Not able to write 14 Bytes into Queued Writes module
Hi Nordic,
Please provide the way to debug not able to write 14 Bytes data into Queued Writes module, my application not get any nrf_ble_qwr_on_ble_evt.
[Project Informaiton]
nrf52832 (S132 SoftDevice v6.1.1) + MCU (CXD5602), UART interface to connect between each other.
[Design description]
My application designs both ble_peripheral, and ble_central in one.
I integrate "write-queued-characteristic-with-less-than-20-bytes" solutions into my application.
[sdk_config.h]
#define NRF_BLE_QWR_ENABLED 1
#define NRF_BLE_QWR_MAX_ATTR 1
[Issue description]
Not able write more than 13 Bytes data (while write 14 Bytes, My application stuck) into My applcation with nrf_connect android application
In nrf_connect android application shows log in "Log 2020-01-17 11_37_48.txt"
[Central][Log in nrf_connect android application]
1). write 13 Bytes, result: PASS
V 11:37:05.688 Writing request to characteristic 6e400002-b5a3-f393-e0a9-e50e24dcca9e
D 11:37:05.688 gatt.writeCharacteristic(6e400002-b5a3-f393-e0a9-e50e24dcca9e, value=0x31323334353637383930313233)
I 11:37:06.088 Data written to 6e400002-b5a3-f393-e0a9-e50e24dcca9e, value: (0x) 31-32-33-34-35-36-37-38-39-30-31-32-33, "1234567890123"
A 11:37:06.088 "1234567890123" sent
2). write 14 Bytes, result: NG
V 11:37:28.334 Writing request to characteristic 6e400002-b5a3-f393-e0a9-e50e24dcca9e
D 11:37:28.334 gatt.writeCharacteristic(6e400002-b5a3-f393-e0a9-e50e24dcca9e, value=0x3132333435363738393031323334)
D 11:37:32.522 [Server callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
I 11:37:32.522 [Server] Device disconnected
E 11:37:32.538 Error 133 (0x85): GATT ERROR
[Peripheral][Log in my application with nrf52832]
[2020-01-17 11:36:49] ble_spresense_handler_on_le_connect_status_change, ble_state_s.ble_connect_handle = 0x0001
[2020-01-17 11:36:49] [BLE_GATT] Connect status ADDR:6D:E1:DE:BF:A7:C3, status:Connected, ble_state->ble_connect_handle = 0x0001
[2020-01-17 11:36:49] Debug : RESP_OK => nrf_ble_qwr_on_ble_evt, p_ble_evt->header.evt_id = 16
[2020-01-17 11:36:49] Debug : RESP_OK => nrf_ble_qwr_on_ble_evt, p_ble_evt->header.evt_id = 35
[2020-01-17 11:36:49] Debug : RESP_OK => nrf_ble_qwr_on_ble_evt, p_ble_evt->header.evt_id = 36
[2020-01-17 11:36:49] Debug : RESP_OK => PHY update request.
[2020-01-17 11:36:49] Debug : RESP_OK => nrf_ble_qwr_on_ble_evt, p_ble_evt->header.evt_id = 33
[2020-01-17 11:36:50] Debug : RESP_OK => nrf_ble_qwr_on_ble_evt, p_ble_evt->header.evt_id = 34
[2020-01-17 11:36:50] Debug : RESP_OK => nrf_ble_qwr_on_ble_evt, p_ble_evt->header.evt_id = 18
[2020-01-17 11:36:51] Debug : RESP_OK => nrf_ble_qwr_on_ble_evt, p_ble_evt->header.evt_id = 18
[2020-01-17 11:36:55] Debug : RESP_OK => nrf_ble_qwr_on_ble_evt, p_ble_evt->header.evt_id = 18
[2020-01-17 11:37:07] Debug : RESP_OK => nrf_ble_qwr_on_ble_evt, p_ble_evt->header.evt_id = 81
[2020-01-17 11:37:07] Debug : RESP_OK => BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
[2020-01-17 11:37:07] Debug : RESP_OK => on_rw_authorize_request, p_auth_req->request.write.op = 0x1
[2020-01-17 11:37:07] Debug : RESP_OK => nrf_ble_qwrs_on_qwr_evt, p_evt->evt_type = 2
[2020-01-17 11:37:07] Debug : RESP_OK => BLE_QWRS_NEW_DATA_RCVD
[2020-01-17 11:37:07] Debug : RESP_OK => 31323334353637383930313233
My application not show any evt in nrf_ble_qwr_on_ble_evt fuction, I guess while handle 14 Bytes data write request in softdevice has exception.
Please Nordic help to provide me the way to do next debug
[Attached files]
sdk_config.h (#define NRF_BLE_QWR_ENABLED 1 #define NRF_BLE_QWR_MAX_ATTR 1)
nrf_ble_qwr.c
nrf_ble_qwr.h
nrf_ble_qwrs.c
nrf_ble_qwrs.h
ble_wrap_15.c (my application)
Many thanks.
Caspar
nRF Connect, 2020-01-17
SONY_BLE (E6:E7:6E:CF:B4:C1)
I	11:36:46.645	[Server] Server started
V	11:36:46.669	Heart Rate (0x180D)
- Heart Rate Measurement [N] (0x2A37)
   Client Characteristic Configuration (0x2902)
- Body Sensor Location [R] (0x2A38)
- Heart Rate Control Point [W] (0x2A39)
Unknown Service (00003802-0000-1000-8000-00805f9b34fb)
- Unknown Characteristic [I N R W] (00004a02-0000-1000-8000-00805f9b34fb)
   Unknown Descriptor (0000aab0-0000-1000-8000-aabbccddeeff)
   Characteristic Presentation Format (0x2904)
- Unknown Characteristic [I R W WNR] (0000aaa2-0000-1000-8000-aabbccddeeff)
User Data (0x181C)
- First Name [R W] (0x2A8A)
- Last Name [R W] (0x2A90)
- Gender [R W] (0x2A8C)
Current Time Service (0x1805)
- Current Time [N R] (0x2A2B)
- Local Time Information [R] (0x2A0F)
V	11:36:47.020	Connecting to E6:E7:6E:CF:B4:C1...
D	11:36:47.021	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D	11:36:48.538	[Server callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	11:36:48.538	[Server] Device with address E6:E7:6E:CF:B4:C1 connected
D	11:36:48.544	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	11:36:48.544	Connected to E6:E7:6E:CF:B4:C1
D	11:36:48.578	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
V	11:36:48.578	Discovering services...
