Read multi characteristics from the peripheral as a central
I'm workin with custom nrf52832 and sdk15.0.0, so to work with the central , i chose the example :ble_app_blinky_c .
I modife the code to control my custom characteristics , and read my custom characteristics, but when i want to read multi characteristics, I'm confused how i should do it by duplicat everythin onhvx and the uuid or what so please guide me to the do it simple
  • Not sure if I have any recommendation here in specific. I assume you need to have a array of some sort that have an overview of the number of active links (connection handles) and notification handles. Then each time you receive a notification from the peer you can do a lookup in the array which characteristic that sent the notification.
    Alternatively you can just add data (e.g. use a header in the data) to the notification, such that the application just parse the notification itself to find the characteristic.
    Kenneth
  • sorry I didnt get you
    here is my code based on the ble_app_blinky_c  nothing changed only the uuid .
    please explain where i shoud do the things or what am i suposed to do cause its confusing example .
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief BLE LED Button Service central and client application main file.
     * This file contains the source code for a sample client application using the LED Button service.
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_timer.h"
    #include "boards.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_db_discovery.h"
    //#include "ble_lbs_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_delay.h"
    #include "our_central.h"
    #define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0                     /**< Scanning LED will be on when the device is scanning. */
    #define CENTRAL_CONNECTED_LED           7                     /**< Connected LED will be on when the device is connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                     /**< LED to indicate a change of state of the the Button characteristic on the peer. */
    #define SCAN_INTERVAL                   0x00A0                              /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW                     0x0050                              /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_DURATION                   0x0000                              /**< Timout when scanning. 0x0000 disables timeout. */
    #define MIN_CONNECTION_INTERVAL         MSEC_TO_UNITS(7.5, UNIT_1_25_MS)    /**< Determines minimum connection interval in milliseconds. */
    #define MAX_CONNECTION_INTERVAL         MSEC_TO_UNITS(30, UNIT_1_25_MS)     /**< Determines maximum connection interval in milliseconds. */
    #define SLAVE_LATENCY                   0                                   /**< Determines slave latency in terms of connection events. */
    #define SUPERVISION_TIMEOUT             MSEC_TO_UNITS(4000, UNIT_10_MS)     /**< Determines supervision time-out in units of 10 milliseconds. */
    #define LEDBUTTON_BUTTON_PIN            8                        /**< Button that will write to the LED characteristic of the peer */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                 /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define APP_BLE_CONN_CFG_TAG            1                                   /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_OBSERVER_PRIO           3                                   /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    BLE_LBS_C_DEF(m_ble_lbs_c);                                     /**< Main structure used by the LBS client module. */
    NRF_BLE_GATT_DEF(m_gatt);                                       /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                /**< DB discovery module instance. */
    static char const m_target_periph_name[] = "Casky_External";     /**< Name of the device we try to connect to. This name is searched in the scan report data*/
    /**@brief Parameters used when scanning. */
    static ble_gap_scan_params_t const m_scan_params =
        .active   = 1,
        .interval = SCAN_INTERVAL,
        .window   = SCAN_WINDOW,
        .timeout           = SCAN_DURATION,
        .scan_phys         = BLE_GAP_PHY_1MBPS,
        .filter_policy     = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
    /**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
    static ble_data_t m_scan_buffer =
        m_scan_buffer_data,
    /**@brief Connection parameters requested for connection. */
    static ble_gap_conn_params_t const m_connection_param =
        (uint16_t)MIN_CONNECTION_INTERVAL,
        (uint16_t)MAX_CONNECTION_INTERVAL,
        (uint16_t)SLAVE_LATENCY,
        (uint16_t)SUPERVISION_TIMEOUT
    /**@brief Function to handle asserts in the SoftDevice.
     * @param[in] line_num     Line number of the failing ASSERT call.
