UICR for the nRF21540 is one time programmable
I have two questions about the nRF21540.
(Is it for AoA / AoD?)
Why are there two antenna outputs on the nRF21540?
It is provided for the possibility to perform antenna diversity.
If the UICR program is below 3.45V, doesn't it work or can't store the value?
Please follow the requirements as listed in the PS: https://infocenter.nordicsemi.com/topic/ps_nrf21540/chapters/device_control/doc/uicr_program.html?cp=6_0_0_4_3
UICR for the nRF21540 is one time programmable, and if you do not follow the requirements in terms of voltage, it is not guaranteed that the program is successfully stored and the device may not function as you want it to.
Håkon
Sorry, I should have been more specific. The UICR eFuse is one time progarmmable, as it locks the "reset value" of the device. You can write new configuration, but it is not retained after a power cycle.
Cheers,
Håkon
Hi Hakon
I'm confused!
Does it mean I can write new value into CONFREG2 and CONFREG3 in UICR program mode after power cycle?
After power cycle, if I read CONFREG2 and CONFREG3 before write value into these register, I will get 0x00 from its, right?
Thanks.
BR
Atlas