D	11:36:48.578	gatt.discoverServices()
I	11:36:48.988	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
D	11:36:49.124	[Callback] Services discovered with status: 0
I	11:36:49.124	Services discovered
V	11:36:49.130	Generic Access (0x1800)
- Device Name [R W] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
- Central Address Resolution [R] (0x2AA6)
Generic Attribute (0x1801)
Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e)
- RX Characteristic [N R W] (6e400002-b5a3-f393-e0a9-e50e24dcca9e)
D	11:36:49.130	gatt.setCharacteristicNotification(6e400002-b5a3-f393-e0a9-e50e24dcca9e, true)
I	11:36:49.211	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
I	11:36:53.218	Connection parameters updated (interval: 195.0ms, latency: 0, timeout: 4000ms)
D	11:37:32.539	[Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
E	11:37:32.552	Error 8 (0x8): GATT CONN TIMEOUT
I	11:37:32.553	Disconnected
D	11:37:32.568	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
sdk_config.h
 * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
#include "sdk_common.h"
#if NRF_MODULE_ENABLED(NRF_BLE_QWR)
#include <stdlib.h>
#include "nrf_ble_qwr.h"
#include "ble.h"
#include "ble_srv_common.h"
#define NRF_BLE_QWR_INITIALIZED 0xDE // Non-zero value used to make sure the given structure has been initialized by the module.
#define MODULE_INITIALIZED      (p_qwr->initialized == NRF_BLE_QWR_INITIALIZED)
#include "sdk_macros.h"
#include <stdio.h>
// Response output macros
#define RESP(_form, ...) do { printf(_form "\n", ##__VA_ARGS__); } while(0)
#define RESP_ASYNC(form, ...) RESP("#" form, ##__VA_ARGS__)
#define RESP_ERROR(form, ...) RESP("*" form, ##__VA_ARGS__)
#define RESP_OK(form, ...)    RESP("=" form, ##__VA_ARGS__)
ret_code_t nrf_ble_qwr_init(nrf_ble_qwr_t            * p_qwr,
                            nrf_ble_qwr_init_t const * p_qwr_init)
    VERIFY_PARAM_NOT_NULL(p_qwr);
    VERIFY_PARAM_NOT_NULL(p_qwr_init);
    if (MODULE_INITIALIZED)
    p_qwr->error_handler = p_qwr_init->error_handler;
    p_qwr->initialized   = NRF_BLE_QWR_INITIALIZED;
    p_qwr->conn_handle   = BLE_CONN_HANDLE_INVALID;
#if (NRF_BLE_QWR_MAX_ATTR > 0)
    memset(p_qwr->attr_handles, 0, sizeof(p_qwr->attr_handles));
    p_qwr->nb_registered_attr        = 0;
    p_qwr->is_user_mem_reply_pending = false;
    p_qwr->mem_buffer                = p_qwr_init->mem_buffer;
    p_qwr->callback                  = p_qwr_init->callback;
    p_qwr->nb_written_handles        = 0;
    return NRF_SUCCESS;
ret_code_t nrf_ble_qwr_attr_register(nrf_ble_qwr_t * p_qwr, uint16_t attr_handle)
    VERIFY_MODULE_INITIALIZED();
    if ((p_qwr->nb_registered_attr == NRF_BLE_QWR_MAX_ATTR)
        || (p_qwr->mem_buffer.p_mem == NULL)
        || (p_qwr->mem_buffer.len == 0))
        return (NRF_ERROR_NO_MEM);
    if (attr_handle == BLE_GATT_HANDLE_INVALID)
        return NRF_ERROR_INVALID_PARAM;
    p_qwr->attr_handles[p_qwr->nb_registered_attr] = attr_handle;
    p_qwr->nb_registered_attr++;
    return NRF_SUCCESS;
ret_code_t nrf_ble_qwr_value_get(nrf_ble_qwr_t * p_qwr,
                                 uint16_t        attr_handle,
                                 uint8_t       * p_mem,
                                 uint16_t      * p_len)
    VERIFY_PARAM_NOT_NULL(p_mem);
    VERIFY_PARAM_NOT_NULL(p_len);
    uint16_t i          = 0;
    uint16_t handle     = BLE_GATT_HANDLE_INVALID;
    uint16_t val_len    = 0;
    uint16_t val_offset = 0;
    uint16_t cur_len    = 0;
    do
        handle = uint16_decode(&(p_qwr->mem_buffer.p_mem[i]));
        if (handle == BLE_GATT_HANDLE_INVALID)
        i         += sizeof(uint16_t);
        val_offset = uint16_decode(&(p_qwr->mem_buffer.p_mem[i]));
        val_len    = uint16_decode(&(p_qwr->mem_buffer.p_mem[i]));
        if (handle == attr_handle)
            cur_len = val_offset + val_len;
            if (cur_len <= *p_len)
                memcpy((p_mem + val_offset), &(p_qwr->mem_buffer.p_mem[i]), val_len);
                return NRF_ERROR_NO_MEM;
        i += val_len;
    while (i < p_qwr->mem_buffer.len);
    *p_len = cur_len;
    return NRF_SUCCESS;
ret_code_t nrf_ble_qwr_conn_handle_assign(nrf_ble_qwr_t * p_qwr,
                                          uint16_t        conn_handle)
    p_qwr->conn_handle = conn_handle;
    return NRF_SUCCESS;
/**@brief checks if a user_mem_reply is pending, if so attempts to send it.
 * @param[in]   p_qwr        QWR structure.
static void user_mem_reply(nrf_ble_qwr_t * p_qwr)
    if (p_qwr->is_user_mem_reply_pending)
        ret_code_t err_code;
#if (NRF_BLE_QWR_MAX_ATTR == 0)
        err_code = sd_ble_user_mem_reply(p_qwr->conn_handle, NULL);
#else
        err_code = sd_ble_user_mem_reply(p_qwr->conn_handle, &p_qwr->mem_buffer);
        if (err_code == NRF_SUCCESS)
        else if (err_code == NRF_ERROR_BUSY)
            p_qwr->is_user_mem_reply_pending = true;
            p_qwr->error_handler(err_code);
/**@brief Handle a user memory request event.
