Migrate CLI over CDC/ACM to project open_bootloader_mbr, but stuck in cli_write
Hi support,
Firstly, environment as below,
(1) upon SDK (nRF5_SDK_15.3.0_59ac345)
(2) Nordic Open_Bootloader (example project: Open_bootloader_usb_mbr_pca10056_debug)
(3) Nordic 52840 DK (PCA10056)
What I am doing is just try to migrate CLI over CDC/ACM to project open_bootloader_mbr, but stuck in cli_write and would not get out as below,
Can anyone tell me why please? Thanks a lot.
FYI, I have separate the configuration of CLI_CDC/ACM away from that of DFU_CDC/ACM as below,
(1) Setting of  CLI_CDC/ACM
// <h> nrf_cli_cdc_acm - CDC ACM command line interface transport
// <q> NRF_CLI_CDC_ACM_ENABLED  - Enable/disable the CLI CDC ACM module.
#ifndef NRF_CLI_CDC_ACM_ENABLED
#define NRF_CLI_CDC_ACM_ENABLED 1
// <o> NRF_CLI_CDC_ACM_COMM_INTERFACE - COMM interface number.
#ifndef NRF_CLI_CDC_ACM_COMM_INTERFACE
#define NRF_CLI_CDC_ACM_COMM_INTERFACE 0
// <s> NRF_CLI_CDC_ACM_COMM_EPIN - COMM IN endpoint number.
#ifndef NRF_CLI_CDC_ACM_COMM_EPIN
#define NRF_CLI_CDC_ACM_COMM_EPIN NRF_DRV_USBD_EPIN2
// <o> NRF_CLI_CDC_ACM_DATA_INTERFACE - DATA interface number.
#ifndef NRF_CLI_CDC_ACM_DATA_INTERFACE
#define NRF_CLI_CDC_ACM_DATA_INTERFACE 1
// <s> NRF_CLI_CDC_ACM_DATA_EPIN - DATA IN endpoint number.
#ifndef NRF_CLI_CDC_ACM_DATA_EPIN
#define NRF_CLI_CDC_ACM_DATA_EPIN NRF_DRV_USBD_EPIN1
// <s> NRF_CLI_CDC_ACM_DATA_EPOUT - DATA OUT endpoint number.
#ifndef NRF_CLI_CDC_ACM_DATA_EPOUT
#define NRF_CLI_CDC_ACM_DATA_EPOUT NRF_DRV_USBD_EPOUT1
(2) Setting of DFU_CDC/ACM
#define CDC_ACM_COMM_INTERFACE          2//0
#define CDC_ACM_COMM_EPIN               NRF_DRV_USBD_EPIN4//NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE          3//1
#define CDC_ACM_DATA_EPIN               NRF_DRV_USBD_EPIN3//NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT              NRF_DRV_USBD_EPOUT2//NRF_DRV_USBD_EPOUT1
Regards
J.S.
    Can explain/show all the change you have done in the bootloader in order to add CLI support? Out of curiosity I also wonder why you want this in the bootloader?
  • Hi Einar,
    Thanks for your response. Let me explain you the second question firstly,
    Re-
    The product would only talk to an another embedded system via CDC/ACM over USB. So, CLI would be the only way to do maintainance once it is published to customer side.
    J.S.
  • Hi Einar,
    Just try to migrate NRF_CLI module to the example project open_bootloader_usb_mbr_pca10056_debug,
    (1) In SDK_Config.h as below,  mainly to enable NRF_CLI related options and queue etc. Please refer to the files below for details,
    4774.sdk_config.h
    (2) add nrf_cli.c nrf_cli_cdc_acm.c nrf_queue.c nrf_sortlist.c
    to nRF_Libraries folder in the project IDE
    (3) Separate CLI_ACM/CDC settings with DFU_ACM/CDC as I already showed in my first post above.
