Hi guys the following is an Arduino code:
volatile long pulses = 0;
unsigned long timeO = 0;
unsigned long timeF = 0;
float encoderSpeed = 0;
void setup()
Serial.begin(9600);
pinMode(7, OUTPUT); // stdby
pinMode(4, OUTPUT); //ain1
pinMode(5, OUTPUT); //ain2
pinMode(6, OUTPUT); //pwmA
pinMode(11, OUTPUT); //bin2
pinMode(10, OUTPUT); //bin1
pinMode(9, OUTPUT); //pwmB
digitalWrite(7, LOW); // stdby LOW
pinMode(2, INPUT_PULLUP); //Pulse A
pinMode(3, INPUT); //Pulse B
attachInterrupt(digitalPinToInterrupt(2), detectPulses, RISING);
void loop()
int input = Serial.parseInt();
int select = input / 10000; //// switch motors
int val = input % 10000; //// notrmal parameter
int speedm = val % 1000;
int state = val / 1000;
if (select == 1);
if (state == 1) //clockwise
digitalWrite(4, LOW);
digitalWrite(5, HIGH);
analogWrite(6, speedm); ///PWM
digitalWrite(7, HIGH); //stdby
if (state == 2) //clockwise
digitalWrite(4, HIGH);d
digitalWrite(5, LOW);
///////////////motor 2///////////////
if (select == 2);
if (state == 3) //clockwise
digitalWrite(10, LOW);
digitalWrite(11, HIGH);
analogWrite(9, speedm); ///PWM
if (state == 4) //clockwise
digitalWrite(10, HIGH);
digitalWrite(11, LOW);
timeF = micros(); // Geting the final time to get the speed
encoderSpeed = ((float)pulses) / ((float)(timeF - timeO) / (6000.0));
Serial.print("Speed: ");
Serial.print(encoderSpeed); // Printing speed value
Serial.println(" rev/min");
pulses = 0; // Initialize pulses to count again
timeO = micros(); // Initialize initial time again
void detectPulses()
if (digitalRead(3) == LOW)
{ //Confirm if we are turning on CW direction.
pulses++; // Adding pulses
{ //Confirm if we are turning on CCW direction.
pulses--; // Substraing pulses
In here,
We are taking the rising edge pulse to measure the rotation per minute of the DC motor and to detect whether the DC motor rotates clockwise or anti-clockwise. I am using the NRF52840 to replace arduino here. So , How can I detect rising edge clock with NRF. It would be very useful if I can get examples. The encoders inside give a feedback (I think they are hall sensors).