 * @param[in]   p_common_evt User_mem_request event to be handled.
static void on_user_mem_request(nrf_ble_qwr_t          * p_qwr,
                                ble_common_evt_t const * p_common_evt)
    if ((p_common_evt->params.user_mem_request.type == BLE_USER_MEM_TYPE_GATTS_QUEUED_WRITES) &&
        (p_common_evt->conn_handle == p_qwr->conn_handle))
        user_mem_reply(p_qwr);
/**@brief Handle a user memory release event.
 * @param[in]   p_common_evt User_mem_release event to be handled.
static void on_user_mem_release(nrf_ble_qwr_t          * p_qwr,
    if ((p_common_evt->params.user_mem_release.type == BLE_USER_MEM_TYPE_GATTS_QUEUED_WRITES) &&
        // Cancel the current operation.
/**@brief Handle a prepare write event.
 * @param[in]   p_evt_write  WRITE event to be handled.
static void on_prepare_write(nrf_ble_qwr_t               * p_qwr,
                             ble_gatts_evt_write_t const * p_evt_write)
    uint32_t                              err_code;
    ble_gatts_rw_authorize_reply_params_t auth_reply;
    memset(&auth_reply, 0, sizeof(auth_reply));
    auth_reply.params.write.gatt_status = NRF_BLE_QWR_REJ_REQUEST_ERR_CODE;
    auth_reply.type                     = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
    uint32_t i;
    for (i = 0; i < p_qwr->nb_written_handles; i++)
        if (p_qwr->written_attr_handles[i] == p_evt_write->handle)
            auth_reply.params.write.gatt_status = BLE_GATT_STATUS_SUCCESS;
    if (auth_reply.params.write.gatt_status != BLE_GATT_STATUS_SUCCESS)
        for (i = 0; i < p_qwr->nb_registered_attr; i++)
            if (p_qwr->attr_handles[i] == p_evt_write->handle)
                p_qwr->written_attr_handles[p_qwr->nb_written_handles++] = p_evt_write->handle;
    err_code = sd_ble_gatts_rw_authorize_reply(p_qwr->conn_handle, &auth_reply);
    if (err_code != NRF_SUCCESS)
        // Report error to application.
/**@brief Handle an execute write event.
 * @param[in]   p_evt_write  EXEC WRITE event to be handled.
static void on_execute_write(nrf_ble_qwr_t               * p_qwr,
    uint32_t                              err_code;
    if (p_qwr->nb_written_handles == 0)
        return;
    for (uint16_t i = 0; i < p_qwr->nb_written_handles; i++)
        nrf_ble_qwr_evt_t evt;
        uint16_t          ret_val;
        evt.evt_type    = NRF_BLE_QWR_EVT_AUTH_REQUEST;
        evt.attr_handle = p_qwr->written_attr_handles[i];
        ret_val         = p_qwr->callback(p_qwr, &evt);
        if (ret_val != BLE_GATT_STATUS_SUCCESS)
            auth_reply.params.write.gatt_status = ret_val;
    // If the execute has not been rejected by any of the registered applications, propagate execute write event to all written handles. */
    if (auth_reply.params.write.gatt_status == BLE_GATT_STATUS_SUCCESS)
            evt.evt_type    = NRF_BLE_QWR_EVT_EXECUTE_WRITE;
            /*lint -e534 -save "Ignoring return value of function" */
            /*lint -restore*/
/**@brief Handle a cancel write event.
static void on_cancel_write(nrf_ble_qwr_t               * p_qwr,
    uint32_t                              err_code;
/**@brief Handle a rw_authorize_request event.
 * @param[in]   p_gatts_evt  RW_authorize_request event to be handled.
static void on_rw_authorize_request(nrf_ble_qwr_t         * p_qwr,
                                    ble_gatts_evt_t const * p_gatts_evt)
    if (p_gatts_evt->conn_handle != p_qwr->conn_handle)
        return;
    ble_gatts_evt_rw_authorize_request_t const * p_auth_req = &p_gatts_evt->params.authorize_request;
    if (p_auth_req->type != BLE_GATTS_AUTHORIZE_TYPE_WRITE)
        return;
    // Handle only queued write related operations.
    if ((p_auth_req->request.write.op != BLE_GATTS_OP_PREP_WRITE_REQ) &&
        (p_auth_req->request.write.op != BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) &&
        (p_auth_req->request.write.op != BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
        return;
    // Prepare the response.
    ble_gatts_rw_authorize_reply_params_t auth_reply = {0};
    if (p_auth_req->request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL)
    ret_code_t err_code = sd_ble_gatts_rw_authorize_reply(p_gatts_evt->conn_handle, &auth_reply);
#else
    RESP_OK("%s, p_auth_req->request.write.op = 0x%x", __func__, p_auth_req->request.write.op);
    switch (p_auth_req->request.write.op)
        case BLE_GATTS_OP_WRITE_REQ:
            auth_reply.params.write.update = 1;
            auth_reply.params.write.p_data = p_auth_req->request.write.data;
            auth_reply.params.write.len = p_auth_req->request.write.len;
            ret_code_t err_code = sd_ble_gatts_rw_authorize_reply(p_qwr->conn_handle,&auth_reply);
              evt.evt_type    = NRF_BLE_QWR_EVT_WRITE;
              evt.attr_handle = p_gatts_evt->params.authorize_request.request.write.handle;
              evt.write_len =  p_auth_req->request.write.len;
        case BLE_GATTS_OP_PREP_WRITE_REQ:
            on_prepare_write(p_qwr, &p_auth_req->request.write);
            break; // BLE_GATTS_OP_PREP_WRITE_REQ
        case BLE_GATTS_OP_EXEC_WRITE_REQ_NOW:
            on_execute_write(p_qwr, &p_auth_req->request.write);
            break; // BLE_GATTS_OP_EXEC_WRITE_REQ_NOW
        case BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL:
            on_cancel_write(p_qwr, &p_auth_req->request.write);
            break; // BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL
            // No implementation needed.
