Bidirectional throughput analysis with nrf52840 and Android
Hello Team,
Currently, we are evaluating nRF52 using nRF52840DK for one of our upcoming project. Basically, our typical application involves sending 32 Bytes of command data from Android to nRF52 and getting 256 bytes from nRF52 to Android.
Considering this, we have taken the Android application “nRF UART Version 2.0” and the Firmware example “ble_app_att_mtu_throughput” as a reference and slightly modified them to perform sending the following sample commands from the Android application and handling the same from the nRF device FW.
100k
Instructs the nRF device to send 100KB data to the mobile device.
Used to test and simulate unidirectional throughput of the nRF device.
m100k
Instructs the Android tool to send 100KB data to the nRF device.
Used to test and simulate unidirectional througput of the mobile device.
10k 32
Instructs the nRF device to send 10KB data to the mobile device. During the transfer, the mobile device sends 32 bytes for every packet (244 bytes) that it receives.
Used to test and simulate bidirectional throughput.
10k 32 w30 w20
Instructs the nRF device to send 10KB data to the mobile device. During the transfer, the mobile device sends 32 bytes for every packet (244 bytes) that it receives; the nRF device performs a delay of 30 ms before sending every packet; the mobile device performs a delay of 20 ms before sending every 32 bytes.
Used to test and simulate bidirectional throughput with delays.
Command flow:
If we take the bidirectional transfer scenario of “10k 32” the overall application flow would be:
1 - The Android application writes 32 bytes to the write characteristic
2 - nRF FW gets a write callback on nrf_ble_amts_on_ble_evt() which is registered as NRF_SDH_BLE_OBSERVER
3 - Immediately the nRF52 FW calls char_notification_send(), to push 244 bytes as notification to the Android application
4- The Android application gets onCharacteristicChanged() from BluetoothGattCallback.
5 - Again the Android application performs Step-1. And this loop continues until 10k data is retrieved from the nRF device.
For information:
To send data from Android to nRF52, the system uses write without response and
To send data from nRF52 to Android, the system uses notification.
The Android application and the FW supports all transfer data lengths up to 1000K and delays up to 100ms.
While connecting to the “Nordic_ATT_MTU” from the Android application, we could see the connection parameters being updated in the nRF device by connecting the board to a putty/terminal window.
Observation:
By performing these test commands with a Samsung S10 running on Android 10, with BLE 5.0 parameters 2M PHY, 251 byte DLE, 247 bye MTU and connection interval 11.25 ms, here is our observation:
100k ==> 1201 kbps at 682 ms (nRF side) and 1168 kbps at 697 ms (App side)
m100k ==> 331 kbps at 2.473(nRF side) and 480 kbps at 1.707 s(App side)
10k 244 ==> 72.68 kbps at 1.128 sec (nRF side) and 64 kbps at 1.199 sec (App side)
10k 244 w30 w20 ==> 22 kbps at 3.627 sec (nRF side) and 16 kbps at 3.776 sec (App side)
Question:
From the above results, we observe that,
  • the unidirectional throughput from the nRF device (1201 kbps) is reaching the theoretical maximum (1400 kbps).
  • the unidirectional throughput from the Android device (480 kbps) is 65% slower than the theoretical maximum. We could not understand the reason for this drop.
  • the bidirectional throughput is more than 85% slower than the theoretical maximum. We could not understand the reason for this “drastic drop”.
Hereby we have attached our Android apk and the nRF FW binary for reference. Could you please guide us on the possible ways to improve the throughput for the bidirectional transfer case?
nRF uart v2.0.apkble_app_att_mtu_throughput_pca10056_s140.hex
