disconnecting while operations are in progress never gives BLE_GAP_EVT_DISCONNECTED event
2020-01-24-092119EST-ProductStoppedGettingEventsFromNordicDK.txtImprivataTestNordicEventsNotReceived.zipCalls_to_pc_ble_driver.cpp0285.2020-02-24-TestProgramUploadedToNordicSupport.zipFeb25TestProgramUploadedToNordicSupport.zipImprivata_bgTestApp.zipbgSDKTestAppMay4.zip2020-05-05-035347-NordicDK_USB840M_200505_ClockInternal_2in1.hex.txt.txtbgSDKTestAppMay6.zipI’m developing an application based on pc-ble-driver to talk to an nRF52840-based dongle (from Fanstel).
I’m having trouble disconnecting cleanly when a connection has operations in progress.  For example, I call ‘sd_ble_gattc_write’, which returns NRF_SUCCESS, but I don’t receive event BLE_GATTC_EVT_WRITE_RSP (after waiting 60 seconds), so I decide to disconnect. When this happens, sd_ble_gap_disconnect returns NRF_SUCCESS, but I do not receive BLE_GAP_EVT_DISCONNECTED even after waiting 30 seconds. The connection supervision timeout is 4 seconds.  What could cause the disconnect to not generate any BLE_GAP_EVT_DISCONNECTED event?
What I’m trying to accomplish here: if a connection is not responsive, I want to end that connection, without disturbing other connections I have open.
Paul Bradford
  • I have had the new application running on my PC with 5 parallel devices for 8 hours yesterday and 4 hours today. So far, I have not been able to reproduce the issue. I do have another PC that does not have Nordic tools installed, but this is not a Dell PC. I will try to setup the test on that one next. It's a bit harder to find equipment for testing this with the limited factors where you have managed to reproduce the issue, due most of us working from home-office due to the Corona situation. Is it still a requirement to have heavy Bluetooth activity around the device in order to reproduce the issue? This could also be a problem to facilitate during home-office.
  • I have been reproducing the problem with the new test program at home, where there are few BLE devices. I've also been running a single copy of the program and still reproducing it.
  • Hi Jorgen,
    I just wanted to confirm that the test program is actually tracking phones. These are the instructions from the README file with the test program:
    You can type command 's' (and Enter) at any time to have the test program show progress.
    The first line of progress shows the total number of advertisements received through scanning, and how many of those have 128-bit UUIDs.
    The second line shows the status of the one UUID we are trying to track (the Android peripheral running Imprivata ID).
    Example output if the test program currently has a connection to the test peripheral:
     2020-03-28 14:33:56.614: (WARNING) phone is being tracked: UUID: 1f1413aa-a819-4da2-ae94-c3564c8da7ec; total #adverts = 657
    Example output if the test program currently does NOT have a connection to the test peripheral:
     2020-03-28 14:33:56.614: (WARNING) phone is NOT being tracked: total #adverts =
    If you can't reproduce this problem with the test program, what help can you give me on diagnosing the problem on my test machines?   Can you create a diagnostic version of the S140 SoftDevice that will generate more logging information when I run it on the Nordic DK and view logging with J-LINK RTT Viewer?
    Let me summarize what I'm seeing.
    Since this doesn't reproduce on all machines, there is some machine-dependent factor in whether this is reproducible. But I can't imagine a machine-dependent factor that would explain the behavior I'm seeing. At the time the problem occurs, all events from the Nordic chip cease. The serial-port-reader (in pc-ble-driver) still reads "responses" from commands, but never gets another event.
    1. The first operation to fail is a write - no event.
    2. Then I do a disconnect - get a response but no event.
    3. Then I do a connect - get a response but no event.
    In mid-January, you had me use connectivity firmware with logging enabled. On January 28, I uploaded logging that showed that I send a read request and never get any event in response.    To me, this indicates the problem is in the SoftDevice layer, since the Connectivity layer never got the event. We need some kind of logging that shows what is happening in the SoftDevice - why does it stop emitting all events?
    -Paul
  • Hi Paul,
    Today, I managed to reproduce this once on a second computer. That was with the nRF52840 Dongle and the stock connectivity FW (no logging enabled). I'm now testing on the same machine with a nRF52840 DK with logging enabled in the connectivity FW, but so far, I have not been able to reproduce the issue with this setup.
    I can't rule out Softdevice issue entirely, but I would have expected this to be reported by more customers and applications if the problem originated there. Hopefully, we will be able to reproduce it with the logging setup soon to get more details on the root cause. The SDK developers are also trying to reproduce the issue on their end.
    Jørgen
  • Hi Jørgen,
    Have you been able to reproduce the problem again?  Can you tell me the model PC on which you did reproduce it?
    -Paul
