I developed a functioning application that advertises with Nordic UART Service, connects to a smartphone application, then reads various sensor data using the SAADC and transmits data to a smartphone. I now want to integrate bonding into the application. I have done a lot of reading online, checking examples, and borrowed some code from the ble_app_template example.
This strategy seemed to work on my iPhone with nRF Connect at first. Upon connection, my application would enter the pm_evt_handler() function and the PM_EVT_CONN_SEC_SUCCEEDED case within peer_manager_handler.c, function pm_handler_evt_log(), would be entered. My debug console would log That the connection was secured, with procedure: encryption. I also noticed that my application was listed and available in my iPhone's bluetooth settings, which had never happened before (only appeared in scans through nRF Connect or similar ble applications). I then wanted to experiment with deleting bonds from with my application, but after doing so my program would enter the PM_EVT_CONN_SEC_FAILED case and print the connection security had failed with error 4102. Research pointed towards the error coming from bonds being deleted on my peripheral device, but not the smartphone. So I selected "forget this device" from within my iPhone bluetooth settings.
I restarted my application without deleting bonds, then received some sort of database error. I cannot remember what the error was exactly and I did not save it, and can no longer reproduce it. I cannot reproduce it because now my application never enters the peer manager event handler function, pm_evt_handler(). The peer manager is being initialized, but my application seems to have lost all functionality with regards to the peer manager and I have not changed the code at all.
Can somebody please help me try to pinpont what I am doing wrong? My application is based off of the uart example, and I integrated peer manager functions from the ble_app_template example project. My application still functions fine with regards to reading SAADC values, timers, regular advertising/connection, etc, but has no peer manager behavior. Below I am pasting my main.c and sdk_config.h files. Please ignore functions related to SAADC, reading values, etc - there are many parts I should clean up and optimize that I am already aware of.
Code related to peer manager are: lines 136-143, 230-250, 583-612, 616-624, 1212-1234. I began writing this application when I was first learning C, so code as seen in function "format_bluetooh_packet()" is painful to look at and is on my to-do to fix. All i want right now is to get peer manager working and then I can clean up/refactor older code.
main.c
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the
* Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "boards.h"
#include "nrf.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_gatt.h"
#include "nrf_saadc.h"
#include "nrf_drv_clock.h"
#include "nrf_delay.h"
#include "nrf_drv_gpiote.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "nrfx_ppi.h"
#include "nrfx_pwm.h"
#include "nrf_timer.h"
#include "nrfx_saadc.h"
#include "ble_nus.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "app_timer.h"
#include "app_uart.h"
#include "app_fifo.h"
#include "app_pwm.h"
#include "app_error.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
// Included for peer manager
#include "nrf_fstorage.h"
#include "nrf_fstorage_sd.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "ble_conn_state.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Lura_Health" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 510 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define SAMPLES_IN_BUFFER 11 /**< SAADC buffer > */
#define NRF_SAADC_CUSTOM_CHANNEL_CONFIG_SE(PIN_P) \
.resistor_p = NRF_SAADC_RESISTOR_DISABLED, \
.resistor_n = NRF_SAADC_RESISTOR_DISABLED, \
.gain = NRF_SAADC_GAIN1_5, \
.reference = NRF_SAADC_REFERENCE_INTERNAL, \
.acq_time = NRF_SAADC_ACQTIME_10US, \
.mode = NRF_SAADC_MODE_SINGLE_ENDED, \
.burst = NRF_SAADC_BURST_DISABLED, \
.pin_p = (nrf_saadc_input_t)(PIN_P), \
.pin_n = NRF_SAADC_INPUT_DISABLED \
/* UNDEFS FOR DEBUGGING */
#undef RX_PIN_NUMBER
#undef RTS_PIN_NUMBER
#undef LED_4
#undef LED_STOP
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
APP_TIMER_DEF(m_timer_id);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
/* Lura Health nRF52810 port assignments */
#define ENABLE_ANALOG_PIN 4
/* GLOBALS */
static uint32_t AVG_PH_VAL = 0;
static uint32_t AVG_BATT_VAL = 0;
static uint32_t AVG_TEMP_VAL = 0;
bool PH_IS_READ = false;
bool BATTERY_IS_READ = false;
bool SAADC_CALIBRATED = false;
bool CONNECTION_MADE = false;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(1);
static nrf_saadc_value_t m_buffer_pool[1][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t m_ppi_channel;
// Forward declarations
static inline void enable_pH_voltage_reading (void);
static inline void enable_switch (void);
static inline void check_reed_switch (void);
static inline void disable_pH_voltage_reading (void);
static inline void saadc_init (void);
static inline void enable_analog_pin (void);
static inline void disable_analog_pin (void);
static void advertising_start (bool erase_bonds);
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product.
