Joining NFC and Mesh examples
I'm using the mesh example Dimming examples (experimental) in the nRF5 SDK for Mesh v4.0.0 and the nRF5 SDK v16.0.0 example Writable NDEF Message Example.
I was able to join the nfc library with the Mesh example, but when passing the phone to read the tag nothing happens and the software goes into a loop on line 112 of the code below:
 *                           SEGGER Microcontroller GmbH                           *
 *                               The Embedded Experts                              *
 *                   (c) 2014 - 2018 SEGGER Microcontroller GmbH                   *
 *                  www.segger.com     Support: [email protected]                 *
 *        All rights reserved.                                                     *
 *        Redistribution and use in source and binary forms, with or               *
 *        without modification, are permitted provided that the following          *
 *        conditions are met:                                                      *
 *        - Redistributions of source code must retain the above copyright         *
 *          notice, this list of conditions and the following disclaimer.          *
 *        - Neither the name of SEGGER Microcontroller GmbH                        *
 *          nor the names of its contributors may be used to endorse or            *
 *          promote products derived from this software without specific           *
 *          prior written permission.                                              *
 *        THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND                   *
 *        CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,              *
 *        INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF                 *
 *        MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE                 *
 *        DISCLAIMED.                                                              *
 *        IN NO EVENT SHALL SEGGER Microcontroller GmbH BE LIABLE FOR              *
 *        ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR                 *
 *        CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT        *
 *        OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;          *
 *        OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF            *
 *        LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT                *
 *        (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE        *
 *        USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH         *
 *        DAMAGE.        *
 *                         Preprocessor Definitions                                 *
 * VECTORS_IN_RAM        *
 *   If defined, an area of RAM will large enough to store the vector table         *
 *   will be reserved.                                                              *
  .syntax unified
  .code 16
  .section .init, "ax"
  .align 0
 * Default Exception Handlers                                                       *
  .thumb_func
  .weak   NMI_Handler
NMI_Handler:
  b     .
  .thumb_func
  .weak   HardFault_Handler
HardFault_Handler:
  b     .
  .thumb_func
  .weak   MemoryManagement_Handler
MemoryManagement_Handler:
  b     .
  .thumb_func
  .weak   BusFault_Handler
BusFault_Handler:
  b     .
  .thumb_func
  .weak   UsageFault_Handler
UsageFault_Handler:
  b     .
  .thumb_func
  .weak   SVC_Handler
SVC_Handler:
  b     .
  .thumb_func
  .weak   DebugMon_Handler
DebugMon_Handler:
  b     .
  .thumb_func
  .weak   PendSV_Handler
PendSV_Handler:
  b     .
  .thumb_func
  .weak   SysTick_Handler
SysTick_Handler:
  b     .
  .thumb_func
  .weak   Dummy_Handler
Dummy_Handler:
  b     .
 * Default Interrupt Handlers                                                       *
.weak POWER_CLOCK_IRQHandler
.thumb_set POWER_CLOCK_IRQHandler, Dummy_Handler
.weak RADIO_IRQHandler
.thumb_set RADIO_IRQHandler, Dummy_Handler
.weak UARTE0_UART0_IRQHandler
.thumb_set UARTE0_UART0_IRQHandler, Dummy_Handler
.weak SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQHandler
.thumb_set SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQHandler, Dummy_Handler
.weak SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQHandler
