Hello people,
As the tittle states, I'm looking for a way to simply enable the GPS module in the thingy:91.
I'm working in the tag v1.1.0
I've been tryng to force with a function like this one:
void force_gps(void) {
if (!atomic_get(&send_data_enable)) {
printk("Link not ready, long press disregarded\n");
return;
printk("Starting GPS\n");
gps_control_enable();
gps_control_start(K_SECONDS(1));
According to what I saw in the code:
static void long_press_handler(struct k_work *work)
return;
if (gps_control_is_enabled()) {
printk("Stopping GPS\n");
gps_control_disable();
} else {
And this is where I am calling the function:
void cloud_event_handler(const struct cloud_backend *const backend,
const struct cloud_event *const evt,
void *user_data)
ARG_UNUSED(user_data);
switch (evt->type) {
case CLOUD_EVT_CONNECTED:
printk("CLOUD_EVT_CONNECTED\n");
k_delayed_work_cancel(&cloud_reboot_work);
ui_led_set_pattern(UI_CLOUD_CONNECTED);
case CLOUD_EVT_READY:
printk("CLOUD_EVT_READY\n");
#if defined(CONFIG_BOOTLOADER_MCUBOOT)
/* Mark image as good to avoid rolling back after update */
boot_write_img_confirmed();
sensors_start();
// activate gps func
k_sleep(20000);
force_gps();
///............... a lot more code
My real question is: Is the GPS module be able to activate it propperly at startup by setting something different in the code like the .config file?
