting configuration values' section of the
    Board Porting Guide as well.
    Parsing Kconfig tree in C:/nrf91/ncs/applications_test/mqtt_simple/Kconfig
    Loaded configuration 'C:/nrf91/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns_defconfig'
    Merged configuration 'C:/nrf91/ncs/applications_test/mqtt_simple/prj.conf'
    Configuration saved to 'C:/nrf91/ncs/applications_test/mqtt_simple/build/zephyr/.config'
    -- The C compiler identification is GNU 7.3.1
    -- The CXX compiler identification is GNU 7.3.1
    -- Found assembler: C:/gnuarmemb/bin/arm-none-eabi-gcc.exe
    -- Using application from 'C:/nrf91/ncs/nrf/samples/nrf9160/spm'
    Changed board to secure nrf9160_pca10090 (NOT NS)
    USING OUT OF TREE BOARD
    -- Loading C:/nrf91/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
    -- Overlaying C:/nrf91/ncs/nrf/samples/nrf9160/spm/nrf9160_pca10090.overlay
    Devicetree configuration written to C:/nrf91/ncs/applications_test/mqtt_simple/build/spm/zephyr/include/generated/generated_dts_board.conf
    Parsing Kconfig tree in C:/nrf91/ncs/zephyr/Kconfig
    Loaded configuration 'C:/nrf91/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090_defconfig'
    Merged configuration 'C:/nrf91/ncs/nrf/samples/nrf9160/spm/prj.conf'
    Configuration saved to 'C:/nrf91/ncs/applications_test/mqtt_simple/build/spm/zephyr/.config'
    Running Partition Manager...
    ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' '-BC:\nrf91\ncs\applications_test\mqtt_simple\build' '-SC:\nrf91\ncs\applications_test\mqtt_simple' -GNinja -DBOARD=nrf9160_pca10090ns
    It seems like there is a relative path to cmake/boilerplate.cmake in the CMakeLists.txt
    include(../../../cmake/boilerplate.cmake NO_POLICY_SCOPE)
    I set it manually to the correct path
    include(C:/nrf91/ncs/nrf/cmake/boilerplate.cmake NO_POLICY_SCOPE)
    Then it builds.
    Can you tell me what the correct environment variable would be to avoid absolute path?