.thumb_set SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQHandler, Dummy_Handler
.weak NFCT_IRQHandler
.thumb_set NFCT_IRQHandler, Dummy_Handler
.weak GPIOTE_IRQHandler
.thumb_set GPIOTE_IRQHandler, Dummy_Handler
.weak SAADC_IRQHandler
.thumb_set SAADC_IRQHandler, Dummy_Handler
.weak TIMER0_IRQHandler
.thumb_set TIMER0_IRQHandler, Dummy_Handler
.weak TIMER1_IRQHandler
.thumb_set TIMER1_IRQHandler, Dummy_Handler
.weak TIMER2_IRQHandler
.thumb_set TIMER2_IRQHandler, Dummy_Handler
.weak RTC0_IRQHandler
.thumb_set RTC0_IRQHandler, Dummy_Handler
.weak TEMP_IRQHandler
.thumb_set TEMP_IRQHandler, Dummy_Handler
.weak RNG_IRQHandler
.thumb_set RNG_IRQHandler, Dummy_Handler
.weak ECB_IRQHandler
.thumb_set ECB_IRQHandler, Dummy_Handler
.weak CCM_AAR_IRQHandler
.thumb_set CCM_AAR_IRQHandler, Dummy_Handler
.weak WDT_IRQHandler
.thumb_set WDT_IRQHandler, Dummy_Handler
.weak RTC1_IRQHandler
.thumb_set RTC1_IRQHandler, Dummy_Handler
.weak QDEC_IRQHandler
.thumb_set QDEC_IRQHandler, Dummy_Handler
.weak COMP_LPCOMP_IRQHandler
.thumb_set COMP_LPCOMP_IRQHandler, Dummy_Handler
.weak SWI0_EGU0_IRQHandler
.thumb_set SWI0_EGU0_IRQHandler, Dummy_Handler
.weak SWI1_EGU1_IRQHandler
.thumb_set SWI1_EGU1_IRQHandler, Dummy_Handler
.weak SWI2_EGU2_IRQHandler
.thumb_set SWI2_EGU2_IRQHandler, Dummy_Handler
.weak SWI3_EGU3_IRQHandler
.thumb_set SWI3_EGU3_IRQHandler, Dummy_Handler
.weak SWI4_EGU4_IRQHandler
.thumb_set SWI4_EGU4_IRQHandler, Dummy_Handler
.weak SWI5_EGU5_IRQHandler
.thumb_set SWI5_EGU5_IRQHandler, Dummy_Handler
.weak TIMER3_IRQHandler
.thumb_set TIMER3_IRQHandler, Dummy_Handler
.weak TIMER4_IRQHandler
.thumb_set TIMER4_IRQHandler, Dummy_Handler
.weak PWM0_IRQHandler
.thumb_set PWM0_IRQHandler, Dummy_Handler
.weak PDM_IRQHandler
.thumb_set PDM_IRQHandler, Dummy_Handler
.weak MWU_IRQHandler
.thumb_set MWU_IRQHandler, Dummy_Handler
.weak PWM1_IRQHandler
.thumb_set PWM1_IRQHandler, Dummy_Handler
.weak PWM2_IRQHandler
.thumb_set PWM2_IRQHandler, Dummy_Handler
.weak SPIM2_SPIS2_SPI2_IRQHandler
.thumb_set SPIM2_SPIS2_SPI2_IRQHandler, Dummy_Handler
.weak RTC2_IRQHandler
.thumb_set RTC2_IRQHandler, Dummy_Handler
.weak I2S_IRQHandler
.thumb_set I2S_IRQHandler, Dummy_Handler
.weak FPU_IRQHandler
.thumb_set FPU_IRQHandler, Dummy_Handler
 * Reset Handler Extensions                                                         *
  .extern Reset_Handler
  .global nRFInitialize
  .extern afterInitialize
  .thumb_func
nRFInitialize:
  b afterInitialize
 * Vector Table        *
  .section .vectors, "ax"
  .align 0
  .global _vectors
  .extern __stack_end__
_vectors:
  .word __stack_end__
  .word Reset_Handler
  .word NMI_Handler
  .word HardFault_Handler
  .word MemoryManagement_Handler
  .word BusFault_Handler
  .word UsageFault_Handler
  .word 0                           /*Reserved */
  .word SVC_Handler
  .word DebugMon_Handler
  .word PendSV_Handler
  .word SysTick_Handler
/* External Interrupts */
  .word   POWER_CLOCK_IRQHandler
  .word   RADIO_IRQHandler
  .word   UARTE0_UART0_IRQHandler
  .word   SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQHandler
  .word   SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQHandler
  .word   NFCT_IRQHandler
  .word   GPIOTE_IRQHandler
  .word   SAADC_IRQHandler
  .word   TIMER0_IRQHandler
  .word   TIMER1_IRQHandler
  .word   TIMER2_IRQHandler
  .word   RTC0_IRQHandler
  .word   TEMP_IRQHandler
  .word   RNG_IRQHandler
  .word   ECB_IRQHandler
  .word   CCM_AAR_IRQHandler
  .word   WDT_IRQHandler
  .word   RTC1_IRQHandler
  .word   QDEC_IRQHandler
  .word   COMP_LPCOMP_IRQHandler
  .word   SWI0_EGU0_IRQHandler
  .word   SWI1_EGU1_IRQHandler
  .word   SWI2_EGU2_IRQHandler
  .word   SWI3_EGU3_IRQHandler
  .word   SWI4_EGU4_IRQHandler
  .word   SWI5_EGU5_IRQHandler
  .word   TIMER3_IRQHandler
  .word   TIMER4_IRQHandler
  .word   PWM0_IRQHandler
  .word   PDM_IRQHandler
  .word   MWU_IRQHandler
  .word   PWM1_IRQHandler
  .word   PWM2_IRQHandler
  .word   SPIM2_SPIS2_SPI2_IRQHandler
  .word   RTC2_IRQHandler
  .word   I2S_IRQHandler
  .word   FPU_IRQHandler
_vectors_end:
#ifdef VECTORS_IN_RAM
  .section .vectors_ram, "ax"
  .align 0
  .global _vectors_ram
_vectors_ram:
  .space _vectors_end - _vectors, 0
I updated sdk_config.h by enabling nfc until adding some of the nfc example to Mesh.
