I'm using the mesh example Dimming examples (experimental) in the nRF5 SDK for Mesh v4.0.0 and the nRF5 SDK v16.0.0 example Writable NDEF Message Example.
I was able to join the nfc library with the Mesh example, but when passing the phone to read the tag nothing happens and the software goes into a loop on line 112 of the code below:
* SEGGER Microcontroller GmbH *
* The Embedded Experts *
* (c) 2014 - 2018 SEGGER Microcontroller GmbH *
* www.segger.com Support: [email protected] *
* All rights reserved. *
* Redistribution and use in source and binary forms, with or *
* without modification, are permitted provided that the following *
* conditions are met: *
* - Redistributions of source code must retain the above copyright *
* notice, this list of conditions and the following disclaimer. *
* - Neither the name of SEGGER Microcontroller GmbH *
* nor the names of its contributors may be used to endorse or *
* promote products derived from this software without specific *
* prior written permission. *
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND *
* CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, *
* INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE *
* DISCLAIMED. *
* IN NO EVENT SHALL SEGGER Microcontroller GmbH BE LIABLE FOR *
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR *
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT *
* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF *
* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT *
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE *
* USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH *
* DAMAGE. *
* Preprocessor Definitions *
* VECTORS_IN_RAM *
* If defined, an area of RAM will large enough to store the vector table *
* will be reserved. *
.syntax unified
.code 16
.section .init, "ax"
.align 0
* Default Exception Handlers *
.thumb_func
.weak NMI_Handler
NMI_Handler:
b .
.thumb_func
.weak HardFault_Handler
HardFault_Handler:
b .
.thumb_func
.weak MemoryManagement_Handler
MemoryManagement_Handler:
b .
.thumb_func
.weak BusFault_Handler
BusFault_Handler:
b .
.thumb_func
.weak UsageFault_Handler
UsageFault_Handler:
b .
.thumb_func
.weak SVC_Handler
SVC_Handler:
b .
.thumb_func
.weak DebugMon_Handler
DebugMon_Handler:
b .
.thumb_func
.weak PendSV_Handler
PendSV_Handler:
b .
.thumb_func
.weak SysTick_Handler
SysTick_Handler:
b .
.thumb_func
.weak Dummy_Handler
Dummy_Handler:
b .
* Default Interrupt Handlers *
.weak POWER_CLOCK_IRQHandler
.thumb_set POWER_CLOCK_IRQHandler, Dummy_Handler
.weak RADIO_IRQHandler
.thumb_set RADIO_IRQHandler, Dummy_Handler
.weak UARTE0_UART0_IRQHandler
.thumb_set UARTE0_UART0_IRQHandler, Dummy_Handler
.weak SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQHandler
.thumb_set SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQHandler, Dummy_Handler
.weak SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQHandler
.thumb_set SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQHandler, Dummy_Handler
.weak NFCT_IRQHandler
.thumb_set NFCT_IRQHandler, Dummy_Handler
.weak GPIOTE_IRQHandler
.thumb_set GPIOTE_IRQHandler, Dummy_Handler
.weak SAADC_IRQHandler
.thumb_set SAADC_IRQHandler, Dummy_Handler
.weak TIMER0_IRQHandler
.thumb_set TIMER0_IRQHandler, Dummy_Handler
.weak TIMER1_IRQHandler
.thumb_set TIMER1_IRQHandler, Dummy_Handler
.weak TIMER2_IRQHandler
.thumb_set TIMER2_IRQHandler, Dummy_Handler
.weak RTC0_IRQHandler
.thumb_set RTC0_IRQHandler, Dummy_Handler
.weak TEMP_IRQHandler
.thumb_set TEMP_IRQHandler, Dummy_Handler