void nrf_ble_qwr_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
    RESP_OK("%s", __func__);
    VERIFY_PARAM_NOT_NULL_VOID(p_context);
    VERIFY_PARAM_NOT_NULL_VOID(p_ble_evt);
    RESP_OK("%s, p_ble_evt->header.evt_id = %d", __func__, p_ble_evt->header.evt_id);
    nrf_ble_qwr_t * p_qwr = (nrf_ble_qwr_t *)p_context;
    VERIFY_MODULE_INITIALIZED_VOID();
    if (p_ble_evt->evt.common_evt.conn_handle == p_qwr->conn_handle)
        case BLE_EVT_USER_MEM_REQUEST:
            RESP_OK("BLE_EVT_USER_MEM_REQUEST");
            on_user_mem_request(p_qwr, &p_ble_evt->evt.common_evt);
            break; // BLE_EVT_USER_MEM_REQUEST
        case BLE_EVT_USER_MEM_RELEASE:
            RESP_OK("BLE_EVT_USER_MEM_RELEASE");
            on_user_mem_release(p_qwr, &p_ble_evt->evt.common_evt);
        case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
            RESP_OK("BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST");
            on_rw_authorize_request(p_qwr, &p_ble_evt->evt.gatts_evt);
            break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
            if (p_ble_evt->evt.gap_evt.conn_handle == p_qwr->conn_handle)
            break; // BLE_GAP_EVT_DISCONNECTED
#endif // NRF_MODULE_ENABLED(NRF_BLE_QWR)
nrf_ble_qwr.h
#include <stdio.h>
#include "nrf_ble_qwrs.h"
#include <string.h>
#define NRF_LOG_MODULE_NAME BLE_QWRS
#include "nrf_log.h"
NRF_LOG_MODULE_REGISTER();
#define BLE_UUID_QWRS_SERVICE             0x0001                      /**< The UUID of the QWRS Service. */
#define BLE_UUID_QWRS_LONG_CHARACTERISTIC 0x0002                      /**< The UUID of the QWRS Long Characteristic. */
#define BLE_QWRS_MAX_LONG_CHAR_LEN        NRF_BLE_QWRS_MAX_RCV_SIZE   /**< Maximum length of the QWRS Long Characteristic (in bytes). */
#define BLE_QWRS_MAX_CHAR_LEN             20                          /**< Maximum length of the QWRS Characteristic (in bytes). */
#define QWRS_BASE_UUID                  {{0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0x00, 0x00, 0x40, 0x6E}} /**< Used vendor specific UUID. */
uint16_t nrf_ble_qwrs_on_qwr_evt(nrf_ble_qwrs_t *p_qwrs,
                                 nrf_ble_qwr_evt_t * p_evt)
    RESP_OK("%s, p_evt->evt_type = %d", __func__, p_evt->evt_type);
    if (p_qwrs->evt_handler != NULL)
        nrf_ble_qwrs_evt_t cur_evt;
        if(p_evt->evt_type == NRF_BLE_QWR_EVT_WRITE)
            uint8_t recv_data[BLE_QWRS_MAX_CHAR_LEN];
            memset(recv_data,0,BLE_QWRS_MAX_CHAR_LEN);
            ble_gatts_value_t gatt_value = {0};
            gatt_value.p_value = recv_data;
            gatt_value.len = p_evt->write_len;
            err_code = sd_ble_gatts_value_get(p_qwr->conn_handle,p_evt->attr_handle,&gatt_value);
                cur_evt.evt_type = BLE_QWRS_NEW_DATA_RCVD;
                memcpy(&cur_evt.rcvd_data, recv_data, p_evt->write_len);
                cur_evt.rcv_length = p_evt->write_len;
                return p_qwrs->evt_handler(p_qwrs, &(cur_evt));
                RESP_ERROR("%s, sd_ble_gatts_value_get failed.", __func__);
            cur_evt.rcv_length = NRF_BLE_QWRS_MAX_RCV_SIZE;
            err_code = nrf_ble_qwr_value_get(p_qwr, p_evt->attr_handle, cur_evt.rcvd_data, &cur_evt.rcv_length);
                RESP_ERROR("%s, nrf_ble_qwr_value_get failed.", __func__);
                return BLE_GATT_STATUS_ATTERR_INSUF_AUTHORIZATION;
            if (p_evt->evt_type == NRF_BLE_QWR_EVT_AUTH_REQUEST)
                cur_evt.evt_type = BLE_QWRS_CHECK_RCVD_DATA;
            else if (p_evt->evt_type == NRF_BLE_QWR_EVT_EXECUTE_WRITE)
    return BLE_GATT_STATUS_SUCCESS;
uint32_t nrf_ble_qwrs_init(nrf_ble_qwrs_init_t *p_qwrs_init, nrf_ble_qwrs_t *p_qwrs)
    ble_uuid_t    ble_uuid;
    // Initialize service structure.
    p_qwrs->evt_handler   = p_qwrs_init->evt_handler;
    p_qwrs->error_handler = p_qwrs_init->error_handler;
    p_qwrs->conn_handle   = BLE_CONN_HANDLE_INVALID;
    // Add service.