     * @param[in] p_file_name  File name of the failing ASSERT call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function to start scanning.
    static void scan_start(void)
        ret_code_t err_code;
        (void) sd_ble_gap_scan_stop();
        err_code = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
        bsp_board_led_off(CENTRAL_CONNECTED_LED);
        bsp_board_led_on(CENTRAL_SCANNING_LED);
    /**@brief Handles events coming from the LED Button central module.
    static void lbs_c_evt_handler(ble_lbs_c_t * p_lbs_c, ble_lbs_c_evt_t * p_lbs_c_evt)
        switch (p_lbs_c_evt->evt_type)
            case BLE_LBS_C_EVT_DISCOVERY_COMPLETE:
                err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c,
                                                    p_lbs_c_evt->conn_handle,
                                                    &p_lbs_c_evt->params.peer_db);
                printf("LED Button service discovered on conn_handle 0x%x.\n", p_lbs_c_evt->conn_handle);
                err_code = app_button_enable();
                // LED Button service discovered. Enable notification of Button.
                err_code = ble_lbs_c_button_notif_enable(p_lbs_c);
            } break; // BLE_LBS_C_EVT_DISCOVERY_COMPLETE
            case BLE_LBS_C_EVT_BUTTON_NOTIFICATION:
                printf("Button state changed on peer to 0x%x \n", p_lbs_c_evt->params.button.button_state);
                if (p_lbs_c_evt->params.button.button_state)
                    bsp_board_led_on(LEDBUTTON_LED);
                    bsp_board_led_off(LEDBUTTON_LED);
            } break; // BLE_LBS_C_EVT_BUTTON_NOTIFICATION
                // No implementation needed.
    /**@brief Function for handling the advertising report BLE event.
     * @param[in] p_adv_report  Advertising report from the SoftDevice.
    static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
        if (ble_advdata_name_find(p_adv_report->data.p_data,
                                  p_adv_report->data.len,
                                  m_target_periph_name))
            // Name is a match, initiate connection.
            err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                          &m_scan_params,
                                          &m_connection_param,
                                          APP_BLE_CONN_CFG_TAG);
            printf("matched\n");
            err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
        // For readability.
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            // Upon connection, check which peripheral has connected (HR or RSC), initiate DB
            // discovery, update LEDs status and resume scanning if necessary. */
            case BLE_GAP_EVT_CONNECTED:
                printf("Connected.");
                err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c, p_gap_evt->conn_handle, NULL);
                err_code = ble_db_discovery_start(&m_db_disc, p_gap_evt->conn_handle);
                // Update LEDs status, and check if we should be looking for more
                // peripherals to connect to.
                bsp_board_led_on(CENTRAL_CONNECTED_LED);
                bsp_board_led_off(CENTRAL_SCANNING_LED);
            } break;
            // Upon disconnection, reset the connection handle of the peer which disconnected, update
            // the LEDs status and start scanning again.
                printf("Disconnected.");
                scan_start();
            } break;
            case BLE_GAP_EVT_ADV_REPORT:
                on_adv_report(&p_gap_evt->params.adv_report);
            } break;
            case BLE_GAP_EVT_TIMEOUT:
                // We have not specified a timeout for scanning, so only connection attemps can timeout.
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_DEBUG("Connection request timed out.");
            } break;
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accept parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                            &p_gap_evt->params.conn_param_update_request.conn_params);
            } break;
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            } break;
            case BLE_GATTS_EVT_TIMEOUT:
            } break;
    /**@brief LED Button client initialization.
    static void lbs_c_init(void)
        ble_lbs_c_init_t lbs_c_init_obj;
        lbs_c_init_obj.evt_handler = lbs_c_evt_handler;
        err_code = ble_lbs_c_init(&m_ble_lbs_c, &lbs_c_init_obj);
     * @details Initializes the SoftDevice and the BLE event interrupts.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON_PIN:
                err_code = ble_lbs_led_status_send(&m_ble_lbs_c, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE)
                if (err_code == NRF_SUCCESS)
                    printf("LBS write LED state %d \n", button_action);
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_lbs_on_db_disc_evt(&m_ble_lbs_c, p_evt);
    /**@brief Database discovery initialization.
    static void db_discovery_init(void)
        ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    /**@brief Function for initializing the log.
    static void log_init(void)
    /**@brief Function for initializing the timer.
    static void timer_init(void)
    /**@brief Function for initializing the Power manager. */
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Handle any pending log operation(s), then sleep until the next event occurs.
