nRF Sniffer on nRF52840 Version 3 installation error
I am working on a Windows 10 pc. python 3.7 is installed and the requirements.txt has been installed successfully and I have the most current pyserial installed
I have successfully installed firmware hex code on the nRF52840 dev board.
Copied the the contents of Sniffer_Software/extcap to the Wireshark extcap folder
When I run the nrf_sniffer_ble.bat --extcap-interfaces as per the pdf instructions I receive an error.
This results in the following error:
c:\Program Files\Wireshark\extcap>nrf_sniffer_ble.bat --extcap-interfaces
File "c:\Program Files\Wireshark\extcap\nrf_sniffer_ble.py", line 52, in <module>
from SnifferAPI import Sniffer, myVersion, Logger, UART, Devices
File "c:\Program Files\Wireshark\extcap\SnifferAPI\Sniffer.py", line 53, in <module>
from . import SnifferCollector
File "c:\Program Files\Wireshark\extcap\SnifferAPI\SnifferCollector.py", line 37, in <module>
from serial import SerialException
ImportError: cannot import name 'SerialException' from 'serial' (C:\Users\WORK\AppData\Local\Programs\Python\Python37\lib\site-packages\serial\__init__.py)
Can you please help?
Thanks
Rick
  • Hello Rick,
    Sorry if I'm bothering you.
    I just had a few things that I wanted to finish before reporting this internally since you had it up and running. I wanted to check whether I was able to reproduce the issue that you had with the previous version of Python. If it is, in fact, a bug, we should either update the documentation or find a fix, so that others don't need to struggle with the same.
    So which version of Python did you use before you updated to 3.8.1?
    Have a nice weekend.
    Edvin
  • Sorry Edvin, I should have included that I was using Python version 3.7.6
    Rick
     No problem :) Thank you!
    I was not aware that you were using the dongle. Unfortunately, the dongle isn't supported in the BLE sniffer.
    pca100XX is the name of the different HW that we have. pca10056 is the nRF52840 DK, while the pca10059 is the nRF52840 dongle. The reason it doesn't work to use the nRF52840 DK FW on the dongle is because the FW uses UART, via the debugger on board to translate from uart to USB. On the dongle, the UART pins aren't connected to anything, and it doesn't have a debugger to translate from UART to USB.
    The USB part on the dongle is the actual USB peripheral on the nRF52840. Although technically possible, we don't have any FW for the nRF Sniffer that does this at this point in time. I am sorry.
    Edvin
  • Thanks. So the Programmer recognizes that the code is invalid and disables all to install it?
    Have a great weekend!
    Rick
     Not sure what you mean, but the reason you don't see the dongle in the programmer app is because you programmed it with an application that doesn't use the USB at all, and hence the USB will only be used for power source. If you press the reset button (Not the white button, but the "sideways" button next to it) while the dongle is connected to USB power, it will re-enter bootloader mode, and you can program new applications to it. However, it will still not work with the nRF Sniffer. But now you can at least use it for something else.
    Edvin