    ble_uuid128_t base_uuid = QWRS_BASE_UUID;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &p_qwrs->uuid_type);
    RESP_OK("%s, sd_ble_uuid_vs_add, err_code = %lu", __func__, err_code);
    VERIFY_SUCCESS(err_code);
    ble_uuid.type = p_qwrs->uuid_type;
    ble_uuid.uuid = BLE_UUID_QWRS_SERVICE;
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                        &ble_uuid,
                                        &p_qwrs->service_handle);
    RESP_OK("%s, sd_ble_gatts_service_add, err_code = %lu", __func__, err_code);
    //Add Long characteristic
    ble_add_char_params_t add_char_params;
    memset(&add_char_params, 0, sizeof(add_char_params));
    add_char_params.uuid             = BLE_UUID_QWRS_LONG_CHARACTERISTIC;
    add_char_params.uuid_type        = p_qwrs->uuid_type;
    add_char_params.max_len          = BLE_QWRS_MAX_LONG_CHAR_LEN;
    add_char_params.init_len         = 0;
    add_char_params.char_props.write = true;
    add_char_params.char_props.read  = true;
    add_char_params.char_props.notify= true;
    add_char_params.cccd_write_access= true;
    add_char_params.read_access      = SEC_OPEN;
    add_char_params.write_access     = SEC_OPEN;
    add_char_params.is_defered_read  = true;
    add_char_params.is_defered_write = true;
    err_code = characteristic_add(p_qwrs->service_handle,
                              &add_char_params,
                              &p_qwrs->long_charact_handles);
    RESP_OK("%s, characteristic_add, err_code = %lu", __func__, err_code);
    if (p_qwrs_init->p_qwr_ctx != NULL)
        err_code = nrf_ble_qwr_attr_register(p_qwrs_init->p_qwr_ctx,
                                             p_qwrs->long_charact_handles.value_handle);
        RESP_OK("%s, nrf_ble_qwr_attr_register, err_code = %lu", __func__, err_code);
    return err_code;
nrf_ble_qwrs.h
 * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, O
#include <utils.h>
// ============================= ble_app_queued_writes =============================
#define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2    /**< Reply when unsupported features are requested. */
#define APP_BLE_OBSERVER_PRIO           1                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define CONFIG_BLUETOOTH_LE_NAME "BLE-CLASSIC"
#define SEND_DISCOVERY_RESULT_DELAY     APP_TIMER_TICKS(10000)                   /**< Discovery notification delay time. */
#define APP_ADV_INTERVAL                300                                      /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                18000                                    /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MEM_BUFF_SIZE                   512
// Global variables
//#define BLE_WRAP_NO_NUS 1 //CEI
NRF_BLE_QWR_DEF(m_qwr);                                                    /**< Queued Writes structure.*/
NRF_BLE_GATT_DEF(m_gatt);                                                 /** GATT module instance*/
BLE_ADVERTISING_DEF(m_advertising);                                      /** Advertising module instance*/
#ifndef BLE_WRAP_NO_NUS
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                           /** Structure to identify the Nordic UART Service*/
#define IS_CENTRAL (m_ble_role == eBLE_Central)
// ============================= Code copied from Nordic template =============================
extern uint8_t m_enc_advdata[];
extern uint8_t m_adv_handle;
extern ble_gap_adv_data_t m_adv_data;
extern ble_gap_adv_params_t m_adv_params;
extern ble_gap_scan_params_t m_scan_params;
extern ble_gap_conn_params_t m_connection_param;
// ============================= ble_app_queued_writes, Start =============================
static uint8_t        m_buffer[MEM_BUFF_SIZE];
static nrf_ble_qwrs_t m_qwrs;
// ============================= ble_app_queued_writes, End =============================
static char const m_target_periph_name[] = "GATTTool";     /**< Name of the device we try to connect to. This name is searched in the scan report data*/
//Todo
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
            err_code = p_scan_evt->params.connecting_err.err_code;
//From v15 nrf_ble_scan
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = BLE_CONN_CFG_TAG_DEFAULT;//APP_BLE_CONN_CFG_TAG;
    	init_scan.p_scan_param = &m_scan_params;
	init_scan.p_conn_param = &m_connection_param;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    // Setting filters for scanning.
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
__WEAK void pm_evt_handler(pm_evt_t const * p_evt)
    switch (p_evt->evt_id)
        case PM_EVT_BONDED_PEER_CONNECTED:
            NRF_LOG_INFO("Connected to a previously bonded device.");
        } break;
        case PM_EVT_CONN_SEC_SUCCEEDED:
            NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                         ble_conn_state_role(p_evt->conn_handle),
                         p_evt->conn_handle,
                         p_evt->params.conn_sec_succeeded.procedure);
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            /* Often, when securing fails, it shouldn't be restarted, for security reasons.
             * Other times, it can be restarted directly.
             * Sometimes it can be restarted, but only after changing some Security Parameters.
             * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
             * Sometimes it is impossible, to secure the link, or the peer device does not support it.
             * How to handle this error is highly application dependent. */
        } break;
        case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        } break;
        case PM_EVT_STORAGE_FULL:
            // Run garbage collection on the flash.
            err_code = fds_gc();
            if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                // Retry.
        } break;
            //advertising_start(false);
        } break;
        case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            // The local database has likely changed, send service changed indications.
            pm_local_database_has_changed();
        } break;
        case PM_EVT_PEER_DATA_UPDATE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
        } break;
        case PM_EVT_PEER_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
        } break;
        case PM_EVT_PEERS_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
        } break;
        case PM_EVT_ERROR_UNEXPECTED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
        } break;
        case PM_EVT_CONN_SEC_START:
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
        case PM_EVT_PEER_DELETE_SUCCEEDED:
        case PM_EVT_LOCAL_DB_CACHE_APPLIED:
        case PM_EVT_SERVICE_CHANGED_IND_SENT:
        case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
__WEAK void timers_init(void)
  // Initialize timer module.
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    //RESP_OK("%s, error_code = %ld", __func__, err_code);
__WEAK void nus_string_received(const char *str) {
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_nus    Nordic UART Service structure.
 * @param[in] p_data   Data to be send to UART module.
 * @param[in] length   Length of the data.
/**@snippet [Handling the data received over BLE] */
__WEAK void nus_data_handler(ble_nus_evt_t * p_evt)
  if (p_evt->type == BLE_NUS_EVT_RX_DATA) {
    uint16_t length = MIN(sizeof(m_nus_input)-1, p_evt->params.rx_data.length);
    strncpy(m_nus_input, (char*)p_evt->params.rx_data.p_data, length);
    m_nus_input[length] = 0;
    if (strstr(m_nus_input, "DFUStart")) {
      // Catch this command here in case application doesn't call ble_wrap_handle_pending
      ble_wrap_enter_ota_mode();
/**@brief Function for handling Service errors.
static void service_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the Queued Write Example Service events.
 * @details This function will be called for all Queued Write Example Service events which are passed to
 *          the application.
 * @param[in]   p_qwrs   Queued Write Example Service structure.
 * @param[in]   p_evt    Event received from the Queued Write Example Service.
static uint16_t queued_write_example_service_evt_handler(nrf_ble_qwrs_t     * p_qwrs,
                                                         nrf_ble_qwrs_evt_t * p_evt)
    uint16_t ret_val = BLE_GATT_STATUS_SUCCESS;
    switch (p_evt->evt_type)
        case BLE_QWRS_CHECK_RCVD_DATA:
            // This is where your application can check the received value before accepting the write.
            if (p_evt->rcvd_data[0] == 0)
                RESP_ERROR("First byte is 0, reject the operation");
                ret_val =  BLE_GATT_STATUS_ATTERR_INSUF_AUTHORIZATION;
                RESP_OK("First byte is not 0, accept the operation");
            break;//BLE_QWRS_CHECK_RCVD_DATA
        case BLE_QWRS_NEW_DATA_RCVD:
            RESP_OK("BLE_QWRS_NEW_DATA_RCVD");
            *  Write Queued Characteristic with Less than 20 bytes
            *  https://devzone.nordicsemi.com/f/nordic-q-a/37970/write-queued-characteristic-with-less-than-20-bytes/151680#151680
            if (p_evt->rcv_length > 0)
                uint8_t buff[p_evt->rcv_length];
                memset(buff, 0x00, p_evt->rcv_length);
                bytes_to_hex(p_evt->rcvd_data, p_evt->rcv_length, (char*)buff);
                RESP_OK("%s", buff);
            // This is where the data is actually received and has been accepted.
            break;//BLE_QWRS_NEW_DATA_RCVD
    return ret_val;
/**@brief Function for handling events from the Queued Write module.
uint16_t queued_write_handler(nrf_ble_qwr_t * p_qwr, nrf_ble_qwr_evt_t * p_evt)
    return nrf_ble_qwrs_on_qwr_evt(&m_qwrs, p_qwr, p_evt);
__WEAK void services_init(void)
  uint32_t       err_code;
  ble_nus_init_t nus_init;
/**@brief Function for initializing gatt services that will be used by the application.
