The Central device could not paring the peripheral
Hello
I am a beginner for NRF52832 FW desgin.
 Now there are some issue stuck me
The scenario could me show as below: IDE platfrom: Embedded Studio Release 4.12  SDK: nRF5_SDK v15.3.0
I have one peripheral and one central/smart phone
The peripheral device is working in connection & advertising in parallel mode.
it means the peripheral use the connectable advertising before the BLE connecting and use the unconnectable advertising after BLE connected.
The peripheral device ‘s FW is coming from ble_app_gls & ble_app_uart, and I am using the static passkey with peering in my FW.
The central device FW is referring ble_app_uart_c
The smart phone is using the nrf_connect (android version)
 The smart phone can paring & bonding the peripheral device succeed.
The issue is central only can connect the device but it never trigger off peering event
he central device can scan & connect the peripheral device, but it could not bonding & peering.
Peering code for peripheral device:
#define SEC_PARAM_BOND                  1                                       /**< Perform  bonding. */
#define SEC_PARAM_MITM                  1                                       /**< Man In The Middle protection  required. The connection need to input the password */
#define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections  enabled. */
#define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
//#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY            /**< Display I/O capabilities. */
#define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
static void peer_manager_init(void)
    ret_code_t           err_code;
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    ret_code_t err_code = NRF_SUCCESS;
   // uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
   // uint16_t role        = ble_conn_state_role(conn_handle);
   //  printf("role%d\n",role);
      case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            printf("\r\Connected.\r\n");
         //   m_peer_to_be_deleted = PM_PEER_ID_INVALID;
            conn_status=true;
            sec_conn=false; // unsafe connection
            NRF_LOG_INFO("Disconnected");
            sec_conn=false;
            printf("\r\Disconnect.\r\n");
            if (m_peer_to_be_deleted != PM_PEER_ID_INVALID)
                err_code = pm_peer_delete(m_peer_to_be_deleted);
                NRF_LOG_DEBUG("Collector's bond deleted");
                 printf("\r\Collector's bond deleted.\r\n");
            sec_conn=false;
            conn_status=false;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
           // err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_SUCCESS, NULL, NULL);
          //  APP_ERROR_CHECK(err_code); // the error point
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
        case BLE_GAP_EVT_PASSKEY_DISPLAY:
          printf("\r\BLE_GAP_EVT_PASSKEY_DISPLAY.\r\n");
          NRF_LOG_INFO("Passkey: %s", p_ble_evt->evt.gap_evt.params.passkey_display.passkey);
        } break;
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
            printf("\r\BLE_GAP_EVT_AUTH_KEY_REQUEST.\r\n");
            NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
        case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
            printf("\r\BLE_GAP_EVT_LESC_DHKEY_REQUEST.\r\n");
            NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
         case BLE_GAP_EVT_AUTH_STATUS:
             sec_conn = true;
             printf("\r\nAUTH_STATUS.\r\n");
             NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                          p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                          p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                          p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
            // No implementation needed.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
   // pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
        case PM_EVT_CONN_SEC_SUCCEEDED:
            sec_conn=true;
            pm_conn_sec_status_t conn_sec_status;
               printf("\r\nPM_EVT_CONN_SEC_SUCCEEDED\r\n");
            // Check if the link is authenticated (meaning at least MITM).
            err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
            if (conn_sec_status.mitm_protected)
                NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
                // The peer did not use MITM, disconnect.
                NRF_LOG_INFO("Collector did not use MITM, disconnecting");
                err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
                err_code = sd_ble_gap_disconnect(m_conn_handle,
        } break;
        case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = true};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        }break;
        case PM_EVT_CONN_SEC_FAILED:
            Pro_level=1;
Peering code for central device:
#define SEC_PARAM_MITM              1                                   /**< Enable MITM protection */
#define SEC_PARAM_LESC              0                                   /**< LE Secure Connections not enabled. */
#define SEC_PARAM_IO_CAPABILITIES   BLE_GAP_IO_CAPS_KEYBOARD_ONLY       /**< Keyboard Only. */
//////////////Added for bonding///////
////////////Added for bonding///////////
// Static passkey
#define STATIC_PASSKEY    "123455"
static ble_opt_t    m_static_pin_option;
uint8_t passkey[] = STATIC_PASSKEY;
//////////////Added for bonding//////////////
/**@brief Function for initializing the Peer Manager.