* You need to analyse how your product is supposed to react in case of
* Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
NRF_LOG_INFO("INSIDE pm_evt_handler()\n");
NRF_LOG_FLUSH();
switch (p_evt->evt_id)
advertising_start(false);
case PM_EVT_BONDED_PEER_CONNECTED:
NRF_LOG_INFO("PM_EVT_BONDED_PEER_CONNECTED");
NRF_LOG_FLUSH();
/**@brief Function for initializing the timer module.
static inline void timers_init(void)
uint32_t err_code;
err_code = app_timer_init();
* @details This function will set up all the necessary GAP (Generic Access
* Profile) parameters of the device. It also sets the permissions
* and appearance.
static inline void gap_params_init(void)
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* @details A pointer to this function will be passed to each service which may
* need to inform the application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART
* BLE Service and send it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
static inline void nus_data_handler(ble_nus_evt_t * p_evt)
uint32_t err_code;
NRF_LOG_HEXDUMP_DEBUG(p_evt->params.rx_data.p_data,
p_evt->params.rx_data.length);
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
do
err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ",
err_code);
} while (err_code == NRF_ERROR_BUSY);
if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize Queued Write Module
// Initialize NUS
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection
* Parameters Module which are passed to the application.
* @note All this function does is to disconnect. This could have been done by
* simply setting the disconnect_on_fail config parameter, but instead
* we use the event handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
err_code = sd_ble_gap_disconnect(m_conn_handle,
BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
uint32_t err_code;
// Go to system-off mode (function will not return; wakeup causes reset).
* @details This function will be called for advertising events which are passed
* to the application.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
CONNECTION_MADE = true;
NRF_LOG_INFO("CONNECTION MADE \n");
if(p_ble_evt->evt.gap_evt.params.disconnected.reason ==
BLE_HCI_CONNECTION_TIMEOUT)
//disconnect_reason is BLE_HCI_CONNECTION_TIMEOUT
NRF_LOG_INFO("connection timeout\n");
NRF_LOG_INFO("DISCONNECTED\n");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle,
&phys);
} break;
// case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
// // Pairing not supported
// err_code =
// sd_ble_gap_sec_params_reply(m_conn_handle,
// BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
// NULL, NULL);
// APP_ERROR_CHECK(err_code);
// break;
// case BLE_GATTS_EVT_SYS_ATTR_MISSING:
// // No system attributes have been stored.
// err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0);
// break;
case BLE_GATTC_EVT_TIMEOUT:
err_code =
sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle,
case BLE_GATTS_EVT_TIMEOUT:
err_code =
sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle,
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
ret_code_t err_code;
uint32_t ram_start = 0;
// Enable BLE stack.
NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO,
ble_evt_handler, NULL);
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
static void log_init(void)
* @details If there is no pending log operation, then sleep until next the
* next event occurs.
UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
nrf_pwr_mgmt_run();
static void advertising_start(bool erase_bonds)
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/* This function sets enable pin for ISFET circuitry to HIGH
static inline void enable_analog_circuit(void)
nrf_drv_gpiote_out_config_t config = NRFX_GPIOTE_CONFIG_OUT_SIMPLE(false);
if(nrf_drv_gpiote_is_init() == false) {
nrf_drv_gpiote_init();
nrf_drv_gpiote_out_init(ENABLE_ANALOG_PIN, &config);
nrf_drv_gpiote_out_set(ENABLE_ANALOG_PIN);
/* This function sets enable pin for ISFET circuitry to LOW
static inline void disable_analog_pin(void)
// Redundant, but follows design
nrfx_gpiote_uninit();
void timer_handler(nrf_timer_event_t event_type, void * p_context)
// To Add Later
static inline void saadc_sampling_event_init(void)
/* setup m_timer for compare event every 15us */
uint32_t ticks = nrf_drv_timer_us_to_ticks(&m_timer, 35);
NRF_TIMER_CC_CHANNEL0,
ticks,
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
false);
uint32_t timer_compare_event_addr =
nrf_drv_timer_compare_event_address_get(&m_timer,
NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
/* setup ppi channel so that timer compare event triggers task in SAADC */
timer_compare_event_addr,
saadc_sample_task_addr);
static inline void saadc_sampling_event_enable(void)
/* Function for converting numbers > 9 to byte arrays in ASCII format
* @params: Averaged value read from SAADC, ptr to byte array
static inline void num_to_byte_arr(uint8_t *data_arr, uint32_t avg_val)
uint8_t dig1, dig2, dig3;
if(avg_val > 99) {
dig1 = avg_val % 10;
dig2 = ((avg_val % 100) - dig1) / 10;
dig3 = (avg_val - (dig1 + (dig2 * 10))) / 100;
// Convert to ASCII values
data_arr[0] = dig3 + 48;
data_arr[1] = dig2 + 48;
data_arr[2] = dig1 + 48;
else if(avg_val > 9) {
dig3 = 0;
data_arr[0] = dig2 + 48;
data_arr[1] = dig1 + 48;
else {
dig3 = 0;
dig2 = 0;
dig1 = avg_val;
data_arr[0] = avg_val + 48;
static inline void restart_saadc(void)
nrfx_timer_uninit(&m_timer);
nrfx_ppi_channel_free(m_ppi_channel);
nrfx_saadc_uninit();
while(nrfx_saadc_is_busy()) {
// make sure SAADC is not busy
enable_pH_voltage_reading();
// Integers can have maximum 3 digits with 8-bit SAADC output
static inline int length_of_int(int x)
if (x >= 100) return 3;
if (x >= 10) return 2;
return 1;
/* This function combines the ph_data and temp_data into one bluetooth
* packet. The packet follows the format [ph_data,temp_data\n] where
* data fields are between 1-3 bytes each (one per digit).
static inline uint8_t* format_bluetooth_packet(uint8_t* ph_data,
uint8_t* batt_data,
uint8_t* temp_data,
uint8_t* total_packet,
uint16_t* total_size)
num_to_byte_arr(temp_data, AVG_TEMP_VAL);
num_to_byte_arr(batt_data, AVG_BATT_VAL);
// Plus two for comma, plus one for EOL
*total_size = length_of_int(AVG_PH_VAL) + length_of_int(AVG_TEMP_VAL)
+ length_of_int(AVG_BATT_VAL) + 2 + 1;
NRF_LOG_INFO("TOTAL SIZE: %d\n", *total_size);
total_packet = (uint8_t*) malloc(sizeof(uint8_t) * (*total_size));
// Copy pH data, copy temp data, add comma and EOL
memcpy(total_packet, ph_data, length_of_int(AVG_PH_VAL));
memcpy(total_packet + length_of_int(AVG_PH_VAL) + 1,
temp_data, length_of_int(AVG_TEMP_VAL));
memcpy(total_packet + length_of_int(AVG_PH_VAL) + 2 + length_of_int(AVG_TEMP_VAL),
batt_data, length_of_int(AVG_BATT_VAL));
total_packet[length_of_int(AVG_PH_VAL)] = 44; // comma
total_packet[length_of_int(AVG_PH_VAL)+1+length_of_int(AVG_TEMP_VAL)] = 44; // comma