__WEAK ret_code_t gatt_services_init(void)
  nrf_ble_qwr_init_t  qwr_init;
  nrf_ble_qwrs_init_t qwrs_init;
  memset(&qwr_init,0x00,sizeof(qwr_init));
  // Initialize Queued Write Module
  qwr_init.mem_buffer.len   = MEM_BUFF_SIZE;
  qwr_init.mem_buffer.p_mem = m_buffer;
  qwr_init.error_handler    = service_error_handler;
  qwr_init.callback         = queued_write_handler;
  RESP_OK("%s, nrf_ble_qwr_init, err_code = %lu\n", __func__, err_code);
  //APP_ERROR_CHECK(err_code);
  //initialize the Queued Writes Example Service
  memset(&qwrs_init, 0, sizeof(qwrs_init));
  qwrs_init.evt_handler   = queued_write_example_service_evt_handler;
  qwrs_init.error_handler = service_error_handler;
  qwrs_init.p_qwr_ctx     = &m_qwr;
  err_code = nrf_ble_qwrs_init(&qwrs_init, &m_qwrs);
  RESP_OK("%s, nrf_ble_qwrs_init, err_code = %lu\n", __func__, err_code);
  return err_code;
__WEAK void conn_params_init(void)
    ret_code_t err_code = NRF_SUCCESS;
            RESP_OK("Disconnected.");
            m_is_connected = false;
        case BLE_GAP_EVT_CONNECTED:
            RESP_OK("Connected.");
            m_is_connected = true;
            RESP_OK("%s, p_ble_evt->header.evt_id = %d, IS_CENTRAL = %d, m_conn_handle = %04X, p_ble_evt->evt.gap_evt.conn_handle = %04X",
              __func__, p_ble_evt->header.evt_id, IS_CENTRAL, m_conn_handle, p_ble_evt->evt.gap_evt.conn_handle);
            RESP_OK("%s, err_code = %lu", __func__, err_code);
#ifndef PERIPHERAL_ONLY
#if 0 //CEI
            //not Start service discovery at this time, it should trigger by spresense/examples/bluetooth_le_central/bluetooth_le_central_main.c
            if (IS_CENTRAL) {
              // Start service discovery
              //APP_ERROR_CHECK(ble_db_discovery_start(&m_ble_db_discovery, p_ble_evt->evt.gap_evt.conn_handle));
              memset(&m_ble_db_discovery, 0x00, sizeof(m_ble_db_discovery));
              err_code = ble_db_discovery_start(&m_ble_db_discovery, p_ble_evt->evt.gap_evt.conn_handle);
#if defined(S132)
            RESP_OK("PHY update request.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
            RESP_OK("GATT Client Timeout.");
        case BLE_GATTS_EVT_TIMEOUT:
            RESP_OK("GATT Server Timeout.");
            err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
            ble_gatts_evt_rw_authorize_request_t  req;
            req = p_ble_evt->evt.gatts_evt.params.authorize_request;
            if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                    if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                    auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                    err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                               &auth_reply);
        } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
        case BLE_GATTS_EVT_HVN_TX_COMPLETE:
          m_buffer_available = true;
        case BLE_GAP_EVT_ADV_REPORT: {
          ble_evt_t *p = (ble_evt_t*)p_ble_evt;
          ble_gap_evt_t *p_gap_evt = &p->evt.gap_evt;
          if (m_adv_report_cb) m_adv_report_cb(&p_gap_evt->params.adv_report);
        case BLE_GAP_EVT_TIMEOUT: {
          const ble_gap_evt_t *p_gap_evt = &p_ble_evt->evt.gap_evt;
          if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN) {
              RESP_ERROR("Scan timed out");
          } else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN) {
              RESP_ERROR("Connection Request timed out");
    if (IS_CENTRAL) {
      ble_db_discovery_on_ble_evt(p_ble_evt, &m_ble_db_discovery);
      ble_nus_c_on_ble_evt(p_ble_evt, &m_ble_nus_c);
    on_ble_evt((ble_evt_t*)p_ble_evt);
__WEAK void ble_stack_init()
  uint32_t ram_start = 0;
  //RESP_OK("%s, nrf_sdh_ble_default_cfg_set() = %lX",  __func__, err_code);
  // Enable BLE stack.
  //RESP_OK("%s, nrf_sdh_ble_enable() = %lX",  __func__, err_code);
  // Enabling and populating the DC/DC converter,
  err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
  //RESP_OK("%s, sd_power_dcdc_mode_set() = %lX",  __func__, err_code);
/**@brief Function for the Peer Manager initialization.
