NRf51822 qfaa bootloader settings not working
I am trying to implement DFU for nrf51822 qfaa module
I have used sdk secure boot-loader example.
Its working on nrf51DK
but not working on nrf51822 qfaa module
sdk : 12.3.0
  • HI Dhaval,
    does the nRF51822 module have an external 32kHz crystal? If not, then you need to change the LFCLK configuration to use the internal RC Oscillator, i.e.
    #define NRF_CLOCK_LFCLKSRC      {.source        = NRF_CLOCK_LF_SRC_RC,            \
                                     .rc_ctiv       = 16,                                \
                                     .rc_temp_ctiv  = 2,                                \
                                     .xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM}
    Best regards
    Bjørn
  • It worked with my module when I changed ram as below
      FLASH (rx) : ORIGIN = 0x35C00, LENGTH = 0xA000
      /** RAM Region for bootloader. This setting is suitable when used with s110, s120, s130, s310. */
      RAM (rwx) :  ORIGIN = 0x200025e0, LENGTH = 0x1a02
      /** Location of non initialized RAM. Non initialized RAM is used for exchanging bond information
       *  from application to bootloader when using buttonluss DFU OTA.
      NOINIT (rwx) :  ORIGIN = 0x20003fe2, LENGTH = 0x80
      /** Location of bootloader setting in at the last flash page. */
      BOOTLOADER_SETTINGS (rw) : ORIGIN = 0x0003FC00, LENGTH = 0x0400
      /** Location in UICR where bootloader start address is stored. */
      UICR_BOOTLOADER (r) : ORIGIN = 0x10001014, LENGTH = 0x04
    but on OTA inrf toolbox giving me error upload failed gatt error
    I have generated package using application hex and private key using following command
    nrfutil pkg generate --hw-version 51 --application-version 1 --application testFirmware\mainApp.hex --sd-req 0x87 --key-file keys\private.pem OTATest.zip
  • Please use the nRF Connect app instead of the nRF Toolbox and provide the log files from the nRF Connect app.
  • INFO:Inside main
     0> :INFO:In nrf_bootloader_init
     0> :INFO:In real nrf_dfu_init
     0> :INFO:running nrf_dfu_settings_init
     0> :INFO:Enter nrf_dfu_continue
     0> :INFO:Valid App
     0> :INFO:Application sent bootloader request
     0> :INFO:In nrf_dfu_transports_init
     0> :INFO:num transports: 1
     0> :INFO:vector table: 0x00035c00
     0> :INFO:After nrf_dfu_transports_init
     0> :INFO:------- nrf_dfu_flash_init-------
     0> :INFO:Waiting for events
    this is getting on dfu start via RTT
    Here is log from nrf connect app
    nRF Connect, 2020-01-27
    DfuTarg (CA:1A:F2:51:65:B7)
    V	15:21:15.600	Connecting to CA:1A:F2:51:65:B7...
    D	15:21:15.600	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	15:21:15.970	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	15:21:15.970	Connected to CA:1A:F2:51:65:B7
    D	15:21:15.973	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    V	15:21:16.009	Discovering services...
    D	15:21:16.012	gatt.discoverServices()
    I	15:21:16.413	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	15:21:46.373	[Callback] Connection state changed with status: 22 and new state: DISCONNECTED (0)
    E	15:21:46.373	Error 22 (0x16): GATT CONN TERMINATE LOCAL HOST
    I	15:21:46.373	Disconnected
    D	15:21:46.411	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
  • Ok, so the nrf51822 is  advertising as Nordic_Buttonless, when you try to connect, then you're not able to connect with the application?
    Best regards
    bjørn