 * @param[in] erase_bonds  Indicates whether the bonding information must be cleared from
 *                         persistent storage during the initialization of the Peer Manager.
static void peer_manager_init()
            scan_start();
Below it is my source code
peripheral device:
sdk_config.hmain - peripheral.c
Central device:
 * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#define APP_BLE_CONN_CFG_TAG    1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
#define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
uint8_t data_array[BLE_NUS_MAX_DATA_LEN];
static char const m_target_periph_name[] = "CAAQS";             /**< Name of the device to try to **/
BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE Nordic UART Service (NUS) client instance. */
NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief NUS UUID. */
static ble_uuid_t const m_nus_uuid =
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
// Static passkey
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is only an example and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for starting scanning. */
static void scan_start(void)
    ret_code_t ret;
    ret = nrf_ble_scan_start(&m_scan);
    APP_ERROR_CHECK(ret);
    ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
         case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
              err_code = p_scan_evt->params.connecting_err.err_code;
         } break;
         case NRF_BLE_SCAN_EVT_CONNECTED:
              ble_gap_evt_connected_t const * p_connected =
                               p_scan_evt->params.connected.p_connected;
             // Scan is automatically stopped by the connection.
             NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                      p_connected->peer_addr.addr[0],
                      p_connected->peer_addr.addr[1],
                      p_connected->peer_addr.addr[2],
                      p_connected->peer_addr.addr[3],
                      p_connected->peer_addr.addr[4],
                      p_connected->peer_addr.addr[5]
         } break;
         case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
             NRF_LOG_INFO("Scan timed out.");
             scan_start();
         } break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    err_code = nrf_ble_scan_filter_set(&m_scan,SCAN_NAME_FILTER,m_target_periph_name);
     err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
   // err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
    //err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
    //APP_ERROR_CHECK(err_code);
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
/**@brief Function for handling characters received by the Nordic UART Service (NUS).
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
        while (app_uart_put('\n') == NRF_ERROR_BUSY);
    if (ECHOBACK_BLE_UART_DATA)
        // Send data back to the peripheral.
        do
            ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
 * @details This function receives a single character from the app_uart module and appends it to
 *          a string. The string is sent over BLE when the last character received is a
 *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
  //  static
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            printf("%d\n", index);
           // printf("%d\n", data_array[1]);
            if(index==7)
                do
                  ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                  if( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                } while (ret_val == NRF_ERROR_RESOURCES);
               index = 0;
            if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                do
                    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling Nordic UART Service (NUS) client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
 * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = pm_conn_secure(p_ble_nus_evt->conn_handle, false);
            if (err_code != NRF_ERROR_BUSY)
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
            scan_start();
 * @brief Function for handling shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
            // start discovery of services. The NUS Client waits for a discovery result
            err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
            NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
                err_code = sd_ble_gap_auth_key_reply(p_gap_evt->conn_handle, BLE_GAP_AUTH_KEY_TYPE_PASSKEY, &passkey[0]);
                asm("nop");
        /////////Remove for bonding///////////
       /* case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
            // Pairing not supported.
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            break;*/
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in] event  Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Function for initializing the UART. */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler = ble_nus_c_evt_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
            scan_start();
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/** @brief Function for initializing the database discovery module. */
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
 * @details Handles any pending log operations, then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
    // Initialize.
    log_init();
    timer_init();
    uart_init();
    buttons_leds_init();
    db_discovery_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    nus_c_init();
    scan_init();
    peer_manager_init();
    // Start execution.
    printf("BLE UART central example started.\r\n");
    NRF_LOG_INFO("BLE UART central example started.");
    scan_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
sdk_config - central.h
