how to resign pins in saadc example
Hi
I'm not familiar with C language, I tested the saadc example in SDK, it worked well in P0.02
But I dont see how they set CH[X].PSELP or CH[X].PSELN (V(p) and V(n)) in main.c
I dont know how to implement this code to work with other ADC pins.
Please help me with it and correct me if I was wrong.
I'm using nrf52 dk and segger embedded studio.
Cindy
  • Hi Cindy
    Do you just need a 2kHz square wave, or do you want to use the PWM for more sophisticated sounds?
    Normally the base clock of the PWM is much higher than then output frequency of the signal, to allow you a better PWM resolution.
    Best regards
    Torbjørn
  • the reason why I want to adjust the frequency is that my speaker isn't very loud with current code, I thought it's because the frequency is too high so the speaker can't have a high decibel level.
    Yesterday, I tried pwm_library,
    /** @file
     * @defgroup pwm_example_main main.c
     * @ingroup pwm_example
     * @brief  PWM Example Application main file.
     * This file contains the source code for a sample application using PWM.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf.h"
    #include "app_error.h"
    #include "bsp.h"
    #include "nrf_delay.h"
    #include "app_pwm.h"
    APP_PWM_INSTANCE(PWM1,1);                   // Create the instance "PWM1" using TIMER1.
    static volatile bool ready_flag;            // A flag indicating PWM status.
    void pwm_ready_callback(uint32_t pwm_id)    // PWM callback function
        ready_flag = true;
        ret_code_t err_code;
        /* 1-channel PWM, 100000 microseconds period = 0.1 second , output on pin 28. */
        app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(1000L, 28);
        /* Switch the polarity of the second channel. */
        pwm1_cfg.pin_polarity[1] = APP_PWM_POLARITY_ACTIVE_HIGH;
        /* Initialize and enable PWM. */
        err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
        app_pwm_enable(&PWM1);
        //DUTY CYCLE SET TO 50%
        while (app_pwm_channel_duty_set(&PWM1, 0, 10) == NRF_ERROR_BUSY);
        while (true)
        // Configure pin 5 as output
        nrf_gpio_cfg_output(4);
        // Set pin 5 high
        nrf_gpio_pin_set(4);
        nrf_delay_ms(1000);
        // Set pin 5 low
        nrf_gpio_pin_clear(4);
        nrf_delay_ms(1000);
    "app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(1000L, 28);" (1kHz)
    by changing the perid of time, I think I changed the frequncy?
    But it's still not very loud. Please let me know if I did it right?
    btw, I tested this speaker with Arduino, I used their tone function.
    Here's the description of their tone function
    Generates a square wave of the specified frequency (and 50% duty cycle) on a pin. A duration can be specified, otherwise the wave continues until a call to noTone(). The pin can be connected to a piezo buzzer or other speaker to play tones.
    Only one tone can be generated at a time. If a tone is already playing on a different pin, the call to tone() will have no effect. If the tone is playing on the same pin, the call will set its frequency.
    So I think I need a simple square wave.
    Could it because the speaker doesn't get enough current?
    https://media.digikey.com/pdf/Data%20Sheets/CUI%20Inc%20All%20Brands%20PDFs/CCV-084B16-SMT.pdf
    here's the datasheet of the speaker I'm using.
    Thanks for your help.
    Cindy
  • Hi Cindy
    If you need to generate a square wave of varying frequencies I don't think the PWM peripheral is the best choice, since the PWM is designed for applications where you use a fixed base frequency and modulate a signal on top of this.
    Instead it should be enough to set up the TIMER, PPI and GPIOTE modules to toggle a pin when the timer overflows, and then you just change the compare value of the timer to change the frequency of the pin.
    I made an example showing how to do this a while back and I will see if I can find it, hopefully by tomorrow.
    Are you saying the speaker is louder when you use it with Arduino than when you use the Nordic kit?
    Some speakers need a particular hardware configuration to get optimal performance, but this is normally mentioned in the datasheet.
    Best regards
    Torbjørn
  • Instead it should be enough to set up the TIMER, PPI and GPIOTE modules to toggle a pin when the timer overflows, and then you just change the compare value of the timer to change the frequency of the pin.
    Hi did you find the example?
    Cindy
  • Hi Cindy
    Sorry for not getting back to you.
    I couldn't find the old example unfortunately, but it was quite simple and I should be able to create something similar shortly. I will get back to you by the end of the week with a similar example.
    Best regards
    Torbjørn
