NRF52 Bootloader Switch Between Applications
I am using the nrf52832 bootloader and i got it working with the s112 sofdevice and a custom application mapped at the end of the softdevice.
I want to add another application (between my first application and the bootloader). And i want to modify the bootloader to choose whether to jump to the first application or the seconde one.
The mapping of my flash is as follows:
Softdevice address : 0x0 - 0x18fff
Application 1 : 0x19000 - 0x3fff
Application 2 : 0x40000 - 0x5fff
Bootloader : 0x60000 - 0x7dff
Is there any way i can change the start address from the Bootloader before jumping into it ?
Thank you for your help.
    you can jump from bootloader to your firmware with this function:
    static sd_mbr_command_t init_sd_command = {SD_MBR_COMMAND_INIT_SD, };
    void jump_to_fw(uint32_t fwaddr)
    	sd_mbr_command(&init_sd_command);
    	sd_softdevice_vector_table_base_set(fwaddr);
    	uint32_t app_start_ptr = ((uint32_t *)fwaddr)[1];  // get start address from vector table
    	((void (*)()) app_start_ptr) ();
  • Thank you for the answer.
    I was already doing that. But i was also forwarding interrupts to the start address of my application using the SD_MBR_COMMAND_IRQ_FORWARD_ADDRESS_SET command.
    So the jump to the application was being executed successfully but the application was crashing after calling nrf_sdh_enable_request().
    So after removing the forward command, the application launched without any problem.