__WEAK void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
// ============================= End of Nordic template code =============================
void ble_wrap_erase_bonds() {
  delete_bonds();
uint32_t _millis() {
  return (uint32_t)((uint64_t)NRF_RTC0->COUNTER*1000/APP_TIMER_CLOCK_FREQ);
__WEAK void ble_log_init()
    static bool done = false;
    if (done) return;
    ret_code_t err_code = NRF_LOG_INIT(_millis);
    done = true;
#if !defined(PERIPHERAL_ONLY) && !defined(BLE_WRAP_NO_NUS)
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, const ble_nus_c_evt_t * p_ble_nus_evt) {
  uint32_t err_code;
  switch (p_ble_nus_evt->evt_type) {
    case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
      // UART service detected
      err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
      err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
      LOG_DEBUG("Service detected");
      if (m_nus_c_rx_cb)
        m_nus_c_rx_cb(NULL, 1);
    case BLE_NUS_C_EVT_NUS_TX_EVT:
      // UART response received
      if (m_nus_c_rx_cb)
        m_nus_c_rx_cb(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
    case BLE_NUS_C_EVT_DISCONNECTED:
      if (m_nus_c_rx_cb)
        m_nus_c_rx_cb(NULL, 0);
static void nus_c_init(void) {
    ble_nus_c_init_t nus_c_init_t;
    nus_c_init_t.evt_handler = ble_nus_c_evt_handler;
    APP_ERROR_CHECK(ble_nus_c_init(&m_ble_nus_c, &nus_c_init_t));
__WEAK void discovery_handler(ble_db_discovery_evt_t *p_evt) {}
static void db_disc_handler(ble_db_discovery_evt_t * p_evt) {
  ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
  discovery_handler(p_evt);
void ble_wrap_init(const char *device_name) {
  if (strlen(device_name) == 0)
    m_ble_role = eBLE_Central;
  //printf("%s, %d\n", __func__, __LINE__);
  if (IS_CENTRAL) {
    APP_ERROR_CHECK(ble_db_discovery_init(db_disc_handler));
  ble_log_init();
  timers_init();
  ble_stack_init();
  gap_params_init(CONFIG_BLUETOOTH_LE_NAME);
  gatt_init();
  services_init();
  conn_params_init();
  peer_manager_init();
  scan_init();
#ifdef INCLUDE_BATT_MEAS
  init_battery_measurement();
  if (IS_CENTRAL) {
    nus_c_init();
  check_set_pub_mac_addr();
  ble_gap_addr_t bt_addr;
  sd_ble_gap_addr_get(&bt_addr);
  LOG_INFO("Mac address: %s", ble_wrap_addr2str(&bt_addr));
  RESP_OK("%s, bt_addr = %02X:%02X:%02X:%02X:%02X:%02X, m_ble_role = %02X",
    __func__,
    bt_addr.addr[5], bt_addr.addr[4], bt_addr.addr[3],
    bt_addr.addr[2], bt_addr.addr[1], bt_addr.addr[0],
    m_ble_role);
  //nrf_delay_ms(1000);
void ble_wrap_teardown() {
  nrf_sdh_disable_request();
static bool m_is_connectable = true;
void ble_wrap_set_connectable(bool on) {
  m_is_connectable = on;
bool ble_wrap_advertise(uint16_t company_id, ble_advdata_name_type_t type,
                        uint8_t *p_data, uint8_t size,
                        uint32_t interval_ms, uint32_t timeout_s) {
  RESP_OK("%s, m_is_connected = %d, m_is_advertising = %d, interval_ms = %lu, m_is_connectable = %d",
        __func__, m_is_connected, m_is_advertising, interval_ms, m_is_connectable);
  if (m_is_connected) return false;
  if (m_is_advertising && sd_ble_gap_adv_stop(m_advertising.adv_handle) != NRF_SUCCESS) return false;
  if (!interval_ms) {
    m_is_advertising = false;
    return true;
  if (m_is_connectable)
      ble_advertising_init_t init;
      init.advdata.name_type = type;
      init.advdata.include_appearance = true; // extra add, 2019/12/16
      init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
      ble_advdata_manuf_data_t manuf_specific_data;
      if (p_data != NULL)
        manuf_specific_data.company_identifier = company_id;
        manuf_specific_data.data.p_data = p_data;
        manuf_specific_data.data.size = size;
        init.advdata.p_manuf_specific_data = &manuf_specific_data;
#ifdef ADVERTISE_SERVICE_UUIDS
      init.advdata.uuids_complete.uuid_cnt = SERVICE_UUID_CNT;
      init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
      init.config.ble_adv_fast_interval = APP_ADV_INTERVAL;// MSEC_TO_UNITS(interval_ms, UNIT_0_625_MS);
      init.config.ble_adv_fast_timeout  = APP_ADV_DURATION;// timeout_s;
      init.evt_handler = ble_wrap_on_adv_evt;
      APP_ERROR_CHECK(ble_advertising_init(&m_advertising, &init));
      ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
      static ble_gap_adv_params_t m_adv_params;
      ble_advdata_t advdata;
      memset(&advdata, 0, sizeof(advdata));
      if (p_data != NULL)
#if NRF_SDK_VERSION == 15
      ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
      memset(&m_adv_params, 0, sizeof(m_adv_params));
      m_adv_params.p_peer_addr = NULL;
      m_adv_params.filter_policy          = BLE_GAP_ADV_FP_ANY;
      m_adv_params.interval    =  MSEC_TO_UNITS(interval_ms, UNIT_0_625_MS);
      m_adv_params.properties.type        = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
      m_adv_params.duration     = timeout_s;
      sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
      sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
#else
      ble_advdata_set(&advdata, NULL);
      m_adv_params.type        = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
      m_adv_params.fp          = BLE_GAP_ADV_FP_ANY;
      m_adv_params.timeout     = timeout_s;
      sd_ble_gap_adv_start(&m_adv_params, APP_BLE_CONN_CFG_TAG);
      m_is_advertising = true;
  // For now, api above return invalid state after first call...
  return true;
uint32_t ble_wrap_stop_advertise() {
  RESP_OK("%s, m_is_connected = %d, m_is_advertising = %d, m_is_connectable = %d, m_advertising.adv_handle = %X",
        __func__, m_is_connected, m_is_advertising, m_is_connectable, m_advertising.adv_handle);
  (void) sd_ble_gap_adv_stop(m_advertising.adv_handle);
  m_advertising.adv_modes_config.ble_adv_fast_timeout  = 1;// timeout_s;
  return NRF_SUCCESS;
  • 1) The function sd_ble_enable()/ nrf_sdh_ble_enable() will tell you how much RAM is required to enable the SoftDevice with the current SD configuration. Turn on logging, and the values should be printed in the log.
    2) Did sd_ble_gap_connect() return any error-code ? You might also want to set a scan-timout in p_scan_params for sd_ble_gap_connect()
  • Hi Sigurd,
    1). my application print out below logs
    ble_stack_init, nrf_sdh_ble_default_cfg_set() = 0, ram_start = 200028C0
    ble_stack_init, nrf_sdh_ble_enable() = 0, ram_start = 200028C0
    Attached my application "app_mem_conf.ld"
    UUID_COUNT = 2
    RAM_REDUCE = 16 * UUID_COUNT = 32
    MEMORY
    FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0x5d000
    RAM (rwx) : ORIGIN = 0x20002890+RAM_REDUC, LENGTH = 0xD740-RAM_REDUC
    after caculate RAM(rwx) would be ORIGIN = 0x200028C2, LENGTH = D70E, however nrf_sdh_ble_enable() is 0x200028C0.
