porting s132 to s140 - understanding security management
To the kind attention of Nordic support team,
I'm porting old code in order to use nRF52840 and s140 softdevice. During initialization of device information service I have old code using ble_dis_init_t
that is defined in
typedef struct
ble_srv_utf8_str_t manufact_name_str; /**< Manufacturer Name String. */
ble_srv_utf8_str_t model_num_str; /**< Model Number String. */
ble_srv_utf8_str_t serial_num_str; /**< Serial Number String. */
ble_srv_utf8_str_t hw_rev_str; /**< Hardware Revision String. */
ble_srv_utf8_str_t fw_rev_str; /**< Firmware Revision String. */
ble_srv_utf8_str_t sw_rev_str; /**< Software Revision String. */
ble_dis_sys_id_t * p_sys_id; /**< System ID. */
ble_dis_reg_cert_data_list_t * p_reg_cert_data_list; /**< IEEE 11073-20601 Regulatory Certification Data List. */
ble_dis_pnp_id_t * p_pnp_id; /**< PnP ID. */
ble_srv_security_mode_t dis_attr_md; /**< Initial Security Setting for Device Information Characteristics. */
ble_dis_init_t;
While the new definition of the same type is:
typedef struct
security_req_t dis_char_rd_sec; /**< Security requirement for reading any DIS characteristic value. */
ble_dis_init_t;
May you please explain to me how old instructions:
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&dis_init_obj.dis_attr_md.read_perm); // do {(ptr)->sm = 1; (ptr)->lv = 2;} while(0)
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init_obj.dis_attr_md.write_perm); // do {(ptr)->sm = 0; (ptr)->lv = 0;} while(0)
map to new framework? Now there is security_req_t dis_char_rd_sec; /**< Security requirement for reading any DIS characteristic value. */
typedef enum
SEC_NO_ACCESS = 0, /**< Not possible to access. */
SEC_OPEN = 1, /**< Access open. */
SEC_JUST_WORKS = 2, /**< Access possible with 'Just Works' security at least. */
SEC_MITM = 3, /**< Access possible with 'MITM' security at least. */
SEC_SIGNED = 4, /**< Access possible with 'signed' security at least. */
SEC_SIGNED_MITM = 5 /**< Access possible with 'signed and MITM' security at least. */
}security_req_t;
So it is ok to set dis_char_rd_sec only? The write part is by default 0? What is in the new enum something that has got the old BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM
meaning?
Is there a low level guide that helps understanding these things? Should be the case, may you please help me to reach it?
Thank you for all your kindness
    Instead of
    now you only need to set e.g.
    dis_init.dis_char_rd_sec = SEC_OPEN;
     Yes.
     Yes. write is now SEC_NO_ACCESS.
     If you need "BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM", set it to
    dis_init.dis_char_rd_sec = SEC_JUST_WORKS;
    Here is the mapping:
        switch (level)
            case SEC_NO_ACCESS:
                BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(p_perm);
            case SEC_OPEN:
                BLE_GAP_CONN_SEC_MODE_SET_OPEN(p_perm);
            case SEC_JUST_WORKS:
                BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(p_perm);
            case SEC_MITM:
                BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(p_perm);
            case SEC_SIGNED:
                BLE_GAP_CONN_SEC_MODE_SET_SIGNED_NO_MITM(p_perm);
            case SEC_SIGNED_MITM:
                BLE_GAP_CONN_SEC_MODE_SET_SIGNED_WITH_MITM(p_perm);
