Adding fstorage functionality to project
Good day.
I am trying to add flash storage functionality to a project based on the ANT asynchronous transmitter example and the ANT back ground channel example of the SDK v16.0.0. That using the softdevice s340. My setup consist of a computer running windows 7, and I am using SEGGER to program the development kit. With the flash_fstorage example as a guideline I have performed the following actions in my project:
include the libraries:
      - nrf_fstorage.h
      - nrf_fstorage_sd.h
include the files on the folder nRF_Libraries
      - nrf_fstorage.c
      - nrf_fstorage_sd.c
add the path to user include directories in the project common configuration
      ../../../../../../components/libraries/fstorage
and finally I added the fstorage configuration to the sdk_config.h file.
// <e> NRF_FSTORAGE_ENABLED - nrf_fstorage - Flash abstraction library
#ifndef NRF_FSTORAGE_ENABLED
#define NRF_FSTORAGE_ENABLED 1
// <h> nrf_fstorage - Common settings
// <i> Common settings to all fstorage implementations
// <q> NRF_FSTORAGE_PARAM_CHECK_DISABLED  - Disable user input validation
// <i> If selected, use ASSERT to validate user input.
// <i> This effectively removes user input validation in production code.
// <i> Recommended setting: OFF, only enable this setting if size is a major concern.
#ifndef NRF_FSTORAGE_PARAM_CHECK_DISABLED
#define NRF_FSTORAGE_PARAM_CHECK_DISABLED 0
// </h>
// <h> nrf_fstorage_sd - Implementation using the SoftDevice
// <i> Configuration options for the fstorage implementation using the SoftDevice
// <o> NRF_FSTORAGE_SD_QUEUE_SIZE - Size of the internal queue of operations
// <i> Increase this value if API calls frequently return the error @ref NRF_ERROR_NO_MEM.
#ifndef NRF_FSTORAGE_SD_QUEUE_SIZE
#define NRF_FSTORAGE_SD_QUEUE_SIZE 4
// <o> NRF_FSTORAGE_SD_MAX_RETRIES - Maximum number of attempts at executing an operation when the SoftDevice is busy
// <i> Increase this value if events frequently return the @ref NRF_ERROR_TIMEOUT error.
// <i> The SoftDevice might fail to schedule flash access due to high BLE activity.
#ifndef NRF_FSTORAGE_SD_MAX_RETRIES
#define NRF_FSTORAGE_SD_MAX_RETRIES 8
// <o> NRF_FSTORAGE_SD_MAX_WRITE_SIZE - Maximum number of bytes to be written to flash in a single operation
// <i> This value must be a multiple of four.
// <i> Lowering this value can increase the chances of the SoftDevice being able to execute flash operations in between radio activity.
// <i> This value is bound by the maximum number of bytes that can be written to flash in a single call to @ref sd_flash_write.
// <i> That is 1024 bytes for nRF51 ICs and 4096 bytes for nRF52 ICs.
#ifndef NRF_FSTORAGE_SD_MAX_WRITE_SIZE
#define NRF_FSTORAGE_SD_MAX_WRITE_SIZE 4096
This last step produced various unexpected compilation errors
When I compile I get the following output:
Compiling ‘nrf_sortlist.c’
Compiling ‘nrf_strerror.c’
Compiling ‘nrf_queue.c’
Compiling ‘nrf_fstorage.c’
Compiling ‘nrf_drv_uart.c’
Compiling ‘nrf_fstorage_sd.c’
sdk_common.h
nrf_fstorage_sd.c
    'NRF_SDH_SOC_ENABLED' undeclared here (not in a function); did you mean 'NRF_SDH_LOG_ENABLED'?
    in definition of macro '_SELECT_ASSERT_FUNC'
    in expansion of macro 'STATIC_ASSERT_MSG'
    in expansion of macro 'STATIC_ASSERT'
    in expansion of macro 'NRF_SDH_SOC_OBSERVER'
    expression in static assertion is not an integer
    'NRF_SDH_SOC_OBSERVER_PRIO_LEVELS' undeclared here (not in a function); did you mean 'NRF_SDH_STACK_OBSERVER_PRIO_LEVELS'?
  Compiling ‘nrfx_atomic.c’
  Compiling ‘nrfx_gpiote.c’
Build failed
Any Idea on how to solve this?