    Would that be no problem for my app_mem_conf.ld define ?
     app_mem_conf.ld
    2). sd_ble_gap_connect() return NRF_SUCCESS, however my android nrfconnect application not receive any connect message,
    Need to debug why sd_ble_gap_connect() not work even though got NRF_SUCCESS.
    Did you have any suggestion to get more debug information ?
    3). my applicatin scan_timeout is 0x0000 //disables timeout.
    4). sd_ble_gap_connect() does not work, after intergate https://github.com/bjornspockeli/custom_ble_service_example into my application.
    Many thanks.
    Caspar
  • Hi Sigurd,
    1). After mark "BLE_CUS_DEF(m_cus)", sd_ble_gap_connect() works very well.
    //BLE_CUS_DEF(m_cus); /**< Context for the Queued Write module.*/
    It would be somewhere not configure properly, and would you please provide me what's item should configure well for intergeate github.com/.../custom_ble_service_example into my application ?
    2). Attached ble_cus.zip (ble_wrap_15.c is my application already integratehttps://github.com/bjornspockeli/custom_ble_service_example )
    3). sd_ble_gap_connect() return NRF_SUCCESS, please check attached
    Developer shell in normal boot!
    NuttShell (NSH) NuttX-7.22
    nsh>
    [2020-02-27 09:16:32] nsh> ble_central
    [2020-02-27 09:16:36] ble_central_main [BT] Register common call back . ret = 0
    [2020-02-27 09:16:36] crc failed
    [2020-02-27 09:16:36] ble_central_main [BT] Initialization . ret = 0
    [2020-02-27 09:16:36] ble_central_main [BT] Set local address . ret = 0
    [2020-02-27 09:16:36] ble_central_main [BT] Set local name . ret = 0
    [2020-02-27 09:16:36] ble_central_main [BLE] Register common call back . ret = 0
    [2020-02-27 09:16:36] ble_central_main [BLE] Register central call back . ret = 0
    [2020-02-27 09:16:36] ble_central_main [BLE] Set name . ret = 0
    [2020-02-27 09:16:36] ble_central_main [BLE] Set address . ret = 0
    [2020-02-27 09:16:36] Power on BLE!!
    [2020-02-27 09:16:36] uart init success
    [2020-02-27 09:16:36] bleWake
    [2020-02-27 09:16:36] bleSetBleName, Length= 20, BleSetName SONY_BLE
    [2020-02-27 09:16:36] , name_len = 8, local_ble_name = SONY_BLE
    [2020-02-27 09:16:36] ble_central_main [BLE] Enable . ret = 0
    [2020-02-27 09:16:36] Length= 56, bleGapScanWithFilter = SCAN D70FE7A15A21|SONY-CENTRAL|hrc|nRF Connect|SONY_BLE
    [2020-02-27 09:16:36] ble_central_main [BLE] Start scan . ret = 0
    [2020-02-27 09:16:36] Debug : RESP_OK => ble_wrap_set_name, device_name = SONY_BLE, err_code = 0000, strlen(device_name) = 8
    [2020-02-27 09:16:36] Debug : RESP_OK => BleSetName
    [2020-02-27 09:16:36] Debug : RESP_OK => SCAN
    [2020-02-27 09:16:36] Debug : RESP_ASYNC_SCAN => 45:17:97:87:94:AE, dev_name+data: 166E524620436F6E6E6563740000
    [2020-02-27 09:16:36] bleRecvLeAdverReport, [NAME] data_len = 16
    [2020-02-27 09:16:36] bleRecvLeAdverReport, [Manufacturer Specific Data] data_len = 00
    [2020-02-27 09:16:36] bleRecvLeAdverReport, [Service Data - 16-bit UUID] data_len = 00
    [2020-02-27 09:16:36] bleRecvLeAdverReport, MAC_ADDR => 45:17:97:87:94:AE
    [2020-02-27 09:16:36] , exitble_spresense_handler_on_scan_result, MAC_ADDR => 45:17:97:87:94:AE
    [2020-02-27 09:16:36] [BLE_GATT] Scan result ADDR:45:17:97:87:94:AE, name:nRF Connect
    [2020-02-27 09:16:36] on_scan_result, dev_name + sizeof(uint8_t) = nRF Connect
    [2020-02-27 09:16:36] on_scan_result, gatts_dev_name_len = 11, gatts_dev_name = nRF Connect
    [2020-02-27 09:16:36] Length= 9, bleGapScan = SCANSTOP
    [2020-02-27 09:16:36] , with_sleep =0
    [2020-02-27 09:16:36] bleGapConnect, ADDR:45:17:97:87:94:AE
    [2020-02-27 09:16:36] on_scan_result [BLE_GATT] connect target device. ret = 0
    [2020-02-27 09:16:36] Debug : RESP_OK => SCANSTOP
    [2020-02-27 09:16:36] Debug : RESP_OK => ble_wrap_connect_to, sd_ble_gap_connect, err_code = 0
    [2020-02-27 09:16:36] Debug : RESP_OK => CONNECT
    Many thanks.
    Caspar
    The nrf_sdh_ble_enable() returns the value you should use.
    When sd_ble_gap_connect() returns NRF_SUCCESS, it will start to scan for the device to connect to. If the device is not found, or if it's not possible to connect to the device, it will continue to scan(until timeout, if enabled), and you will not get the the BLE_GAP_EVT_CONNECTED.
    The zip does not seem to have been attached, only ble_wrap_15.c. If are still having issues with this, please upload the whole project.
    Do you get BLE_GAP_EVT_CONNECTED ?
  • Hi ,
    Use ozone to debug, and find out the root cause is NULL pointer causes fatal error.
    The application is both central, and peripheral.role.
    Both central, and peripheral should have customer_ble_service, however only peripheral role do ble_cus_init(&m_cus, &cus_init);
    Due to central-role does not do ble_cus_init(&m_cus, &cus_init), on_connect() function access null pointer in p_cus->evt_handler(p_cus, &evt); fatal error.
    Would you please share how to extract crash log, and stack dump from nRF52832 ? and the way to parse stack dump to call-stack ?
    Many thanks.
    Caspar
