Queued write response fails
iOS is using queued writes to send data to my nRF52832 application. For some reason, on the third queued write reply (in nrf_ble_qwr.c) sd_ble_gatts_rw_authorize_reply returns NRF_ERROR_INVALID_STATE.
I modified nrf_ble_qwr.c to log every time it calls sd_ble_gatts_rw_authorize_reply anywhere. I am sure that my code is not calling it, as I also log everywhere I call it too. The log output looks like this:
<debug> nrf_sdh_ble: BLE event: 0x1.
<debug> nrf_sdh_ble: BLE event: 0x51.
<info> app: prepare reply
<error> KFPAL: ERROR 8 [NRF_ERROR_INVALID_STATE] at ...KFPAL_Nordic_bluetooth.c:446
PC at: 0x000268F1
<error> KFPAL: End of error report
this occurs in the sd_ble_gatts_rw_authorize_reply call in on_prepare_write in nrf_ble_qwr.c. Unless sd_ble_gatts_rw_authorize_reply is being called by another nrf library, it is only being called from nrf_ble_qwr.c. I'm really struggling to understand why INVALID_STATE is being returned.
  • Hi Nick,
    What do you have at KFPAL_Nordic_bluetooth.c line 446 ?
    If you are not sure where sd_ble_gatts_rw_authorize_reply () being called, and if other module is using it you can do a "Find in Files" and find all location that function is called.
    Please add the log in each of the events inside nrf_ble_qwr_on_ble_evt() it would help to detect the last event before the assert.
    Have you tried to test with the \examples\ble_peripheral\experimental\ble_app_queued_writes example ?
    Please also capture a sniffer trace, it help analyzing what happens over the air.
    KFPAL_Nordic_bluetooth.c line 446 is the QWR error callback
    static void queued_write_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    I am now confident that I am logging everywhere sd_ble_gatts_rw_authorize_reply is called including in libraries.
    I am logging BLE events from the softdevice as you can see in the logs (NRF_SDH_BLE_LOG_ENABLED=1), so these are the only BLE events occurring.
    Here's a packet log captured from the iPad. You can see it never receives a response to the third write. I suspect this could actually be a softdevice bug. Queued writes with only two writes work fine.
    I haven't tried your example but I think it is broken.
  • Hi Nick,
    Thanks for the link. I think it's not related to the issue you are having here. You can add the fix to initialize the cur_evt.rcvd_data array before calling nrf_ble_qwr_value_get() inside nrf_ble_qwrs_on_qwr_evt(). memset(cur_evt.rcvd_data,0,NRF_BLE_QWRS_MAX_RCV_SIZE); should fix it.
    Have you tried to add logging inside nrf_ble_qwr_on_ble_evt() event ? We would need to find which function throw the error.
    I'm looking for a way to reproduce the issue here. Could you describe your iphone app ? I can see in the log it's doing 3 queued writes, each has 180 bytes. Is it possible to replace the iphone with a nRF52 as a central device ? So we can reproduce here ? It's the best if you can reproduce with ble_app_queued_writes, this example has both sides running on nRF52.
  • No, the issue is not related to the example bug, I just meant I can't test the example as-is. That would also not fix it as no buffer is set to cur_evt.rcvd_data.
    The event is prepare write request (BLE_GATTS_OP_PREP_WRITE_REQ) (I logged "prepare reply" on this event in nrf_ble_qwr.c on_prepare_write just before the call to sd_ble_gatts_rw_authorize_reply).
    The App uses peripheral.maximumWriteValueLength(for: .withResponse) to get the max write length which is 512 in my testing. Then I write a 512 byte Data with peripheral.writeValue(remaining.subdata(in: 0..<lengthToWrite), for: c, type: .withResponse). iOS then uses queued writes to send that data. It should be fairly easy to reproduce, I'm using an iPad Pro 11" with iOS 13.3. I've already spent a lot of time on this issue though so I can't really investigate further right now. I'm just reducing sent data length in the app for now.
  • Hi Nick,
    rcvd_data is defined as an array not a pointer:
        uint8_t               rcvd_data[NRF_BLE_QWRS_MAX_RCV_SIZE];
    So the array has the buffer, it's just not initialized to 0 and I'm not sure initialized to 0 is really needed anyway.
    Please try to test with ble_app_queued_writes so we have an aligned test base.
    I will try to test here with what you described.
