Rebroadcasting Advertisements Unintentionally
QUESTION(s): Is there such a thing in BT spec that allows for a device to rebroadcast advertising data for another device? Sort of like a flood mesh. Could it be iBeacon specific and only occur with Apple devices?
REASONING: I am able to clearly reproduce the following phenomena:
Setup - I place a nRF52832 based advertising beacon into a semi-anechoic chamber and read RSSI from outside the chamber using a nRF52832 dev kit or really any device that can scan for advertisements. It's near the noise floor, around -80 to -90 dBm.
I have a Raspberry Pi 3 device that I turn on and enable BLE, I am immediately able to see the RSSI dramatically increase (-40dBm) with the same UUID and major-minor as the beacon in the shield chamber. I move the RPI3 closer and further from my scanning device and see it change accordingly. I turn off the RPI3 and the beacon strength goes back to very weak. It appears the RPI3 is "rebroadcasting" the advertisement data.
I am also able to reproduce this sequence using an Apple iPhone 11 Pro Max running iOS 13.1.3. No apps are running in the foreground.
