Adapting NRF52832 example to custom board with NRF52810
My custom board with NRF52810 is done and I'm now trying to get some examples working. I am adapting blinky_s132 in SES. To do this I edited the project options including disabling the FPU, defining BOARD_CUSTOM, chaning the device definition to NRF52810_XXAA, and some other changes. I've attached the SES project file. I also opened this project file in a text editor and changed  ...
arm_target_device_name="nRF52810_xxAA"
I also created a custom_board.h which I have attached. The program compiles correctly and programs fine but when debugging it seems to get stuck in a trap. I don't think SES has registered that I'm using 52810 instead of 52832 as can be seem by the flash and ram usage . Can you help me resolve this?
By the way, I can't seem to upload more than one file for some reason.
  • I'm still having problems with my NRF52810 board. I can run non-softdevice examples fine. Here are the steps I'm taking to get the ble_app_gatts_c_pca10040e project working in SES.
    1. open this project in SES.
    2. Change project options for "common" config.. Preproccesor macros set to
    APP_TIMER_V2
    APP_TIMER_V2_RTC1_ENABLED
    BOARD_CUSTOM
    CONFIG_GPIO_AS_PINRESET
    FLOAT_ABI_SOFT
    INITIALIZE_USER_SECTIONS
    NO_VTOR_CONFIG
    NRF52810_XXAA
    NRF52_PAN_74
    NRF_SD_BLE_API_VERSION=7
    S112
    SOFTDEVICE_PRESENT
    3. created custom_board.c by copying board_pca10040.c and removing defines that do not apply.
    4. Comment out contents of buttons_leds_init() function in main.c because I have no buttons on my board.
    5. Open nrfGo Studio, program s112 softdevice followed by the new project hex file. I've tried both the "Debug" and "release" without success. If I attache the debugger, reset and then pause the program, I always end up at the same instruction:
    4770        bx lr
    I've attached a screen cap of that program location I get trapped in. Can you see any mistake I'm making?
     Do you use the same setting in Setp.2 & 3?
    Please start a terminal emulator like PuTTY and connect to the used COM port with the following UART settings and provide the log:
    • Baud rate: 115.200
    • 8 data bits
    • 1 stop bit
    • No parity
    • HW flow control: None
    -Amanda H.
  • I am using the same custom_board.h in both projects. Here is the preprocessor macros from my blinky project:
    BOARD_CUSTOM
    BSP_DEFINES_ONLY
    FLOAT_ABI_SOFT
    NO_VTOR_CONFIG
    NRF52810_XXAA
    NRF52_PAN_74
    And is the preprocessor macros for the BLE GATTS example:
    APP_TIMER_V2
    BOARD_CUSTOM
    FLOAT_ABI_SOFT
    NO_VTOR_CONFIG
    NRF52810_XXAA
    NRF52_PAN_74
    S112
    SOFTDEVICE_PRESENT
    The only differences I see are...
    APP_TIMER_V2
    BSP_DEFINES_ONLY
    S112
    SOFTDEVICE_PRESENT
    I don't have a serial port on my NRF52810 board. Do you mean an emulated serial port over the debugger or a physical serial port?
    Could you enable the RTT log in the sdk_config.h as follwing and provide it?
    // <e> NRF_LOG_BACKEND_RTT_ENABLED - nrf_log_backend_rtt - Log RTT backend
    #ifndef NRF_LOG_BACKEND_RTT_ENABLED
    #define NRF_LOG_BACKEND_RTT_ENABLED 1
    It will show in the Segger.
    -Amanda H.
  • I enabled RTT as suggested and also disabled deferred logging with...
    NRF_LOG_DEFERRED=0
    I can now see RTT output from this I added in main.c .....
    NRF_LOG_WARNING("hello you\n");
    I am getting no RTT output from the SoftDevice or any other RTT output at all. When the SVCALL(SD_SOFTDEVICE_ENABLE ...) is called the program runs until it gets trapped (see screencap). Am I programming the SoftDevice incorrectly? I'm can't seem to figure this one out!
