Mesh disconnection
Hi everyone,
I recently finished developing a program that includes BLE, mesh and DFU.
Everything seems to be working but there is a problem with disconnection.
The real system includes 9 mesh devices which, for one reason or another, could disconnect due to the low signal quality.
I had already checked that, in the evaluation sheets, once the signal quality was restored, the reconnection was always verified.
With the PCB produced by us, however, this thing does not happen, and even with a good signal it does not return to connect to the network.
The code in both cases is clearly the same, the development uses a rigado module with external antenna. I checked the quality and disconnection by checking the RSSI in the porvisioner.
By removing the antenna, the device is no longer present and reconnecting it, in one case it reappears in the other instead it does not.
If anyone could help will be awesome. Thanks for the attention
AM
