How to generate two complimentary 300KHz signals with specific timing
How can I generate two complimentary signals using PWM with a period of 3.33us (300khz) with ability to control number of pulses to generate.
1: With current api PWM takes period is integer values of microseconds so I can set either 3us or 4us, but I need to set 3.33us
2: How do I control exact number of pulses generated by PWM
3: For my second signal is it possible to set delay so that first signal and the second signal does not overlap
    it would be too complex configuration for PWM, though maybe it's possible...  I would recommend you to use TIMER and GPIOTE for this task. Note that you cannot achieve an exact 300khz signal, either with TIMER or PWM, the closest value is 16000000/53=301.8kHz (if it matters to you). A number of pulses can be counted by an interrupt handler triggered with COMPARE[3] event.
    Here is a code that uses TIMER1:
    nrf_gpiote_task_configure(0, DRVA_PIN_NUMBER, NRF_GPIOTE_POLARITY_TOGGLE, NRF_GPIOTE_INITIAL_VALUE_LOW);
    nrf_gpiote_task_configure(1, DRVB_PIN_NUMBER, NRF_GPIOTE_POLARITY_TOGGLE, NRF_GPIOTE_INITIAL_VALUE_LOW);
    NRF_TIMER1->MODE        = TIMER_MODE_MODE_Timer;
    NRF_TIMER1->BITMODE     = (TIMER_BITMODE_BITMODE_32Bit << TIMER_BITMODE_BITMODE_Pos);
    NRF_TIMER1->PRESCALER   = 0; // 16MHz
    NRF_TIMER1->SHORTS      = (TIMER_SHORTS_COMPARE3_CLEAR_Enabled << TIMER_SHORTS_COMPARE3_CLEAR_Pos);
    int period = 16000000/300000;
    NRF_TIMER1->CC[0] = 2; // ensure 124ns delay
    NRF_PPI->CH[0].EEP = (uint32_t) &NRF_TIMER1->EVENTS_COMPARE[0];
    NRF_PPI->CH[0].TEP = (uint32_t) &NRF_GPIOTE->TASKS_SET[0];
    NRF_TIMER1->CC[1] = period/2;
    NRF_PPI->CH[1].EEP = (uint32_t) &NRF_TIMER1->EVENTS_COMPARE[1];
    NRF_PPI->CH[1].TEP = (uint32_t) &NRF_GPIOTE->TASKS_CLR[0];
    NRF_TIMER1->CC[2] = period/2 + 2; // ensure 124ns delay
    NRF_PPI->CH[2].EEP = (uint32_t) &NRF_TIMER1->EVENTS_COMPARE[2];
    NRF_PPI->CH[2].TEP = (uint32_t) &NRF_GPIOTE->TASKS_SET[1];
    NRF_TIMER1->CC[3] = period;
    NRF_PPI->CH[3].EEP = (uint32_t) &NRF_TIMER1->EVENTS_COMPARE[3];
    NRF_PPI->CH[3].TEP = (uint32_t) &NRF_GPIOTE->TASKS_CLR[1];
    NRF_PPI->CHENSET = PPI_CHENSET_CH0_Enabled << PPI_CHENSET_CH0_Pos |
                       PPI_CHENSET_CH1_Enabled << PPI_CHENSET_CH1_Pos |
                       PPI_CHENSET_CH2_Enabled << PPI_CHENSET_CH2_Pos |
                       PPI_CHENSET_CH3_Enabled << PPI_CHENSET_CH3_Pos;
    NRF_TIMER1->TASKS_CLEAR = 1;
    NRF_TIMER1->TASKS_START = 1;
  • Thank you, it works. 301.8khz will work for me.
  • How do I register an interrupt handler on compare event
  • You can look at this example (it should compile also for nRF52)
