Configure Ceedling for unit testing
I'm starting to look at using Ceedling (+Unity + CMock) for some test driven development but am having trouble getting tests that use/mock the SDK. I'm currently trying to set up unit tests for a custom ble service (an SDK equivalent would be any of the files in the components\ble\ble_services folder) that will run on my PC, not on the target. I am using Cygwin and gcc
Does anyone have any experience/guidance/project files for how to set this up?
My current yml file looks like this
# Notes:
# Sample project C code is not presently written to produce a release artifact.
# As such, release build options are disabled.
# This sample, therefore, only demonstrates running a collection of unit tests.
:project:
  :use_exceptions: FALSE
  :use_test_preprocessor: TRUE
  :use_auxiliary_dependencies: TRUE
  :build_root: build
#  :release_build: TRUE
  :test_file_prefix: test_
  :which_ceedling: gem
  :default_tasks:
    - test:all
  :options_paths:
    - options/
#:test_build:
#  :use_assembly: TRUE
#:release_build:
#  :output: MyApp.out
#  :use_assembly: FALSE
:environment:
:extension:
  :executable: .out
:paths:
  :test:
    - +:test/**
    - -:test/support
  :source:
    - lib/**
  :include:
    - include/**
  :support:
    - test/support
:module_generator:
  :source_root: lib/
  :inc_root: include/mylib/
:use_test_preprocessor: true
:defines:
  # in order to add common defines:
  #  1) remove the trailing [] from the :common: section
  #  2) add entries to the :common: section (e.g. :test: has TEST defined)
  :common: &common_defines []
  :test:
    - *common_defines
    - TEST
    - __STATIC_INLINE='static inline'
  :test_preprocess:
    - *common_defines
    - TEST
:cmock:
  :mock_prefix: mock_
  :when_no_prototypes: :warn
  :enforce_strict_ordering: TRUE
  :plugins:
    - :ignore
    - :callback
  :treat_as:
    uint8:    HEX8
    uint16:   HEX16
    uint32:   UINT32
    int8:     INT8
    bool:     UINT8
# Add -gcov to the plugins list to make sure of the gcov plugin
# You will need to have gcov and gcovr both installed to make it work.
# For more information on these options, see docs in plugins/gcov
:gcov:
    :html_report: TRUE
    :html_report_type: detailed
    :html_medium_threshold: 75
    :html_high_threshold: 90
    :xml_report: FALSE
#:tools:
# Ceedling defaults to using gcc for compiling, linking, etc.
# As [:tools] is blank, gcc will be used (so long as it's in your system path)
# See documentation to configure a given toolchain for use
# LIBRARIES
# These libraries are automatically injected into the build process. Those specified as
# common will be used in all types of builds. Otherwise, libraries can be injected in just
# tests or releases. These options are MERGED with the options in supplemental yaml files.
:libraries:
  :placement: :end
  :flag: "${1}"  # or "-L ${1}" for example
  :test: []
  :release: []
:plugins:
  :load_paths:
    - "#{Ceedling.load_path}"
  :enabled:
    - stdout_pretty_tests_report
    - module_generator
I am using python to extract include paths and defines from my Keil project file and generate another yml file that I include when running ceedling e.g.
ceedling options:NRF52_S332_SDK153 test:all
this is so i can run tests for each of the targets for my project.
I'm currently stuck with errors like
../libnordic/v15.3/components/softdevice/s332/headers/ble.h: In function 'sd_ble_user_mem_reply':
../libnordic/v15.3/components/softdevice/s332/headers/nrf_svc.h:68:5: error: unknown register name 'r0' in 'asm'
     __asm(                                              \
I have included mock_ble.h in my test file.
#include "unity.h"
#include "ble_my_service.h"
#include "mock_ble.h"
#include "mock_ble_gap.h"
void setUp(void)
void tearDown(void)
void test_ble_my_service_NeedToImplement(void)
    TEST_IGNORE_MESSAGE("Need to Implement ble_my_service");
How can I get this going? Should this work? Am I trying to mock things at too low of a level? Am I using the right compiler tools?