.weak RNG_IRQHandler
.thumb_set RNG_IRQHandler, Dummy_Handler
.weak ECB_IRQHandler
.thumb_set ECB_IRQHandler, Dummy_Handler
.weak CCM_AAR_IRQHandler
.thumb_set CCM_AAR_IRQHandler, Dummy_Handler
.weak WDT_IRQHandler
.thumb_set WDT_IRQHandler, Dummy_Handler
.weak RTC1_IRQHandler
.thumb_set RTC1_IRQHandler, Dummy_Handler
.weak QDEC_IRQHandler
.thumb_set QDEC_IRQHandler, Dummy_Handler
.weak COMP_LPCOMP_IRQHandler
.thumb_set COMP_LPCOMP_IRQHandler, Dummy_Handler
.weak SWI0_EGU0_IRQHandler
.thumb_set SWI0_EGU0_IRQHandler, Dummy_Handler
.weak SWI1_EGU1_IRQHandler
.thumb_set SWI1_EGU1_IRQHandler, Dummy_Handler
.weak SWI2_EGU2_IRQHandler
.thumb_set SWI2_EGU2_IRQHandler, Dummy_Handler
.weak SWI3_EGU3_IRQHandler
.thumb_set SWI3_EGU3_IRQHandler, Dummy_Handler
.weak SWI4_EGU4_IRQHandler
.thumb_set SWI4_EGU4_IRQHandler, Dummy_Handler
.weak SWI5_EGU5_IRQHandler
.thumb_set SWI5_EGU5_IRQHandler, Dummy_Handler
.weak TIMER3_IRQHandler
.thumb_set TIMER3_IRQHandler, Dummy_Handler
.weak TIMER4_IRQHandler
.thumb_set TIMER4_IRQHandler, Dummy_Handler
.weak PWM0_IRQHandler
.thumb_set PWM0_IRQHandler, Dummy_Handler
.weak PDM_IRQHandler
.thumb_set PDM_IRQHandler, Dummy_Handler
.weak MWU_IRQHandler
.thumb_set MWU_IRQHandler, Dummy_Handler
.weak PWM1_IRQHandler
.thumb_set PWM1_IRQHandler, Dummy_Handler
.weak PWM2_IRQHandler
.thumb_set PWM2_IRQHandler, Dummy_Handler
.weak SPIM2_SPIS2_SPI2_IRQHandler
.thumb_set SPIM2_SPIS2_SPI2_IRQHandler, Dummy_Handler
.weak RTC2_IRQHandler
.thumb_set RTC2_IRQHandler, Dummy_Handler
.weak I2S_IRQHandler
.thumb_set I2S_IRQHandler, Dummy_Handler
.weak FPU_IRQHandler
.thumb_set FPU_IRQHandler, Dummy_Handler
* Reset Handler Extensions *
.extern Reset_Handler
.global nRFInitialize
.extern afterInitialize
.thumb_func
nRFInitialize:
b afterInitialize
* Vector Table *
.section .vectors, "ax"
.align 0
.global _vectors
.extern __stack_end__
_vectors:
.word __stack_end__
.word Reset_Handler
.word NMI_Handler
.word HardFault_Handler
.word MemoryManagement_Handler
.word BusFault_Handler
.word UsageFault_Handler
.word 0 /*Reserved */
.word SVC_Handler
.word DebugMon_Handler
.word PendSV_Handler
.word SysTick_Handler
/* External Interrupts */
.word POWER_CLOCK_IRQHandler
.word RADIO_IRQHandler
.word UARTE0_UART0_IRQHandler
.word SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQHandler
.word SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQHandler
.word NFCT_IRQHandler
.word GPIOTE_IRQHandler
.word SAADC_IRQHandler
.word TIMER0_IRQHandler
.word TIMER1_IRQHandler
.word TIMER2_IRQHandler
.word RTC0_IRQHandler
.word TEMP_IRQHandler
.word RNG_IRQHandler
.word ECB_IRQHandler
.word CCM_AAR_IRQHandler
.word WDT_IRQHandler
.word RTC1_IRQHandler
.word QDEC_IRQHandler
.word COMP_LPCOMP_IRQHandler
.word SWI0_EGU0_IRQHandler
.word SWI1_EGU1_IRQHandler
.word SWI2_EGU2_IRQHandler
.word SWI3_EGU3_IRQHandler
.word SWI4_EGU4_IRQHandler
.word SWI5_EGU5_IRQHandler
.word TIMER3_IRQHandler
.word TIMER4_IRQHandler
.word PWM0_IRQHandler
.word PDM_IRQHandler
.word MWU_IRQHandler
.word PWM1_IRQHandler
.word PWM2_IRQHandler
.word SPIM2_SPIS2_SPI2_IRQHandler
.word RTC2_IRQHandler
.word I2S_IRQHandler
.word FPU_IRQHandler
_vectors_end:
#ifdef VECTORS_IN_RAM
.section .vectors_ram, "ax"
.align 0
.global _vectors_ram
_vectors_ram:
.space _vectors_end - _vectors, 0
I updated sdk_config.h by enabling nfc until adding some of the nfc example to Mesh.
I'm using the: light_switch_dimming_client_nrf52832_xxAA_s132_7_0_1.emProject
Is there anything else that needs to be done to work?
Thank you in advance.
