GPIOTE does not work when PA/LNA is enabled
I am using GPIO interrupt event.
And I added the following code because I wanted to observe PA / LNA.
static void pa_lna_init(void)
    ret_code_t err_code;
    static const uint32_t gpio_toggle_ch = 0;
    static const uint32_t ppi_set_ch = 0;
    static const uint32_t ppi_clr_ch = 1;
    ble_opt_t opt;
    memset(&opt, 0, sizeof(ble_opt_t));
    // Common PA/LNA config
    opt.common_opt.pa_lna.gpiote_ch_id  = gpio_toggle_ch;        // GPIOTE channel
    opt.common_opt.pa_lna.ppi_ch_id_clr = ppi_clr_ch;            // PPI channel for pin clearing
    opt.common_opt.pa_lna.ppi_ch_id_set = ppi_set_ch;            // PPI channel for pin setting
    // PA config
    opt.common_opt.pa_lna.pa_cfg.active_high = 1;                // Set the pin to be active high
    opt.common_opt.pa_lna.pa_cfg.enable      = 1;                // Enable toggling
    opt.common_opt.pa_lna.pa_cfg.gpio_pin    = PA_PIN;      // The GPIO pin to toggle
    // LNA config
    opt.common_opt.pa_lna.lna_cfg.active_high  = 1;              // Set the pin to be active high
    opt.common_opt.pa_lna.lna_cfg.enable       = 1;              // Enable toggling
    opt.common_opt.pa_lna.lna_cfg.gpio_pin     = LNA_PIN;   // The GPIO pin to toggle
    //opt.common_opt.conn_evt_ext.enable = 1;
    err_code = sd_ble_opt_set(BLE_COMMON_OPT_PA_LNA, &opt);
    //err_code = sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt);
Adding this code stopped the GPIO interrupts. Can the two coexist?