    (4) The main NRF_CLI init/start/process as
    #include <stdio.h>
    #include <stdbool.h>
    #include <stddef.h>
    #include "app_timer.h"
    #include "nrf_cli.h"
    //#include "nrf_cli_rtt.h"
    #include "nrf_cli_types.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_log_backend_flash.h"
    #include "nrf_fstorage_nvmc.h"
    #if defined(APP_USBD_ENABLED) && APP_USBD_ENABLED
    #define CLI_OVER_USB_CDC_ACM 1
    #else
    #define CLI_OVER_USB_CDC_ACM 0
    #if CLI_OVER_USB_CDC_ACM
    #include "nrf_cli_cdc_acm.h"
    #include "nrf_drv_usbd.h"
    #include "app_usbd_core.h"
    #include "app_usbd.h"
    #include "app_usbd_string_desc.h"
    #include "app_usbd_cdc_acm.h"
    #endif //CLI_OVER_USB_CDC_ACM
    #if defined(TX_PIN_NUMBER) && defined(RX_PIN_NUMBER)
    #define CLI_OVER_UART 1
    #else
    #define CLI_OVER_UART 0
    /* Counter timer. */
    APP_TIMER_DEF(m_timer_0);
    /* Declared in demo_cli.c */
    //extern uint32_t m_counter;
    //extern bool m_counter_active;
    /* If enabled then CYCCNT (high resolution) timestamp is used for the logger. */
    #define USE_CYCCNT_TIMESTAMP_FOR_LOG 0
     * @brief Command line interface instance
    #define CLI_EXAMPLE_LOG_QUEUE_SIZE  (4)
    NRF_CLI_CDC_ACM_DEF(m_cli_cdc_acm_transport);
    NRF_CLI_DEF(m_cli_cdc_acm,
                "mst_cli:~$ ",
                &m_cli_cdc_acm_transport.transport,
                '\r',
                CLI_EXAMPLE_LOG_QUEUE_SIZE);
    void cli_start(void)
        ret_code_t ret;
        ret = nrf_cli_start(&m_cli_cdc_acm);
        APP_ERROR_CHECK(ret);
    #if CLI_OVER_UART
        ret = nrf_cli_start(&m_cli_uart);
    void cli_init(void)
        ret_code_t ret;
        ret = nrf_cli_init(&m_cli_cdc_acm, NULL, true, true, NRF_LOG_SEVERITY_INFO);
    #if CLI_OVER_UART
        nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
        uart_config.pseltxd = TX_PIN_NUMBER;
        uart_config.pselrxd = RX_PIN_NUMBER;
        uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
        ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
        NRF_LOG_INFO("mst global Available commands:");
        NRF_LOG_INFO("- mstglobal");
    void cli_process(void)
        nrf_cli_process(&m_cli_cdc_acm);
    #if CLI_OVER_UART
        nrf_cli_process(&m_cli_uart);
    (4) I get the NRF_CLI to envoke the NRF_CLI init/start/process as,
    uint32_t nrf_dfu_init_user(void)
        ret_code_t ret;
        NRF_LOG_DEBUG("In mst nrf_dfu_init_user");
        app_usbd_class_inst_t const * class_cli_cdc_acm = app_usbd_cdc_acm_class_inst_get(&nrf_cli_cdc_acm);
        ret = app_usbd_class_append(class_cli_cdc_acm);
        cli_init();
        cli_start();
        return NRF_SUCCESS;
    ret_code_t nrf_bootloader_init(nrf_dfu_observer_t observer)
        NRF_LOG_DEBUG("In nrf_bootloader_init");
        if (dfu_enter)
            nrf_bootloader_wdt_init();
            scheduler_init();
            dfu_enter_flags_clear();
            nrf_bootloader_dfu_inactivity_timer_restart(initial_timeout, inactivity_timeout);
            ret_val = nrf_dfu_init(dfu_observer); //here already complete usb transport initialization
            if (ret_val != NRF_SUCCESS)
                return NRF_ERROR_INTERNAL;
            // Call user-defined init function if implemented
            ret_val = nrf_dfu_init_user(); //here I envoke to do NRF_CLI init/start
            NRF_LOG_DEBUG("Enter main loop");
            loop_forever(); // This function will never return.
            NRF_LOG_ERROR("Unreachable");
    static void loop_forever(void)
        while (true)
            //feed the watchdog if enabled.
            nrf_bootloader_wdt_feed();
            app_sched_execute();
            cli_process();  //***************** here I get CLI_PROCESS called
            UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
            /* Sleep CPU only if there was no interrupt since last loop processing */
            __WFE();
            if (!NRF_LOG_PROCESS())
                wait_for_event();
    (5) I didn't get task_manager enabled.
    Above all is my change. Any thought please? Thanks
    Regards
    J.S.
    I do not immediately see anything that sticks out.
    Have you made sure that the bootloader start address is moved sufficiently down so that the bootloader does not overlap with the two last pages (MBR params and Bootloader settings). If so, the code that happens to be placed there would be corrupted. This is a problem since the SES bootloader projects in the SDK are slightly misconfigured, and you will not get a linker error even if the bootloader is up to two pages too big. And in this case, any odd error could happen.
    I still don't understand why you want this in the bootloader though. I understand that you need the USB bootloader for updating firmware via USB. But why do you need CLI in addition? What will it be used for? You write that "CLI would be the only way to do maintainance once it is published to the customer side", but the bootloader should not need any "maintenance"?
    Thanks for your reply. I have figured out a workaround for this, just commenting out those parts in cli_write. Seems that there is a timing issue there, like when the source code in the cycle waiting for TX_DONE to change tx_rdy, however this while loop blocks the CPU and would not let other procedure continue any more. It is very easy to reproduce such an issue if your developer would like to do this.
    However I don't know if there is any side effect. Could it get CLI consume much cpu? or something else?please let me know. Thanks.
    Regards
    J.S.