        NRF_LOG_FLUSH();
        nrf_pwr_mgmt_run();
        // Initialize.
        log_init();
        timer_init();
        leds_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        gatt_init();
        db_discovery_init();
        lbs_c_init();
        // Start execution.
        printf("Blinky CENTRAL example started.\n");
        scan_start();
        // Turn on the LED to signal scanning.
    while(true){
        // ble_lbs_led_status_send(&m_ble_lbs_c, 0x01);
        //     nrf_delay_ms(10000);
        // Enter main loop.
        for (;;)
            idle_state_handle();
     * Copyright (c) 2012 - 2018, Nordic Semiconductor ASA
    #include "sdk_common.h"
    #if NRF_MODULE_ENABLED(BLE_LBS_C)
    #include "ble_types.h"
    #include "ble_srv_common.h"
    #include "ble_gattc.h"
    #define NRF_LOG_MODULE_NAME ble_lbs_c
    NRF_LOG_MODULE_REGISTER();
    #define TX_BUFFER_MASK         0x07                  /**< TX Buffer mask, must be a mask of continuous zeroes, followed by continuous sequence of ones: 000...111. */
    #define TX_BUFFER_SIZE         (TX_BUFFER_MASK + 1)  /**< Size of send buffer, which is 1 higher than the mask. */
    #define WRITE_MESSAGE_LENGTH   BLE_CCCD_VALUE_LEN    /**< Length of the write message for CCCD. */
    typedef enum
        READ_REQ,  /**< Type identifying that this tx_message is a read request. */
        WRITE_REQ  /**< Type identifying that this tx_message is a write request. */
    } tx_request_t;
    /**@brief Structure for writing a message to the peer, i.e. CCCD.
    typedef struct
        uint8_t                  gattc_value[WRITE_MESSAGE_LENGTH];  /**< The message to write. */
        ble_gattc_write_params_t gattc_params;                       /**< GATTC parameters for this message. */
    } write_params_t;
    /**@brief Structure for holding data to be transmitted to the connected central.
    typedef struct
        uint16_t     conn_handle;  /**< Connection handle to be used when transmitting this message. */
        tx_request_t type;         /**< Type of this message, i.e. read or write message. */
        union
            uint16_t       read_handle;  /**< Read request message. */
            write_params_t write_req;    /**< Write request message. */
        } req;
    } tx_message_t;
    static tx_message_t m_tx_buffer[TX_BUFFER_SIZE];  /**< Transmit buffer for messages to be transmitted to the central. */
    static uint32_t     m_tx_insert_index = 0;        /**< Current index in the transmit buffer where the next message should be inserted. */
    static uint32_t     m_tx_index = 0;               /**< Current index in the transmit buffer from where the next message to be transmitted resides. */
    /**@brief Function for passing any pending request from the buffer to the stack.
    static void tx_buffer_process(void)
        if (m_tx_index != m_tx_insert_index)
            uint32_t err_code;
            if (m_tx_buffer[m_tx_index].type == READ_REQ)
                err_code = sd_ble_gattc_read(m_tx_buffer[m_tx_index].conn_handle,
                                             m_tx_buffer[m_tx_index].req.read_handle,
                                             0);
                err_code = sd_ble_gattc_write(m_tx_buffer[m_tx_index].conn_handle,
                                              &m_tx_buffer[m_tx_index].req.write_req.gattc_params);
                printf("SD Read/Write API returns Success..\n");
                m_tx_index++;
                m_tx_index &= TX_BUFFER_MASK;
                printf("SD Read/Write API returns error. This message sending will be "
                    "attempted again..\n");
    /**@brief Function for handling write response events.
     * @param[in] p_ble_lbs_c Pointer to the Led Button Client structure.
     * @param[in] p_ble_evt   Pointer to the BLE event received.
    static void on_write_rsp(ble_lbs_c_t * p_ble_lbs_c, ble_evt_t const * p_ble_evt)
        // Check if the event if on the link for this instance
        if (p_ble_lbs_c->conn_handle != p_ble_evt->evt.gattc_evt.conn_handle)
            return;
        // Check if there is any message to be sent across to the peer and send it.
        tx_buffer_process();
    /**@brief Function for handling Handle Value Notification received from the SoftDevice.
