Hi Support,
Now I am developing over Nordic 52840 DK (PCA10056). My environment as below,
(1) upon SDK (nRF5_SDK_15.3.0_59ac345)
(2) softdevice s140_nrf52_6.1.1_softdevice, which softdevice ID should be 0xB6 (??).
(3) Nordic Programmer in nRF Connect v3.3.0 (Windows10)
(4) Nordic Open_Bootloader (example project: Open_bootloader_usb_mbr_pca10056_debug) with preload SD as well like below,
Now the issue is that, what I am doing is to try to use Nordic Open_bootloader to work with Nordic Programmer to download my pure application (I don't use mergehex tool since there is only one application). This is the screenshot from Nordic Programmer,
However, each time when main application transfer completes, the bootloader would not get the application run up, will be stuck in "In nrf_bootloader_init". Briefed log and detailed log as below,
Briefed log :
<debug> nrf_dfu_req_handler: Whole firmware image received. Postvalidating. Logs dropped (1) <debug> nrf_dfu_validation: Hash verification. start address: 0x26000, size: 0x22980 Logs dropped (1) <debug> nrf_dfu_validation: Validating new application in bank 1. <debug> nrf_dfu_validation: Invalidating old application in bank 0. Logs dropped (2) <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1] <debug> nrf_dfu_settings: Writing settings... Logs dropped (2) <debug> nrf_dfu_settings: Erasing old settings at: 0x000FF000 Logs dropped (1) <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 1 Logs dropped (1) <debug> nrf_dfu_flash: Flash erase success: addr=0x000FF000, pending 0 <debug> nrf_dfu_settings: the bank1 code is: 1 Logs dropped (2) <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x20008614, len=896 bytes), queue usage: 1 Logs dropped (1) <debug> nrf_dfu_flash: Flash write success: addr=0x000FF000, pending 0 Logs dropped (2) <info> nrf_dfu_settings: Backing up settings page to address 0xFE000. <debug> nrf_dfu_settings: Writing settings... <debug> nrf_dfu_settings: Erasing old settings at: 0x000FE000 Logs dropped (1) <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FE000, len=1 pages), queue usage: 1 Logs dropped (2) <debug> nrf_dfu_flash: Flash erase success: addr=0x000FE000, pending 0 Logs dropped (1) <debug> nrf_dfu_settings: the bank1 code is: 1 Logs dropped (1) <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FE000, src=0x20008994, len=896 bytes), queue usage: 1 Logs dropped (1) <debug> nrf_dfu_flash: Flash write success: addr=0x000FE000, pending 0 Logs dropped (1) <debug> nrf_dfu_req_handler: All flash operations have completed. DFU completed. Logs dropped (1) <debug> app: Shutting down transports (found: 1) Logs dropped (1) <debug> app: Resetting bootloader. Logs dropped (1) <info> nrf_dfu_settings: Backing up settings page to address 0xFE000. <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping. <info> app: Open USB bootloader started <debug> app: In nrf_bootloader_init <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()... <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend. <debug> nrf_dfu_settings: Using settings page. <debug> nrf_dfu_settings: Copying forbidden parts from backup page. <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping. <info> nrf_dfu_settings: Backing up settings page to address 0xFE000. <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping. <debug> app: Enter nrf_bootloader_fw_activate <debug> app: Valid App <debug> app: Enter nrf_dfu_app_continue <debug> app: No copy needed <debug> app: Setting app as valid <debug> nrf_dfu_settings: Writing settings... <debug> nrf_dfu_settings: Erasing old settings at: 0x000FF000 <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 0 <debug> nrf_dfu_flash: Flash erase success: addr=0x000FF000, pending 0 <debug> nrf_dfu_settings: the bank1 code is: 0 <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x20008614, len=896 bytes), queue usage: 1 <debug> nrf_dfu_flash: Flash write success: addr=0x000FF000, pending 0 <info> nrf_dfu_settings: Backing up settings page to address 0xFE000. <debug> nrf_dfu_settings: Writing settings... <debug> nrf_dfu_settings: Erasing old settings at: 0x000FE000 <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FE000, len=1 pages), queue usage: 1 <debug> nrf_dfu_flash: Flash erase success: addr=0x000FE000, pending 0 <debug> nrf_dfu_settings: the bank1 code is: 0 <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FE000, src=0x20008994, len=896 bytes), queue usage: 1 <debug> nrf_dfu_flash: Flash write success: addr=0x000FE000, pending 0 <debug> app: Resetting bootloader. <info> nrf_dfu_settings: Backing up settings page to address 0xFE000. <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping. <info> app: Open USB bootloader started <debug> app: In nrf_bootloader_init
Detailed log:
Thanks a lot
Regards
S.