total_packet[*total_size - 1] = 10; // EOL
return total_packet;
static inline uint8_t* create_bluetooth_packet(uint32_t ph_val,
uint32_t batt_val,
uint32_t temp_val,
uint8_t threedig_PH_data [3] = {0, 0, 0};
uint8_t threedig_BATT_data[3] = {0, 0, 0};
uint8_t threedig_TEMP_data[3] = {0, 0, 0};
uint8_t twodig_PH_data [2] = {0, 0};
uint8_t twodig_BATT_data [2] = {0, 0};
uint8_t twodig_TEMP_data [2] = {0, 0};
uint8_t onedig_PH_data [1] = {0};
uint8_t onedig_BATT_data [1] = {0};
uint8_t onedig_TEMP_data [1] = {0};
uint8_t* packet;
if(AVG_PH_VAL > 99) {
num_to_byte_arr(threedig_PH_data, AVG_PH_VAL);
// Convert temp number to appropriate byte array
if(AVG_TEMP_VAL > 99) {
if(AVG_BATT_VAL > 99)
packet = format_bluetooth_packet(threedig_PH_data, threedig_BATT_data, threedig_TEMP_data,
total_packet, total_size);
else if(AVG_BATT_VAL > 9)
packet = format_bluetooth_packet(threedig_PH_data, twodig_BATT_data, threedig_TEMP_data,
packet = format_bluetooth_packet(threedig_PH_data, onedig_BATT_data, threedig_TEMP_data,
else if(AVG_TEMP_VAL > 9) {
packet = format_bluetooth_packet(threedig_PH_data, threedig_BATT_data, twodig_TEMP_data,
packet = format_bluetooth_packet(threedig_PH_data, twodig_BATT_data, twodig_TEMP_data,
packet = format_bluetooth_packet(threedig_PH_data, onedig_BATT_data, twodig_TEMP_data,
else {
packet = format_bluetooth_packet(threedig_PH_data, threedig_BATT_data, onedig_TEMP_data,
packet = format_bluetooth_packet(threedig_PH_data, twodig_BATT_data, onedig_TEMP_data,
packet = format_bluetooth_packet(threedig_PH_data, onedig_BATT_data, onedig_TEMP_data,
else if(AVG_PH_VAL > 9) {
num_to_byte_arr(twodig_PH_data, AVG_PH_VAL);
packet = format_bluetooth_packet(twodig_PH_data, threedig_BATT_data, threedig_TEMP_data,
packet = format_bluetooth_packet(twodig_PH_data, twodig_BATT_data, threedig_TEMP_data,
packet = format_bluetooth_packet(twodig_PH_data, onedig_BATT_data, threedig_TEMP_data,
packet = format_bluetooth_packet(twodig_PH_data, threedig_BATT_data, twodig_TEMP_data,
packet = format_bluetooth_packet(twodig_PH_data, twodig_BATT_data, twodig_TEMP_data,
packet = format_bluetooth_packet(twodig_PH_data, onedig_BATT_data, twodig_TEMP_data,
packet = format_bluetooth_packet(twodig_PH_data, threedig_BATT_data, onedig_TEMP_data,
packet = format_bluetooth_packet(twodig_PH_data, twodig_BATT_data, onedig_TEMP_data,
packet = format_bluetooth_packet(twodig_PH_data, onedig_BATT_data, onedig_TEMP_data,
else {
num_to_byte_arr(onedig_PH_data, AVG_PH_VAL);
packet = format_bluetooth_packet(onedig_PH_data, threedig_BATT_data, threedig_TEMP_data,
packet = format_bluetooth_packet(onedig_PH_data, twodig_BATT_data, threedig_TEMP_data,
packet = format_bluetooth_packet(onedig_PH_data, onedig_BATT_data, threedig_TEMP_data,
packet = format_bluetooth_packet(onedig_PH_data, threedig_BATT_data, twodig_TEMP_data,
packet = format_bluetooth_packet(onedig_PH_data, twodig_BATT_data, twodig_TEMP_data,
packet = format_bluetooth_packet(onedig_PH_data, onedig_BATT_data, twodig_TEMP_data,
else {
packet = format_bluetooth_packet(onedig_PH_data, threedig_BATT_data, onedig_TEMP_data,
packet = format_bluetooth_packet(onedig_PH_data, twodig_BATT_data, onedig_TEMP_data,
packet = format_bluetooth_packet(onedig_PH_data, onedig_BATT_data, onedig_TEMP_data,
return packet;
* Function is called when SAADC reading event is done. First done event
* reads pH input, stores in global variable. Second reading stores
* pH data, combines pH and temp data into a comma-seperated string,
* then transmits via BLE.
