following the peripheral/saadc sample, which shows the periodic reading... could you please share the essential and minimal config for the One-Shot measurement?
Thank you
Thank you
You can refer to this example to see how you can do blocking single shot SAADC sampling, which is the simplest way of doing it. You can drop this main.c file directly into the SAADC example of SDK 16.0.0 and test it.
* Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup nrf_adc_example main.c
* @ingroup nrf_adc_example
* @brief ADC Example Application main file.
* This file contains the source code for a sample application using ADC.
* @image html example_board_setup_a.jpg "Use board setup A for this example."
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SAADC_CHANNEL 0
* @brief Not used in this example, but driver API requiers a callback function to be proivded.
* @brief Function for confguring SAADC channel 0 for sampling AIN0 (P0.02).
void saadc_init(void)
ret_code_t err_code;
nrf_saadc_channel_config_t channel_config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
err_code = nrf_drv_saadc_init(NULL, saadc_callback);
err_code = nrf_drv_saadc_channel_init(SAADC_CHANNEL, &channel_config);
nrf_saadc_value_t sample;
err_code = NRF_LOG_INIT(NULL);
saadc_init();
NRF_LOG_INFO("SAADC HAL simple example started.");
while (1)
err_code = nrfx_saadc_sample_convert(SAADC_CHANNEL, &sample);
NRF_LOG_INFO("Sample: %i", sample);
NRF_LOG_FLUSH();
nrf_delay_ms(1000);
Hi Einar,
thank you! that worked and we are using it.
I am doing housekeeping :) and closing tickets...
thanks!
