disconnecting while operations are in progress never gives BLE_GAP_EVT_DISCONNECTED event
2020-01-24-092119EST-ProductStoppedGettingEventsFromNordicDK.txtImprivataTestNordicEventsNotReceived.zipCalls_to_pc_ble_driver.cpp0285.2020-02-24-TestProgramUploadedToNordicSupport.zipFeb25TestProgramUploadedToNordicSupport.zipImprivata_bgTestApp.zipbgSDKTestAppMay4.zip2020-05-05-035347-NordicDK_USB840M_200505_ClockInternal_2in1.hex.txt.txtbgSDKTestAppMay6.zipI’m developing an application based on pc-ble-driver to talk to an nRF52840-based dongle (from Fanstel).
I’m having trouble disconnecting cleanly when a connection has operations in progress.  For example, I call ‘sd_ble_gattc_write’, which returns NRF_SUCCESS, but I don’t receive event BLE_GATTC_EVT_WRITE_RSP (after waiting 60 seconds), so I decide to disconnect. When this happens, sd_ble_gap_disconnect returns NRF_SUCCESS, but I do not receive BLE_GAP_EVT_DISCONNECTED even after waiting 30 seconds. The connection supervision timeout is 4 seconds.  What could cause the disconnect to not generate any BLE_GAP_EVT_DISCONNECTED event?
What I’m trying to accomplish here: if a connection is not responsive, I want to end that connection, without disturbing other connections I have open.
Paul Bradford
  • Today I have reproduced it 3 times on the same PC, but only with the precompiled HEX file. Last week I ran it for multiple days on the same PC with logging enabled, without being able to reproduce.
    This was on a ASUS ET2221 All-in-One PC, which is the only I have available without Nordic tools installed.
  • What is the next step now?
    We can't make any progress on using the nRF52840 until this is fixed, or you find some way for us to avoid the problem.
    If you are trying to reproduce it with the connectivity firmware logging enabled, I already posted that on January 24, and it didn't show any useful information.
  • Hi Paul,
    The point of reproducing it with logging enabled is not just to get similar logs to what you posted on January 24, but to add more logging to the application in order to find where the issue occurs.
    I can now consistently reproduce this issue on the same computer, with two different phones, with UART logging enabled. This means that I should be able to add more logging next week, and hopefully get some more details on why this is happening. It's a bit strange that I'm not able to reproduce with RTT logging enabled, but UART will have to do for now. Unfortunately, our SDK developers are still not able to reproduce it on their end, so, for now, we only have my setup to debug with.
    Have a nice weekend.
    Jørgen
    I ran the application many times over the last few days and from studying the logs it seems that this issue occurs right after the application/connectivity FW starts receiving notifications from the connected phone. It could be a coincidence, but I see the same pattern in all the log-files I have checked. Is there any way you could disable the notifications in the phone application, in order to verify if that is what's causing the issue?
    Another customer have reported similar issues with pc-ble-driver, but he was only able to reproduce this with sd_api_v3, not with 6 like you are using. However, it has some other similarities with this issue (I was not able to reproduce his issue when running J-Link RTT Viewer, same as here).
    Jørgen
  • I agree it seems that the problem is related to receiving notifications. In my reply on January 22 I wrote "The failure to receive events always occurs after I have received notifications for a characteristic."
    I've done an experiment that is much simpler than altering the phone app. The notifications from the phone app are triggered by the Windows app writing to a particular characteristic on the phone. I modified the Windows app so that it (optionally) does not write to that characteristic. With that option enabled, the Windows app runs for many hours without failing (about 18 hours so far). By contrast when I start it without that option (and thus with notifications received), it fails in less than an hour each time.