     * @details This function will uses the Handle Value Notification received from the SoftDevice
     *          and checks if it is a notification of Button state from the peer. If
     *          it is, this function will decode the state of the button and send it to the
     *          application.
    static void on_hvx(ble_lbs_c_t * p_ble_lbs_c, ble_evt_t const * p_ble_evt)
        // Check if the event is on the link for this instance
            return;
        // Check if this is a Button notification.
        if (p_ble_evt->evt.gattc_evt.params.hvx.handle == p_ble_lbs_c->peer_lbs_db.button_handle)
            if (p_ble_evt->evt.gattc_evt.params.hvx.len == 4)
                ble_lbs_c_evt_t ble_lbs_c_evt;
                ble_lbs_c_evt.evt_type                   = BLE_LBS_C_EVT_BUTTON_NOTIFICATION;
                ble_lbs_c_evt.conn_handle                = p_ble_lbs_c->conn_handle;
                ble_lbs_c_evt.params.button.button_state = p_ble_evt->evt.gattc_evt.params.hvx.data[0];
                p_ble_lbs_c->evt_handler(p_ble_lbs_c, &ble_lbs_c_evt);
    /**@brief Function for handling Disconnected event received from the SoftDevice.
     * @details This function check if the disconnect event is happening on the link
     *          associated with the current instance of the module, if so it will set its
     *          conn_handle to invalid.
    static void on_disconnected(ble_lbs_c_t * p_ble_lbs_c, ble_evt_t const * p_ble_evt)
        if (p_ble_lbs_c->conn_handle == p_ble_evt->evt.gap_evt.conn_handle)
            p_ble_lbs_c->conn_handle                    = BLE_CONN_HANDLE_INVALID;
            p_ble_lbs_c->peer_lbs_db.button_cccd_handle = BLE_GATT_HANDLE_INVALID;
            p_ble_lbs_c->peer_lbs_db.button_handle      = BLE_GATT_HANDLE_INVALID;
            p_ble_lbs_c->peer_lbs_db.led_handle         = BLE_GATT_HANDLE_INVALID;
    void ble_lbs_on_db_disc_evt(ble_lbs_c_t * p_ble_lbs_c, ble_db_discovery_evt_t const * p_evt)
        // Check if the Led Button Service was discovered.
        if (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE &&
            p_evt->params.discovered_db.srv_uuid.uuid == LBS_UUID &&
            p_evt->params.discovered_db.srv_uuid.type == p_ble_lbs_c->uuid_type)
            ble_lbs_c_evt_t evt;
            evt.evt_type    = BLE_LBS_C_EVT_DISCOVERY_COMPLETE;
            evt.conn_handle = p_evt->conn_handle;
            for (uint32_t i = 0; i < p_evt->params.discovered_db.char_count; i++)
                const ble_gatt_db_char_t * p_char = &(p_evt->params.discovered_db.charateristics[i]);
                switch (p_char->characteristic.uuid.uuid)
                    case LBS_UUID_LED_CHAR:
                        evt.params.peer_db.led_handle = p_char->characteristic.handle_value;
                    case LBS_UUID_BUTTON_CHAR:
                        evt.params.peer_db.button_handle      = p_char->characteristic.handle_value;
                        evt.params.peer_db.button_cccd_handle = p_char->cccd_handle;
            printf("Led Button Service discovered at peer.\n");
            //If the instance has been assigned prior to db_discovery, assign the db_handles
            if (p_ble_lbs_c->conn_handle != BLE_CONN_HANDLE_INVALID)
                if ((p_ble_lbs_c->peer_lbs_db.led_handle         == BLE_GATT_HANDLE_INVALID)&&
                    (p_ble_lbs_c->peer_lbs_db.button_handle      == BLE_GATT_HANDLE_INVALID)&&
                    (p_ble_lbs_c->peer_lbs_db.button_cccd_handle == BLE_GATT_HANDLE_INVALID))
                    p_ble_lbs_c->peer_lbs_db = evt.params.peer_db;
            p_ble_lbs_c->evt_handler(p_ble_lbs_c, &evt);
    uint32_t ble_lbs_c_init(ble_lbs_c_t * p_ble_lbs_c, ble_lbs_c_init_t * p_ble_lbs_c_init)
        uint32_t      err_code;
        ble_uuid_t    lbs_uuid;
        ble_uuid128_t lbs_base_uuid = {LBS_UUID_BASE};
        VERIFY_PARAM_NOT_NULL(p_ble_lbs_c);
        VERIFY_PARAM_NOT_NULL(p_ble_lbs_c_init);
        VERIFY_PARAM_NOT_NULL(p_ble_lbs_c_init->evt_handler);
        p_ble_lbs_c->evt_handler                    = p_ble_lbs_c_init->evt_handler;
        err_code = sd_ble_uuid_vs_add(&lbs_base_uuid, &p_ble_lbs_c->uuid_type);
        if (err_code != NRF_SUCCESS)
            return err_code;
        VERIFY_SUCCESS(err_code);
        lbs_uuid.type = p_ble_lbs_c->uuid_type;
        lbs_uuid.uuid = LBS_UUID;
        return ble_db_discovery_evt_register(&lbs_uuid);
    void ble_lbs_c_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
        if ((p_context == NULL) || (p_ble_evt == NULL))
            return;
        ble_lbs_c_t * p_ble_lbs_c = (ble_lbs_c_t *)p_context;
            case BLE_GATTC_EVT_HVX:
                on_hvx(p_ble_lbs_c, p_ble_evt);
            case BLE_GATTC_EVT_WRITE_RSP:
                on_write_rsp(p_ble_lbs_c, p_ble_evt);
                on_disconnected(p_ble_lbs_c, p_ble_evt);
    /**@brief Function for configuring the CCCD.
