Built Error Starting Process JAVA
I was able to compile my example codes successfully. All of sudden I have started seeing Error starting Process JAVA.
Has anyone faced this issue?
Can you please help quickly?
thanks
Jay
  • It tells you that the error occurs in the pre-build command.
    So look at your pre-build command(s) to see what it/they is/are doing - and debug from there ...
    By default, Nordic projects don't have a pre-build command - so this is (probably) not a Nordic problem ...
    Your screenshot mentions Rigado - perhaps they can help you ?
    People will help at whatever speed they can!
