nRF52 DK GPIOTE interrupt stops working after approx 400ms after startup.
I am using SDK 15.3, SES 4.30 and softdevice 132 with the ble_app_uart_c as the core functionality for my system.
I've read many dev support threads about this issue and most seem to point to using high accuracy with GPIOTE.  I have high accuracy enabled.  Attached is my code:
// GPIOTE is used for D_TEMP_IRQ input to know when a temperature conversion is completed
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action) {
  nrf_gpio_pin_toggle(LED_1); // Flash the led so we know something's happening
  get_water_temp();
 * @brief Function for configuring: PIN_IN pin for input,
 * and configures GPIOTE to give an interrupt on pin change. */
#define PIN_IN D_TEMP_IRQ
void gpio_init(void) {
  ret_code_t err_code;
  nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);   // true = high accuracy
  in_config.pull = NRF_GPIO_PIN_NOPULL;
  err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
  d_temp_irq_enable();
//  Functions to enable and disable interrupts on d_temp_irq
int d_temp_irq_enable(void) {
  nrf_drv_gpiote_in_event_enable(PIN_IN, true);
//  nrf_gpio_pin_toggle(LED_2); // Flash the led so we know something's happening
  temp_probe_irq = true;
uint32_t d_temp_irq_disable(void) {
  nrf_drv_gpiote_in_event_disable(PIN_IN);
//  nrf_gpio_pin_toggle(LED_1); // Flash the led so we know something's happening
  temp_probe_irq = false;
I have an external pullup on the d_temp_irq line that is triggering the GPIOTE.  The system is consistently shutting down the GPIOTE interrupts within the approximately 400ms time period.  This is the only GPIOTE interrupt I use.
The GPIOTE is setup early in the startup sequence via gpio_init()  in main(void) code were I immediately configure the Dallas DS18B20 temperature sensor.  The sensor is working up until the 400ms time wherein the interrupt stops working.  I'm thinking that there is other code starting afterwards that is disabling the interrupt function.
Does the soft device, timers, or other BLE functions affect the GPIOTE operation?   Here's my main(void) code:
int main(void) {
  // Initialize.
  log_init();
  app_timers_init();
  uart_init();
  pins_buttons_leds_init();
  gpio_init();
//  pwm_init();
//  saadc_init();
//  saadc_sampling_event_init();
  perfect_shower_init();
  db_discovery_init();
  power_management_init();
  ble_stack_init();
  gatt_init();
  nus_c_init();
  scan_init();
  // Start execution.
  printf("BLE UART central example started.\r\n");
  NRF_LOG_INFO("BLE UART central example started.");
  scan_start();
  // Enter main loop.
  for (;;) {
    idle_state_handle();
I've disabled the pwm and saadc code to see if they're causing the problem... They aren't.
  • Have you gotten any further? It seems I need the entire structure yes (I need something self contained that compile out of the box).
    Kenneth
  • Hi Kenneth,
    I've attached the entire structure. nRF5_SDK_15.3.0_59ac345.zip
    I've made no more progress with this.
  • Any progress? I can compile and run the code, but it is stuck in perfect_shower_init() since I don't have an DS18B20 present. Any way I can run the code without it present to recreate the issue?
    Kenneth
  • Hi Kenneth,
    Still no resolution on my end.
    I think you can trick the system if you change line 927 to have an internal pullup, you should be able to manually trigger the gpiote interrupt with a ground wire on P0.25 on P4 of the dev board. It is set for a LoToHi transition on this pin. Also comment-out the init function void perfect_shower_init(void) at line 1255.
    In a nutshell, what I am trying to do is to run the Dallas ds18B20 temperature sensor continuously.  It takes 172ms per conversion so I can't use a delay function so I set up it's OneWire pin as an interrupt on pin P0.25.  This pin will be held low by the DS18B20 while the conversion takes place then an external pullup resistor on our board pulls it high.  (Hence the internal pullup requirement.)  When an interrupt is generated the handler goes to read the temperature probe data.  First it disables the interrupt so that when I read the probe the act of reading doesn't generate more interrupts.  After the temperature data is read then another temperature conversion is immediately initiated and the interrupt is re-enabled and I go off to do other things for another 172ms.
    The problem is that this process stops working after about 400ms.  The last activity I see on the d_temp_irq line falls in line with my perfect_shower_init() initialization routine. After this, I never get any interrupts from the GPIOTE system.  This seems to coincide with the ble_app_uart_c functions starting up.
  • You can also set up another GPIO as an output and tie it to P0.25 to toggle the interrupt to simulate the Dallas onewire function.