     * @param[in] conn_handle The connection handle on which to configure the CCCD.
     * @param[in] handle_cccd The handle of the CCCD to be configured.
     * @param[in] enable      Whether to enable or disable the CCCD.
     * @return NRF_SUCCESS if the CCCD configure was successfully sent to the peer.
    static uint32_t cccd_configure(uint16_t conn_handle, uint16_t handle_cccd, bool enable)
        printf("Configuring CCCD. CCCD Handle = %d, Connection Handle = %d \n",
            handle_cccd,conn_handle);
        tx_message_t * p_msg;
        uint16_t       cccd_val = enable ? BLE_GATT_HVX_NOTIFICATION : 0;
        p_msg              = &m_tx_buffer[m_tx_insert_index++];
        m_tx_insert_index &= TX_BUFFER_MASK;
        p_msg->req.write_req.gattc_params.handle   = handle_cccd;
        p_msg->req.write_req.gattc_params.len      = WRITE_MESSAGE_LENGTH;
        p_msg->req.write_req.gattc_params.p_value  = p_msg->req.write_req.gattc_value;
        p_msg->req.write_req.gattc_params.offset   = 0;
        p_msg->req.write_req.gattc_params.write_op = BLE_GATT_OP_WRITE_REQ;
        p_msg->req.write_req.gattc_value[0]        = LSB_16(cccd_val);
        p_msg->req.write_req.gattc_value[1]        = MSB_16(cccd_val);
        p_msg->conn_handle                         = conn_handle;
        p_msg->type                                = WRITE_REQ;
        return NRF_SUCCESS;
    uint32_t ble_lbs_c_button_notif_enable(ble_lbs_c_t * p_ble_lbs_c)
        if (p_ble_lbs_c->conn_handle == BLE_CONN_HANDLE_INVALID)
        return cccd_configure(p_ble_lbs_c->conn_handle,
                              p_ble_lbs_c->peer_lbs_db.button_cccd_handle,
                              true);
    uint32_t ble_lbs_led_status_send(ble_lbs_c_t * p_ble_lbs_c, uint8_t status)
        printf("writing LED status 0x%x \n", status);
        p_msg->req.write_req.gattc_params.handle   = p_ble_lbs_c->peer_lbs_db.led_handle;
        p_msg->req.write_req.gattc_params.len      = sizeof(status);
        p_msg->req.write_req.gattc_params.write_op = BLE_GATT_OP_WRITE_CMD;
        p_msg->req.write_req.gattc_value[0]        = status;
        p_msg->conn_handle                         = p_ble_lbs_c->conn_handle;
        return NRF_SUCCESS;
    uint32_t ble_lbs_c_handles_assign(ble_lbs_c_t    * p_ble_lbs_c,
                                      const lbs_db_t * p_peer_handles)
        p_ble_lbs_c->conn_handle = conn_handle;
        if (p_peer_handles != NULL)
            p_ble_lbs_c->peer_lbs_db = *p_peer_handles;
        return NRF_SUCCESS;
    #endif // NRF_MODULE_ENABLED(BLE_LBS_C)
    our_central.h