Code: https://github.com/joao-marcus/Mesh_light_dimming_NFC/tree/master/examples/experimental_dimming/dimming_client
I'm using the:  light_switch_dimming_client_nrf52832_xxAA_s132_7_0_1.emProject
Is there anything else that needs to be done to work?
Thank you in advance.
  • Thanks,
        I managed to solve, it was the NRFX_POWER_ENABLED that even disabled = 0 (sdk_config), the nrfx_power_clock file when checking the function - NRFX_CHECK (NRFX_POWER_ENABLED) considered enabled.
       I commented on the #if leaving only what I needed just like the example of the nfc Writable NDEF Message Example and it worked.
    #ifndef NRFX_POWER_CLOCK_H__
    #define NRFX_POWER_CLOCK_H__
    #include <nrfx.h>
    #ifdef __cplusplus
    extern "C" {
    __STATIC_INLINE void nrfx_power_clock_irq_init(void);
    #ifndef SUPPRESS_INLINE_IMPLEMENTATION
        uint8_t priority;
        #if NRFX_CHECK(NRFX_CLOCK_ENABLED)
        priority = NRFX_CLOCK_CONFIG_IRQ_PRIORITY;
    #else
        #error "This code is not supposed to be compiled when neither POWER nor CLOCK is enabled."
    //#if NRFX_CHECK(NRFX_POWER_ENABLED) && NRFX_CHECK(NRFX_CLOCK_ENABLED)                            //@todo JM
    //    #if NRFX_POWER_CONFIG_IRQ_PRIORITY != NRFX_CLOCK_CONFIG_IRQ_PRIORITY
    //    #error "IRQ priorities for POWER and CLOCK must be the same. Check <nrfx_config.h>."
    //    #endif
    //    priority = NRFX_POWER_CONFIG_IRQ_PRIORITY;
    //#elif NRFX_CHECK(NRFX_POWER_ENABLED)
    //#elif NRFX_CHECK(NRFX_CLOCK_ENABLED)
    //    priority = NRFX_CLOCK_CONFIG_IRQ_PRIORITY;
    //#else
    //    #error "This code is not supposed to be compiled when neither POWER nor CLOCK is enabled."
    //#endif
        if (!NRFX_IRQ_IS_ENABLED(nrfx_get_irq_number(NRF_CLOCK)))
            NRFX_IRQ_PRIORITY_SET(nrfx_get_irq_number(NRF_CLOCK), priority);
            NRFX_IRQ_ENABLE(nrfx_get_irq_number(NRF_CLOCK));
    #endif // SUPPRESS_INLINE_IMPLEMENTATION
    //void nrfx_power_clock_irq_handler(void);
    //#define nrfx_power_irq_handler  nrfx_power_clock_irq_handler
    #define nrfx_clock_irq_handler  nrfx_power_clock_irq_handler
    #ifdef __cplusplus
    //#endif // NRFX_POWER_CLOCK_H__
       In fact this NRFX_CHECK problem happened in several files, depending on the identifier in sdk_config the function returns the wrong value.
       Thank you so much for the help I was trying to solve a long time ago.
  • Glad to hear that it works now. Thanks for the update.
