I tried to merge ble and calendar example but when i call "nrf_cal_init();" I've got error "app: SOFTDEVICE: INVALID MEMORY ACCESS" i tried to use RTC2 in Calendar.h but nothing chenged
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "ble_bas.h"
#include "services/led_service.h"
#include "Battery Level/battery_voltage.h"
#include "services/button_service.h"
#include "Calendar.h"
//#include "nrf_drv_qspi.h"
#define DEVICE_NAME "BLE_Test" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
// Corresponds to LED2 on the development kit
#define LIGHTBULB_LED BSP_BOARD_LED_1
#define LED3 BSP_BOARD_LED_2 /**< LED to be toggled with the help of the LED Button Service. */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50)
/**< Battery timer. */
APP_TIMER_DEF(m_battery_timer_id);
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(1000) /**< Battery level measurement interval (ticks). */
// FROM_SERVICE_TUTORIAL: Declare a service structure for our application
ble_os_t m_our_service;
static bool run_time_updates = false;
// OUR_JOB: Step 3.G, Declare an app_timer id variable and define our timer interval and define a timer interval
APP_TIMER_DEF(m_our_char_timer_id);
#define OUR_CHAR_TIMER_INTERVAL APP_TIMER_TICKS(1000) //1000 ms intervals
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded scan data. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = m_enc_scan_response_data,
/**< Structure used to identify the battery service. */
BLE_BAS_DEF(m_bas);
/**< Structure used to identify the LED service. */
BLE_LED_SERVICE_DEF(m_led_service);
static void led_write_handler(uint16_t conn_handle, ble_led_service_t * p_led_service, uint8_t led_state);
static void battery_level_meas_timeout_handler(void * p_context);
static void battery_level_update(void);
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
static void advertising_start();
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
// Create timers.
err_code = app_timer_create(&m_battery_timer_id,
APP_TIMER_MODE_REPEATED,
battery_level_meas_timeout_handler);
/**@brief Function for starting application timers.
static void application_timers_start(void)
uint32_t err_code;
// Start application timers.
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ret_code_t err_code;
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_UNKNOWN);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
uint32_t err_code;
ble_bas_init_t bas_init;
ble_led_service_init_t led_init;
// 1. Initialize the LED service
led_init.led_write_handler = led_write_handler;
err_code = ble_led_service_init(&m_led_service, &led_init);
// 2. Initialize Battery Service.
memset(&bas_init, 0, sizeof(bas_init));
// Here the sec level for the Battery Service can be changed/increased.
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
bas_init.evt_handler = NULL;
bas_init.support_notification = true;
bas_init.p_report_ref = NULL;
bas_init.initial_batt_level = 100;
err_code = ble_bas_init(&m_bas, &bas_init);
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ret_code_t err_code = NRF_SUCCESS;
NRF_LOG_INFO("Disconnected.");
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
// Pairing not supported
err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
NULL,
NULL);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
uint32_t ram_start = 0;
// Enable BLE stack.
//OUR_JOB: Step 3.C Set up a BLE event observer to call ble_our_service_on_ble_evt() to do housekeeping of ble connections related to our service and characteristics.
NRF_SDH_BLE_OBSERVER(m_our_service_observer, APP_BLE_OBSERVER_PRIO, ble_our_service_on_ble_evt, (void*) &m_our_service);
/**@brief Function for handling write events to the LED characteristic.
* @param[in] p_led_service Instance of LED Service to which the write applies.
* @param[in] led_state Written/desired state of the LED.
if (led_state == 0x01)
bsp_board_led_on(LIGHTBULB_LED);
NRF_LOG_INFO("Received LED ON!");
else if(led_state == 0x02)
bsp_board_led_on(LED3);
NRF_LOG_INFO("Received LED2 ON!");
bsp_board_led_off(LIGHTBULB_LED);
bsp_board_led_off(LED3);
NRF_LOG_INFO("Received LED OFF!");
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[in] event Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
int32_t temperature = 0;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
break; // BSP_EVENT_SLEEP
case BSP_EVENT_DISCONNECT:
break; // BSP_EVENT_DISCONNECT
case BSP_EVENT_WHITELIST_OFF:
break; // BSP_EVENT_KEY_0
case BSP_EVENT_KEY_0:
if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
temperature = 1;
NRF_LOG_INFO("Button1 Pressed");
our_temperature_characteristic_update(&m_our_service, &temperature);
case BSP_EVENT_KEY_1:
temperature = 2;
case BSP_EVENT_KEY_2:
temperature = 4;
case BSP_EVENT_KEY_3:
temperature = 8;
/**@brief Function for initializing leds.
