Quickest path to BLE data exchange...
Given the too many examples in the nRF5 SDK that are provided to implement BLE and the unclear documentation on how to best proceed, what would you say is the quickest path to begin development of a bidirectional data transmission in a BLE embedded device? I am seeking to transmit small chunks of proprietary data (maybe 100 bytes/sec) from an embedded device and have it received by another embedded device in close proximity then send the data from the second embedded device on to an iPhone also very close by. I need bidirectional data from iPhone to second device to first device as well, so a two way data stream. Make sense?
I am using v16 (latest I believe) of the nRF5 SDK on an nRF52832.
Kevin
  • Thanks Darren. Actually Device 1 will transmit data to Device 2. Device 2 will receive Device 1's data and do some calculations and transmit to the iPhone. However we need bidirectional data channels open between all devices, ideally. So Device 1 will Tx and Rx to 2 and Device 2 will Tx and Rx to Device 1. And Device 2 will also Tx and Rx to the iPhone. In this situation, what would you say are good starting projects for Device 1 and Device 2?
  • Hi Torbjørn. It occurs to me that the starting projects I need are: a two device BLE communications system where a device (either device) can say "I have some data for you" and can push their data to the other device (likely using an interrupt on the Rx end). At the same time, each device can also send a "pull" data request to the other device when it has some data ready for the other end (again probably in an interrupt notification situation). This would all be irrespective of who is the central and who is the peripheral - either can be I think, however one device also needs bidirectional communications with the iPhone sending and receiving data as needed.
    IOW: Device A (or B) has some data for Device B (or A) and sends out a push notification. Device B (or A) responds "OK I'm listening" and starts receiving the data. Later on, Device A (or B) needs some data from Device B (or A) and sends out a "please fulfill data" request. Device B (or A) then sends out the requested data. In this situation I'm not sure who is the central and who is the peripheral and it might not matter, however one of the devices, say Device B needs to also be able to send and receive data to the iPhone app.
    So I am looking for two good starting embedded projects for such communications setup. What would you recommend given all the sample apps?
    Make sense? Thanks!
  • Hi Kevin
    It sounds to me like you need one device (B?) to be connected to both device A and the phone at the same time, while device A only needs to connect to device B.
    In this case device B will need to be both central and peripheral at the same time, acting as a central towards device A, and as a peripheral to the phone.
    The client/server relationship is actually independent of the central/peripheral relationship, but the most common configuration is to have the central be the client and the peripheral be the server, and when using the NUS service this is the configuration I would recommend.
    Then you are looking at a total system where you have a phone being the central/client towards device B.
    Device B is a peripheral/server towards the phone while also being a central/client towards device A.
    Device A is a peripheral/server towards device B.
    The phone would be able to use the standard apps, and device A could use the ble_app_uart example, while device B would have to use a combination of the ble_app_uart and ble_app_uart_c examples.
    You can send data whenever you want on both the client and server side of the link.
    The client would use write commands to send data, while the server would use notifications.
    Best regards
    Torbjørn
  • Excellent Torbjørn. Thank You. So on Device B I need to manually mix the relevant code from the ble_app_uart and ble_app_uart_c examples, right? Is there an existing code base that already does this so I don't have to reinvent the wheel, perhaps an example starting project inside of Nordic for the dual capability of Device B?
    Thanks so much.
  • Hi Kevin
    Essentially you have to copy all the client specific code from the ble_app_uart_c example into the ble_app_uart examples, yes, or vice versa.
    You would also have to change the NRF_SDH_BLE_PERIPHERAL_LINK_COUNT, NRF_SDH_BLE_CENTRAL_LINK_COUNT and NRF_SDH_BLE_TOTAL_LINK_COUNT defines in sdk_config.h to allow for more links than what the examples support out of the box.
    There is no example out of the box showing how to do this unfortunately.
    The closest in the SDK would be the ble_app_hrs_rscs_relay example in the examples/ble_central_and_peripheral/experimental folder.
    This example essentially does the same thing, but uses different services.
    Best regards
    Torbjørn