* BUG: p_buffer[0] is always '0' when reading pH at high frequency.
* Workaround is to average values besides 1, divide by
* samples_in_buffer -1 .
static inline void saadc_callback(nrf_drv_saadc_evt_t const * p_event)
uint16_t total_size;
uint32_t avg_saadc_reading = 0;
// Byte array to store total packet
uint8_t* total_packet;
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer,
SAMPLES_IN_BUFFER);
// Sum and average SAADC values
for (int i = 1; i < SAMPLES_IN_BUFFER; i++)
if (p_event->data.done.p_buffer[i] < 0) {
avg_saadc_reading += 0;
else {
avg_saadc_reading += p_event->data.done.p_buffer[i];
avg_saadc_reading = avg_saadc_reading/(SAMPLES_IN_BUFFER - 1);
// If ph has not been read, read it then restart SAADC to read temp
if (!PH_IS_READ) {
AVG_PH_VAL = avg_saadc_reading;
PH_IS_READ = true;
// Uninit saadc peripheral, restart saadc, enable sampling event
NRF_LOG_INFO("read pH val, restarting: %d", AVG_PH_VAL);
NRF_LOG_FLUSH();
restart_saadc();
// If pH has been read but not battery, read battery then restart
else if (!(PH_IS_READ && BATTERY_IS_READ)) {
AVG_BATT_VAL = avg_saadc_reading;
NRF_LOG_INFO("read batt val, restarting: %d", AVG_BATT_VAL);
NRF_LOG_FLUSH();
BATTERY_IS_READ = true;
restart_saadc();
// Once temp, batter and ph have been read, create and send data in packet
else {
AVG_TEMP_VAL = avg_saadc_reading;
NRF_LOG_INFO("read temp val, restarting: %d", AVG_TEMP_VAL);
NRF_LOG_FLUSH();
// Convert pH number to appropriate byte array
total_packet = create_bluetooth_packet((uint32_t)AVG_PH_VAL,
(uint32_t)AVG_BATT_VAL,
(uint32_t)AVG_TEMP_VAL,
total_packet, &total_size);
// Send data
err_code = ble_nus_data_send(&m_nus, total_packet,
&total_size, m_conn_handle);
// reset global control boolean
PH_IS_READ = false;
// Free dynamic array
free(total_packet);
// Turn off peripherals
NRF_LOG_INFO("BLUETOOTH DATA SENT\n");
NRF_LOG_FLUSH();
disable_pH_voltage_reading();
NRF_LOG_INFO("SAADC DISABLED\n");
NRF_LOG_FLUSH();
/* Reads pH transducer output
void saadc_init(void)
nrf_saadc_input_t ANALOG_INPUT;
// Change pin depending on global control boolean
if (!PH_IS_READ) {
NRF_LOG_INFO("Setting saadc input to AIN1\n");
ANALOG_INPUT = NRF_SAADC_INPUT_AIN1;
NRF_LOG_INFO("Setting saadc input to AIN3\n");
ANALOG_INPUT = NRF_SAADC_INPUT_AIN3;
else {
NRF_LOG_INFO("Setting saadc input to AIN0\n");
ANALOG_INPUT = NRF_SAADC_INPUT_AIN0;
nrf_saadc_channel_config_t channel_config =
NRF_SAADC_CUSTOM_CHANNEL_CONFIG_SE(ANALOG_INPUT);
err_code = nrf_drv_saadc_init(NULL, saadc_callback);
* BUG: calibration never completes
// Calibrate offset
// if(!SAADC_CALIBRATED) {
// while (nrfx_saadc_calibrate_offset() != NRFX_SUCCESS) {
// NRF_LOG_INFO("calibration does not equal success\n");
// NRF_LOG_FLUSH();
// nrf_delay_us(10);
// SAADC_CALIBRATED = true;
// while (nrfx_saadc_is_busy()) {
// NRF_LOG_INFO("saadc busy while restarting\n");
// NRF_LOG_FLUSH();
// nrf_delay_ms(1000);
err_code = nrf_drv_saadc_channel_init(0, &channel_config);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