* @details Initializes all LEDs used by the application.
static void leds_init()
err_code = bsp_init(BSP_INIT_LEDS| BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
UNUSED_PARAMETER(p_context);
NRF_LOG_INFO("Battery Level timeout event");
// Only send the battery level update if we are connected
battery_level_update();
/**@brief Function for updating the Battery Level measurement*/
uint8_t battery_level;
uint16_t vbatt; // Variable to hold voltage reading
battery_voltage_get(&vbatt); // Get new battery voltage
battery_level = battery_level_in_percent(vbatt); //Transform the millivolts value into battery level percent.
NRF_LOG_INFO("ADC result in percent: %d\r\n", battery_level);
err_code = ble_bas_battery_level_update(&m_bas, battery_level, m_conn_handle);
NRF_LOG_INFO("err_code %d\r\n", err_code);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
void print_current_time()
printf("Uncalibrated time:\t%s\r\n", nrf_cal_get_time_string(false));
printf("Calibrated time:\t%s\r\n", nrf_cal_get_time_string(true));
void calendar_updated()
if(run_time_updates)
print_current_time();
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize.
log_init();
timers_init();
battery_voltage_init();
leds_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
application_timers_start();
our_service_init(&m_our_service);
uint32_t year = 2020, month = 1, day = 27, hour = 15, minute = 40, second = 0;
while(NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
nrf_cal_init();
nrf_cal_set_callback(calendar_updated, 4);
// Start execution.
NRF_LOG_INFO("BLE started.");
// Enter main loop.
for (;;)
idle_state_handle();
#ifndef __NRF_CALENDAR_H__
#define __NRF_CALENDAR_H__
#include <stdint.h>
#include "time.h"
// Change the following defines to change the RTC timer used or the interrupt priority
#define CAL_RTC NRF_RTC2
#define CAL_RTC_IRQn RTC2_IRQn
#define CAL_RTC_IRQHandler RTC2_IRQHandler
#define CAL_RTC_IRQ_Priority 3
// Initializes the calendar library. Run this before calling any other functions.
void nrf_cal_init(void);
// Enables a callback feature in the calendar library that can call a function automatically at the specified interval (seconds).
void nrf_cal_set_callback(void (*callback)(void), uint32_t interval);
// Sets the date and time stored in the calendar library.
// When this function is called a second time calibration data will be automatically generated based on the error in time since the
// last call to the set time function. To ensure good calibration this function should not be called too often
// (depending on the accuracy of the 32 kHz clock it should be sufficient to call it between once a week and once a month).
void nrf_cal_set_time(uint32_t year, uint32_t month, uint32_t day, uint32_t hour, uint32_t minute, uint32_t second);
// Returns the uncalibrated time as a tm struct. For more information about the tm struct and the time.h library in general please refer to:
// www.tutorialspoint.com/.../time_h.htm
struct tm *nrf_cal_get_time(void);
// Returns the calibrated time as a tm struct. If no calibration data is available it will return the uncalibrated time.
struct tm *nrf_cal_get_time_calibrated(void);
// Returns a string for printing the date and time. Turn the calibration on/off by setting the calibrate parameter.
char *nrf_cal_get_time_string(bool calibrated);
The nrf_cal_init function will access the CLOCK peripheral, which has restricted access when the softdevice is enabled (the softdevice controls the clocks).
The LFCLK will always be running with the softdevice enabled. You can use the Clock driver to control the clock if you are switching between having the softdevice enabled and disabled.
Jørgen
Thanks for your answer! It is my first experience of using nordic and ble. If I understand you correctly i need to change nrf_cal_init function. I will be very grateful if you give me an example of how to fix it
If you are using the softdevice, it should be sufficient to comment out lines 25-28 in the file I linked on GitHub above.
You also need to use RTC2 like you suggested in your initial post.
