PCA10040e and s113 bootloader
Hello I am trying to add OTA update functionality to my device which is running the nrf52810 micro with the s113 softdevice. Currently I am trying to convert the PCA10040e/s112 bootloader example to the s113 softdevice however I am running into the device being completely unresponsive after flashing it. Note: I am just flashing the bootloader hex and the softdevice hex.
I changed all the headers in the armgcc/makefile and tried different combinations of RAM/FLASH placement based on the other boot loader examples however I wasn't able to get the boot loader to successfully start advertising. I suspect the culprit is the flash/ram placements in the .ld file however I don't know where to find the correct values to place! If anyone can tell me what I should be doing to get this working, I would appreciate it!
Here is my .ld file,(I cant seem to upload the makefile, this editor isn't accepting it for some reason).
secure_bootloader_gcc_nrf52.ld
  • So i had to convert the makefile to a txt to post it, so here it is
    PROJECT_NAME     := secure_bootloader_ble_s113_pca10040e
    TARGETS          := nrf52810_xxaa_s113
    OUTPUT_DIRECTORY := _build
    SDK_ROOT := ../../../../..
    PROJ_DIR := ../..
    $(OUTPUT_DIRECTORY)/nrf52810_xxaa_s113.out: \
      LINKER_SCRIPT  := secure_bootloader_gcc_nrf52.ld
    # Source files common to all targets
    SRC_FILES += \
      $(SDK_ROOT)/modules/nrfx/mdk/gcc_startup_nrf52810.S \
      $(SDK_ROOT)/modules/nrfx/mdk/system_nrf52810.c \
      $(SDK_ROOT)/components/libraries/util/app_error_weak.c \
      $(SDK_ROOT)/components/libraries/scheduler/app_scheduler.c \
      $(SDK_ROOT)/components/libraries/util/app_util_platform.c \
      $(SDK_ROOT)/components/libraries/crc32/crc32.c \
      $(SDK_ROOT)/components/libraries/mem_manager/mem_manager.c \
      $(SDK_ROOT)/components/libraries/util/nrf_assert.c \
      $(SDK_ROOT)/components/libraries/atomic_fifo/nrf_atfifo.c \
      $(SDK_ROOT)/components/libraries/atomic/nrf_atomic.c \
      $(SDK_ROOT)/components/libraries/balloc/nrf_balloc.c \
      $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage.c \
      $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage_nvmc.c \
      $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage_sd.c \
      $(SDK_ROOT)/components/libraries/queue/nrf_queue.c \
      $(SDK_ROOT)/components/libraries/ringbuf/nrf_ringbuf.c \
      $(SDK_ROOT)/components/libraries/experimental_section_vars/nrf_section_iter.c \
      $(SDK_ROOT)/components/libraries/strerror/nrf_strerror.c \
      $(SDK_ROOT)/components/libraries/sha256/sha256.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/micro_ecc/micro_ecc_backend_ecc.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/micro_ecc/micro_ecc_backend_ecdh.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/micro_ecc/micro_ecc_backend_ecdsa.c \
      $(SDK_ROOT)/components/boards/boards.c \
      $(SDK_ROOT)/modules/nrfx/hal/nrf_nvmc.c \
      $(SDK_ROOT)/modules/nrfx/soc/nrfx_atomic.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_ecc.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_ecdsa.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_hash.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_init.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_shared.c \
      $(PROJ_DIR)/../dfu_public_key.c \
      $(PROJ_DIR)/main.c \
      $(SDK_ROOT)/components/ble/common/ble_srv_common.c \
      $(SDK_ROOT)/components/libraries/bootloader/nrf_bootloader.c \
      $(SDK_ROOT)/components/libraries/bootloader/nrf_bootloader_app_start.c \
      $(SDK_ROOT)/components/libraries/bootloader/nrf_bootloader_app_start_final.c \
      $(SDK_ROOT)/components/libraries/bootloader/nrf_bootloader_dfu_timers.c \
      $(SDK_ROOT)/components/libraries/bootloader/nrf_bootloader_fw_activation.c \
      $(SDK_ROOT)/components/libraries/bootloader/nrf_bootloader_info.c \
      $(SDK_ROOT)/components/libraries/bootloader/nrf_bootloader_wdt.c \
      $(SDK_ROOT)/external/nano-pb/pb_common.c \
      $(SDK_ROOT)/external/nano-pb/pb_decode.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/nrf_sw/nrf_sw_backend_hash.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/dfu-cc.pb.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu.c \
