Hi DevZone Team,
Is there a way to stop the ZigBee network steering after a device has successfully joined instead of waiting for the timeout to expire?
Thanks
Hi DevZone Team,
Thanks
I cannot find any APIs to do this, and also the spec says that the minimum commissioning time (bdbcMinCommissioningTime) should be set to 180s.
Jørgen
Thanks for looking into this Jorgen.
since I was looking at a related case, I came up with the following solution:
static void network_close_global_cb(zb_bufid_t buf)
NRF_LOG_INFO("Network closed");
if (buf)
zb_buf_free(buf);
static void network_close_global(zb_bufid_t buf)
zb_zdo_mgmt_permit_joining_req_param_t * p_req;
NRF_LOG_INFO("Zigbee network closed locally...");
p_req = ZB_BUF_GET_PARAM(buf, zb_zdo_mgmt_permit_joining_req_param_t);
p_req->dest_addr = ZB_NWK_BROADCAST_ROUTER_COORDINATOR;
p_req->permit_duration = 0;
p_req->tc_significance = 1;
zb_zdo_mgmt_permit_joining_req(buf, network_close_global_cb);
void network_close(zb_bufid_t buf)
zb_zdo_mgmt_permit_joining_req_param_t * p_req = NULL;
if (!ZB_JOINED())
return;
if (buf == 0)
(void)zb_buf_get_out_delayed(network_close);
return;
NRF_LOG_INFO("Close Zigbee network...");
p_req->dest_addr = ZB_PIBCACHE_NETWORK_ADDRESS();
zb_zdo_mgmt_permit_joining_req(buf, network_close_global);
It is true, that the BDB forces you to open the network for 180 seconds, but it does not prevent you from issuing permit join request, specified in Zigbee PRO specification .
Kind Regards,
Tomchy
Hi.
I am developing a zigbee coordinator. To open and close the network I also use the zb_zdo_mgmt_permit_joining_req request.
When I open the network and the callback function is called (zdo_mgmt_permit_joining_req_cb) I evaluate the answer from the buffer using the struct zb_zdo_mgmt_permit_joining_resp_s.
It seems as if the status in zb_zdo_mgmt_permit_joining_resp_s always contains the duration time I transmitted with the request. If that correct?
Is there a possibility to read the current joining state of the network?
Lutz
