Dfu not sucess when app init and enable wdt,although I feeddog and disable the wdt
Dear Nordic
my SOFT DFU fail when I init the WDT, but I have feeddog and disable the WDT, like below:
static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_DFU:
NRF_LOG_INFO("Power management wants to reset to DFU mode.");
// YOUR_JOB: Get ready to reset into DFU mode
// If you aren't finished with any ongoing tasks, return "false" to
// signal to the system that reset is impossible at this stage.
// Here is an example using a variable to delay resetting the device.
// if (!m_ready_for_reset)
// return false;
// else
// // Device ready to enter
// uint32_t err_code;
// err_code = sd_softdevice_disable();
// APP_ERROR_CHECK(err_code);
// err_code = app_timer_stop_all();
// YOUR_JOB: Implement any of the other events available from the power management module:
// -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
// -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
// -NRF_PWR_MGMT_EVT_PREPARE_RESET
return true;
NRF_LOG_INFO("Power management allowed to reset to DFU mode.");
nrf_drv_wdt_feed();
nrf_wdt_int_disable(NRF_WDT_INT_TIMEOUT_MASK);
//nrf_wdt_int_enable(NRF_WDT_INT_TIMEOUT_MASK);
return true;
I don't know why nrf_wdt_int_disable is un-useful.
but if I don't init wdt in main, dfu is ok.
thanks for support.
Roger Huang