      $(SDK_ROOT)/components/libraries/bootloader/ble_dfu/nrf_dfu_ble.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_flash.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_handling_error.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_mbr.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_req_handler.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_settings.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_settings_svci.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_transport.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_utils.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_validation.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_ver_validation.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_svci.c \
      $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_svci_handler.c \
      $(SDK_ROOT)/components/libraries/svc/nrf_svc_handler.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_ble.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_soc.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/oberon/oberon_backend_chacha_poly_aead.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/oberon/oberon_backend_ecc.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/oberon/oberon_backend_ecdh.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/oberon/oberon_backend_ecdsa.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/oberon/oberon_backend_eddsa.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/oberon/oberon_backend_hash.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/oberon/oberon_backend_hmac.c \
    # Include folders common to all targets
    INC_FOLDERS += \
      $(SDK_ROOT)/components/libraries/crypto/backend/micro_ecc \
      $(SDK_ROOT)/components/libraries/memobj \
      $(SDK_ROOT)/components/libraries/sha256 \
      $(SDK_ROOT)/components/libraries/crc32 \
      $(SDK_ROOT)/components/libraries/experimental_section_vars \
      $(SDK_ROOT)/components/libraries/mem_manager \
      $(SDK_ROOT)/components/libraries/fstorage \
      $(SDK_ROOT)/components/libraries/util \
      $(SDK_ROOT)/modules/nrfx \
      $(SDK_ROOT)/external/nrf_oberon/include \
      $(SDK_ROOT)/components/libraries/crypto/backend/oberon \
      $(SDK_ROOT)/components/libraries/crypto/backend/cifra \
      $(SDK_ROOT)/components/libraries/atomic \
      $(SDK_ROOT)/integration/nrfx \
      $(SDK_ROOT)/components/libraries/crypto/backend/cc310_bl \
      $(SDK_ROOT)/components/libraries/log/src \
      $(SDK_ROOT)/components/libraries/bootloader/dfu \
      $(SDK_ROOT)/components/ble/common \
      $(SDK_ROOT)/components/libraries/delay \
      $(SDK_ROOT)/components/softdevice/s113/headers/nrf52 \
      $(SDK_ROOT)/components/libraries/svc \
      $(SDK_ROOT)/components/libraries/stack_info \
      $(SDK_ROOT)/components/libraries/crypto/backend/nrf_hw \
      $(SDK_ROOT)/components/libraries/log \
      $(SDK_ROOT)/external/nrf_oberon \
      $(SDK_ROOT)/components/libraries/strerror \
      $(SDK_ROOT)/components/libraries/crypto/backend/mbedtls \
      $(SDK_ROOT)/components/softdevice/s113/headers \
      $(SDK_ROOT)/components/boards \
      $(SDK_ROOT)/components/libraries/crypto/backend/cc310 \
      $(SDK_ROOT)/components/libraries/bootloader \
      $(SDK_ROOT)/components/libraries/crypto \
      ../config \
      $(SDK_ROOT)/components/libraries/crypto/backend/optiga \
      $(SDK_ROOT)/components/libraries/scheduler \
      $(SDK_ROOT)/modules/nrfx/hal \
      $(SDK_ROOT)/components/toolchain/cmsis/include \
      $(SDK_ROOT)/components/libraries/balloc \
      $(SDK_ROOT)/components/libraries/atomic_fifo \
      $(SDK_ROOT)/external/micro-ecc/micro-ecc \
      $(PROJ_DIR) \
      $(SDK_ROOT)/components/libraries/crypto/backend/nrf_sw \
      $(SDK_ROOT)/modules/nrfx/mdk \
      $(SDK_ROOT)/components/libraries/bootloader/ble_dfu \
      $(SDK_ROOT)/components/softdevice/common \
      $(SDK_ROOT)/external/nano-pb \
      $(SDK_ROOT)/components/libraries/queue \
      $(SDK_ROOT)/components/libraries/ringbuf \
    # Libraries common to all targets
    LIB_FILES += \
      $(SDK_ROOT)/external/nrf_oberon/lib/cortex-m4/soft-float/liboberon_3.0.1.a \
      $(SDK_ROOT)/external/micro-ecc/nrf52nf_armgcc/armgcc/micro_ecc_lib_nrf52.a \
    # Optimization flags
    OPT = -Os -g3
    # Uncomment the line below to enable link time optimization
    #OPT += -flto
    # C flags common to all targets
    CFLAGS += $(OPT)
    CFLAGS += -DBLE_STACK_SUPPORT_REQD
    CFLAGS += -DBOARD_PCA10040
    CFLAGS += -DCONFIG_GPIO_AS_PINRESET
