Out of bounds memory write in nrfx_gpiote_in_uninit with new pin
The following code has an unexpected out-of-bounds array access:
#define DRDY_PIN 24
nrfx_gpiote_in_uninit(DRDY_PIN);
nrfx_gpiote_in_init(DRDY_PIN, &drdy_cfg,onDRDY_gpiote_evt);
Primary cause is this line:
channel_free((uint8_t)channel_port_get(pin));
On an uninitalized pin number, channel_port_get() returns -1, which is converted to 255 via the cast and this causes out of bounds access in channel_free() - as the latter function does not check its argument for overflows.
Fix is pretty simple:
static void channel_free(uint8_t channel_id)
    if (channel_id >=
      (GPIOTE_CH_NUM + NRFX_GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS)) return;
    m_cb.handlers[channel_id] = FORBIDDEN_HANDLER_ADDRESS;
Edit: This is using nRF SDK 16.0 version.
    Thank you for reporting. I have created an internal ticket so that this can be fixed in a future SDK (and nrfx) release.
  • also happens in SDK 17.0.2 and SDK 15.3
    should modify nrfx_gpiote_in_uninit from this
    void nrfx_gpiote_in_uninit(nrfx_gpiote_pin_t pin)
        NRFX_ASSERT(nrf_gpio_pin_present_check(pin));
        NRFX_ASSERT(pin_in_use_by_gpiote(pin));
        nrfx_gpiote_in_event_disable(pin);
        if (pin_in_use_by_te(pin))
            nrf_gpiote_te_default((uint32_t)channel_port_get(pin));
        if (pin_configured_check(pin))
            nrf_gpio_cfg_default(pin);
            pin_configured_clear(pin);
        pin_in_use_clear(pin);
    to this
        if ( pin_in_use(pin) )