/* This function initializes and enables SAADC sampling
static inline void enable_pH_voltage_reading(void)
saadc_init();
saadc_sampling_event_init();
nrf_pwr_mgmt_run();
/* Function unitializes and disables SAADC sampling, restarts 1 second timer
static inline void disable_pH_voltage_reading(void)
// *** DISABLE ENABLE ***
disable_analog_pin();
// Restart timer
err_code = app_timer_start(m_timer_id, APP_TIMER_TICKS(1500), NULL);
nrf_pwr_mgmt_run();
NRF_LOG_INFO("TIMER RESTARTED (disable_ph_voltage_reading)\n");
NRF_LOG_FLUSH();
static inline void single_shot_timer_handler()
// disable timer
err_code = app_timer_stop(m_timer_id);
// Delay to ensure appropriate timing between
enable_analog_circuit();
// PWM output, ISFET capacitor, etc
nrf_delay_us(2000);
// Begin SAADC initialization/start
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) &&
(p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH
- HANDLE_LENGTH;
// Create application timer
err_code = app_timer_create(&m_timer_id,
APP_TIMER_MODE_SINGLE_SHOT,
single_shot_timer_handler);
// 1 second timer intervals
err_code = app_timer_start(m_timer_id, APP_TIMER_TICKS(2000), NULL);
NRF_LOG_INFO("TIMER STARTED (gatt_evt_handler) \n");
NRF_LOG_FLUSH();
nrf_pwr_mgmt_run();
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt,
NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
/**@brief Application main function.
bool erase_bonds = false;
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
peer_manager_init();
// Initial pin state is low
advertising_start(erase_bonds);
// Enter main loop.
while (true)
idle_state_handle();
/** @file
#include <stdint.h>
#include <string.h>
#include "boards.h"
#include "nrf.h"
#include "fds.h"
#undef LED_4
#undef LED_STOP
/* GLOBALS */
* Assert.
NRF_LOG_FLUSH();
NRF_LOG_FLUSH();
uint32_t err_code;
* and appearance.
uint32_t err_code;
uint32_t err_code;
do
err_code);
uint32_t err_code;
// Initialize NUS
uint32_t err_code;
uint32_t err_code;
uint32_t err_code;
uint32_t err_code;
sleep_mode_enter();
uint32_t err_code;
&phys);
} break;
// err_code =
// NULL, NULL);
// break;
// break;
err_code =
err_code =
uint32_t err_code;
nrf_pwr_mgmt_run();
delete_bonds();
// To Add Later
ticks,
false);
if(avg_val > 99) {
dig3 = 0;
else {
dig3 = 0;
dig2 = 0;
dig1 = avg_val;
return 1;
uint8_t* batt_data,
uint8_t* temp_data,
uint32_t batt_val,
uint32_t temp_val,
uint8_t* packet;
else {
else {
else {
return packet;
SAMPLES_IN_BUFFER);
else {
if (!PH_IS_READ) {
PH_IS_READ = true;
NRF_LOG_FLUSH();
restart_saadc();
NRF_LOG_FLUSH();
restart_saadc();
else {
NRF_LOG_FLUSH();
// Send data
PH_IS_READ = false;
free(total_packet);
NRF_LOG_FLUSH();
NRF_LOG_FLUSH();
if (!PH_IS_READ) {
else {
// Calibrate offset
// NRF_LOG_FLUSH();
// NRF_LOG_FLUSH();
saadc_init();
nrf_pwr_mgmt_run();
// Restart timer
nrf_pwr_mgmt_run();
NRF_LOG_FLUSH();
// disable timer
nrf_delay_us(2000);
- HANDLE_LENGTH;
NRF_LOG_FLUSH();
nrf_pwr_mgmt_run();
log_init();
timers_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Enter main loop.
while (true)
