DFU SDK v16 on Mac OS X
Hi,  I am trying to get DFU from SDK16 working on my Mac.(Mac Os Mojave).  I am following the instruction on https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_nrf5_v16.0.0%2Fble_sdk_app_dfu_bootloader.html
I have tried first to build the micro-eco library by clicking on the build_all.bat file and got the following errors from the Terminal.app:
SLMini-I5-172:~ slareau$ /Users/slareau/nrf52_development/nRF5_SDK_16/external/micro-ecc/build_all.bat ; exit;
/Users/slareau/nrf52_development/nRF5_SDK_16/external/micro-ecc/build_all.bat: line 1: @ECHO: command not found
/Users/slareau/nrf52_development/nRF5_SDK_16/external/micro-ecc/build_all.bat: l: command not found
/Users/slareau/nrf52_development/nRF5_SDK_16/external/micro-ecc/build_all.bat: line 3: syntax error near unexpected token `('
/Users/slareau/nrf52_development/nRF5_SDK_16/external/micro-ecc/build_all.bat: line 3: `:: This script will use git (must be in %PATH%) and arm-none-eabi tools 'n combination with GNU Make
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
To solve that step, I have navigate to the micro.ecc folder in terminal.  I have open the build_all.bat file in TexEdit ,  copy and paste the following command directly in Terminal.app
git clone https://github.com/kmackay/micro-ecc.git
and then
make -C nrf52hf_armgcc/armgcc      // I believe that  the only one that I need for my project
This work perfectly.
I have tried to generate a public and private key with nrf_util.  I have done that without problem in SDK14.3
nrf_util ask me to upgrade to the latest version with I did.
In Terminal.app  I have navigate to the dfu folder where I want the key to be generated and type the command :
nrfutil keys generate priv.perm
I have the following problems :
SLMini-I5-172:dfu slareau$ nrfutil keys generate priv.perm
  File "/Library/Frameworks/Python.framework/Versions/3.7/bin/nrfutil", line 11, in <module>
    load_entry_point('nrfutil==6.0.1', 'console_scripts', 'nrfutil')()
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/pkg_resources/__init__.py", line 490, in load_entry_point
    return get_distribution(dist).load_entry_point(group, name)
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/pkg_resources/__init__.py", line 2853, in load_entry_point
    return ep.load()
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/pkg_resources/__init__.py", line 2444, in load
    return self.resolve()
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/pkg_resources/__init__.py", line 2450, in resolve
    module = __import__(self.module_name, fromlist=['__name__'], level=0)
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/nordicsemi/__main__.py", line 52, in <module>
    from nordicsemi.dfu.dfu_transport_serial import DfuTransportSerial
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/nordicsemi/dfu/dfu_transport_serial.py", line 53, in <module>
    from nordicsemi.dfu.dfu_trigger import DFUTrigger
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/nordicsemi/dfu/dfu_trigger.py", line 48, in <module>
    import usb1
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/usb1/__init__.py", line 61, in <module>
    from . import libusb1
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/usb1/libusb1.py", line 199, in <module>
    libusb = _loadLibrary()
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/usb1/libusb1.py", line 173, in _loadLibrary
    return dll_loader('libusb-1.0' + suffix, **loader_kw)
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/ctypes/__init__.py", line 364, in __init__
    self._handle = _dlopen(self._name, mode)
OSError: dlopen(libusb-1.0.dylib, 6): image not found
It seems to have found the /libusb1   but not the libusb library.
In Terminal.app I type :  pip install libusb
SLMini-I5-172:dfu slareau$ pip install libusb
Requirement already satisfied: libusb in /Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages (1.0.22b9)
Requirement already satisfied: setuptools>=42.0.2 in /Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages (from libusb) (45.1.0)
Requirement already satisfied: atpublic>=1.0.0 in /Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages (from libusb) (1.0)
and the package seems to be install correctly.
Here a creenshoot of the folder
At this point, I am not sure what is the next step.
  • I have just notice that nrfutil come with the libusb package.  have tried to reinstall nrfutil with the following command as stated in the nrfutil v1.3 document find on the web:When installing on macOS, you might get an error about the Python module six. In this case, enter the following command instead
    pip install --ignore-installed six nrfutil
    When generating the private key, I still have the same error :
  • Following the instruction, I have download tnrfutil installation pkg from Github.
    In Terminal.app I navigate to the folder and type : pip install -r requirements.txt
    Listing says that all requierent were satisfied, except this line :
       Ignoring antlib: markers 'sys_platform == "win32"' don't match your environment
    I  assume that Ok, its a Mac.
    I have tried to run nrf_util without installation and this append:
     SLMini-I5-172:pc-nrfutil-master slareau$ python nordicsemi/__main__.py
      File "nordicsemi/__main__.py", line 43, in <module>
        import click
    ImportError: No module named click
    I ran instead python3 command (not in the instruction):  python3 nordicsemi/__main__.py
    SLMini-I5-172:pc-nrfutil-master slareau$ python3 nordicsemi/__main__.py
      File "nordicsemi/__main__.py", line 52, in <module>
        import usb1
    The // OSError: dlopen(libusb-1.0.dylib, 6): image not found // is the one I got previously - see beginning of the post
    To install nrfutil, the python setup.py install does not work - it try to install the program with python 2.7 framework.  I had to use python3 setup.py install
    and then got  the error at the end of a long list:
    error: [Errno 13] Permission denied: '/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/easy-install.pth'
    I had to use the command: sudo python3 setup.py install,  and it work.
    I have then tried to run the command : pyinstaller nrfutil.spec
    and the command was not found.
    SLMini-I5-172:pc-nrfutil-master slareau$ pyinstaller nrfutil.spec
    -bash: pyinstaller: command not found
    Typing the command: nrfutil -- help    give and a long list ending by the following error:
    Could it be that a file is misplace during the installation ? Please look at the screenshot.
  • Specific installation instruction for OsX would be nice since command differ from what is in the instruction.
    Had to use sudo and python3.
  • After the install command, I had the following warning , but the rest of the processs seems OK.
    SLMini-I5-172:pc-nrfutil-master slareau$ sudo python3 setup.py install
    /Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/distutils/dist.py:274: UserWarning: Unknown distribution option: 'zipfile'
      warnings.warn(msg)
    /Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/distutils/dist.py:274: UserWarning: Unknown distribution option: 'console'
      warnings.warn(msg)
    running install.....