    CFLAGS += -DDEVELOP_IN_NRF52832
    CFLAGS += -DFLOAT_ABI_SOFT
    CFLAGS += -DNRF52810_XXAA
    CFLAGS += -DNRF52_PAN_74
    CFLAGS += -DNRFX_COREDEP_DELAY_US_LOOP_CYCLES=3
    CFLAGS += -DNRF_DFU_SETTINGS_VERSION=2
    CFLAGS += -DNRF_DFU_SVCI_ENABLED
    CFLAGS += -DNRF_SD_BLE_API_VERSION=7
    CFLAGS += -DS113
    CFLAGS += -DSOFTDEVICE_PRESENT
    CFLAGS += -DSVC_INTERFACE_CALL_AS_NORMAL_FUNCTION
    CFLAGS += -DuECC_ENABLE_VLI_API=0
    CFLAGS += -DuECC_OPTIMIZATION_LEVEL=3
    CFLAGS += -DuECC_SQUARE_FUNC=0
    CFLAGS += -DuECC_SUPPORT_COMPRESSED_POINT=0
    CFLAGS += -DuECC_VLI_NATIVE_LITTLE_ENDIAN=1
    CFLAGS += -mcpu=cortex-m4
    CFLAGS += -mthumb -mabi=aapcs
    CFLAGS += -Wall -Werror
    CFLAGS += -mfloat-abi=soft
    # keep every function in a separate section, this allows linker to discard unused ones
    CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
    CFLAGS += -fno-builtin -fshort-enums
    # C++ flags common to all targets
    CXXFLAGS += $(OPT)
    # Assembler flags common to all targets
    ASMFLAGS += -g3
    ASMFLAGS += -mcpu=cortex-m4
    ASMFLAGS += -mthumb -mabi=aapcs
    ASMFLAGS += -mfloat-abi=soft
    ASMFLAGS += -DBLE_STACK_SUPPORT_REQD
    ASMFLAGS += -DBOARD_PCA10040
    ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
    ASMFLAGS += -DDEVELOP_IN_NRF52832
    ASMFLAGS += -DFLOAT_ABI_SOFT
    ASMFLAGS += -DNRF52810_XXAA
    ASMFLAGS += -DNRF52_PAN_74
    ASMFLAGS += -DNRFX_COREDEP_DELAY_US_LOOP_CYCLES=3
    ASMFLAGS += -DNRF_DFU_SETTINGS_VERSION=2
    ASMFLAGS += -DNRF_DFU_SVCI_ENABLED
    ASMFLAGS += -DNRF_SD_BLE_API_VERSION=7
    ASMFLAGS += -DS113
    ASMFLAGS += -DSOFTDEVICE_PRESENT
    ASMFLAGS += -DSVC_INTERFACE_CALL_AS_NORMAL_FUNCTION
    ASMFLAGS += -DuECC_ENABLE_VLI_API=0
    ASMFLAGS += -DuECC_OPTIMIZATION_LEVEL=3
    ASMFLAGS += -DuECC_SQUARE_FUNC=0
    ASMFLAGS += -DuECC_SUPPORT_COMPRESSED_POINT=0
    ASMFLAGS += -DuECC_VLI_NATIVE_LITTLE_ENDIAN=1
    # Linker flags
    LDFLAGS += $(OPT)
    LDFLAGS += -mthumb -mabi=aapcs -L$(SDK_ROOT)/modules/nrfx/mdk -T$(LINKER_SCRIPT)
    LDFLAGS += -mcpu=cortex-m4
    # let linker dump unused sections
    LDFLAGS += -Wl,--gc-sections
    # use newlib in nano version
    LDFLAGS += --specs=nano.specs
    nrf52810_xxaa_s113: CFLAGS += -D__HEAP_SIZE=0
    nrf52810_xxaa_s113: CFLAGS += -D__STACK_SIZE=2048
    nrf52810_xxaa_s113: ASMFLAGS += -D__HEAP_SIZE=0
    nrf52810_xxaa_s113: ASMFLAGS += -D__STACK_SIZE=2048
    # Add standard libraries at the very end of the linker input, after all objects
    # that may need symbols provided by these libraries.
    LIB_FILES += -lc -lnosys -lm
    .PHONY: default help
    # Default target - first one defined
    default: nrf52810_xxaa_s113
    # Print all targets that can be built
    help:
    	@echo following targets are available:
    	@echo		nrf52810_xxaa_s113
    	@echo		flash_softdevice
    	@echo		sdk_config - starting external tool for editing sdk_config.h
    	@echo		flash      - flashing binary
    TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc
    include $(TEMPLATE_PATH)/Makefile.common
    $(foreach target, $(TARGETS), $(call define_target, $(target)))
    .PHONY: flash flash_softdevice erase
    # Flash the program
    flash: default
    	@echo Flashing: $(OUTPUT_DIRECTORY)/nrf52810_xxaa_s113.hex
    	nrfjprog -f nrf52 --program $(OUTPUT_DIRECTORY)/nrf52810_xxaa_s113.hex --sectorerase
    	nrfjprog -f nrf52 --reset
    # Flash softdevice
    flash_softdevice:
    	@echo Flashing: s113_nrf52_7.0.1_softdevice.hex
    	nrfjprog -f nrf52 --program $(SDK_ROOT)/components/softdevice/s113/hex/s113_nrf52_7.0.1_softdevice.hex --sectorerase
    erase:
    	nrfjprog -f nrf52 --eraseall
    SDK_CONFIG_FILE := ../config/sdk_config.h
    CMSIS_CONFIG_TOOL := $(SDK_ROOT)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar
    sdk_config:
    	java -jar $(CMSIS_CONFIG_TOOL) $(SDK_CONFIG_FILE)
    The s113 uses more RAM than the s112 with the same configuration, so it's likely the RAM settings. The debug log should inform you if they need to be changed, and in that case, what values to use. If you don't have logging enabled you can step through the nrf_sdh_ble_enable() function with a debugger.
    I tried to repeat this with the debug bootloader in SDK 16.0.0 and ended up with the following RAM settings:  "RAM (rwx) :  ORIGIN = 0x20002608, LENGTH = 0x39f8".
    pca10040e_s113_ble_debug.zip
